Well if the trunion ataches to the cabinet then adjusting it should be a snap.
Before you start Check that the blade is 90 deg to the table with a good quality combination square or a machinist square.
First you loosen the 4 bolts that attach the table top to the cabinet
Check and adjust the measurement between the Miter slot and the Saw Blade making sure to always use the same point (tooth)
After you are satisfied that the slot is parallel to blade tightnen the bolts carefully so that you don't loose your adjsutement.
Now adjust the fence to the miter making it also parallel.
For maximum precision it is recommended to use a Dial Gauge indicator but you can also use a combination square.
