61 - 80 of 103 Posts
· Registered
Discussion Starter · #62 ·
· Registered
Discussion Starter · #63 ·
Making spoke wheels
It's time to get started on the spoke wheels so I'll know how the fenders will need to be.
I found some dowels about twice the size of tooth picks at wally world, really like the size but the drill bits I've got to work with it seem to have a mind of their own.
Come to think about it now I haven't switched out bits in quite some time so will be digging out the drill set next time I'm in the shop.
I really didn't want to use maple again but already have some blanks made up and not enough oak, I just don't have the gumption to go the extra mile for this model.
So here we go.
I'm drilling out the centers of the wheel blanks for the spokes.
Wood Machine tool Creative arts Engineering Machine
The rims will need to be thinned down after I see what I have after the spokes are set.
Wood Electrical tape Gas Composite material Automotive tire
Automotive tire Gas Engineering Machine tool Automotive wheel system
All my hole saws use the same 1/4" guide bit so very easy to drill it all.
Automotive tire Gas Circle Nut Auto part
Drilled the out side then the center hub, then drill out the center and chisel it out.
I know I could have done this on the lathe but just not wanting to have to set it all up when I can have it done in the time it take to get the lathe set up. ;-{
Automotive tire Wheel Bumper Rim Automotive wheel system
Automotive tire Wood Gas Font Circle
Automotive tire Wood Gas Auto part Engineering
Couple a minutes with a chisel and we're ready to drill the spoke holes.
I tried to set up my wheel making jig to drill the holes but the drill bits just wouldn't cooperate, so drilled all the holes by hand which I like doing any way so no problem.
Wood Gas Auto part Metal Circle
If you're wondering what I'm doing here, by leaving 1/16"-1/8" of the blank still on the rims the center and rim will stay centered and I will cut the wood out after the spokes have been glued up.
I will need to thin the wheels down any way once I see how much room the spokes used.
Drilling the spokes by hand is not an exact science so will just have to see where the spokes ended up after drilling and glue up.
Wood Circle Composite material Stairs Art
It helps to have a backer board screwed down as you drill all the holes.
Pneumatic tool Saw Drill Hammer drill Handheld power drill
I drilled the hub with one spoke just past the front of the center line and the other to the back, so the spokes aren't ganging up on each other, I had trouble with this on my first set of spokes.
Automotive tire Wood Motor vehicle Rim Gas
Not to bad for 6 hours of play.
Automotive tire Motor vehicle Wheel Automotive design Alloy wheel
Wheel Tire Automotive tire Motor vehicle Wood
Wheel Automotive tire Vehicle Tire Wood
Now I'll need to make some oak treads to cover them.
· Premium Member
Making spoke wheels
So here we go.
Very nice looking wheels!
· Registered
Making spoke wheels
So here we go.
Just a comment on the spokes. My wife had some bamboo skewers she got in the houseware section at a variety store. They are just about the correct size for a 3" wheel. They are strong and have some give to them if you don't get your holes lined up. Nice job on the truck.
· Registered
Making spoke wheels
So here we go.
The wheels are amazing Bruce, so fiddly by hand but come out a treat!
· Registered
Making spoke wheels
So here we go.
Nice job on the wheels!
· Premium Member
Making spoke wheels
So here we go.
now its getting very exciting #4 i was waiting for the wheels on this jalopy :<)))
· Registered
Making spoke wheels
So here we go.
Very cool way going about making those wheels. Almost has me wanting to try them. Nice work.
· Registered
Discussion Starter · #70 ·
Making spoke wheels
So here we go.
Someone on Face Book asked why I didn't use my Shop Smith as a lathe and turn the hubs, and I know I could but I've been doing it this way and have it figured out plus the time it would take to set up and get all my lathe tools together I can have it done with out getting out of my chair. ;-]]]
I haven't said it in a while but there's a hundred ways to do something and this is what works for now.
· Registered
Making spoke wheels
So here we go.
Always fun to see your wheel builds!
· Registered
Making spoke wheels
So here we go.
The wheels look great. And so does the truck. Nice job on both.
I agree, lathe would work but then you lose the center. The way you explained it makes perfect sense. Now a thought tighten it on a threaded shaft and fine tune the wheels.
· Registered
Discussion Starter · #73 ·
Making spoke wheels
So here we go.
- Eric
Eric that's what I did today but sad to say no pictures. ;-[
I use the SS disk sander jig to round everything then as you said bolt to the drill press and sand it pretty.
Built this way they are balanced and spin like a top.
· Registered
Making spoke wheels
So here we go.
I didn't even think about the balance, that is great
· Registered
Making spoke wheels
So here we go.
What a brainstorm, axles and tires one piece.
· Registered
Making spoke wheels
So here we go.
I was wondering if back panel of wheel got sawn off after spokes were installed?
· Registered
Discussion Starter · #77 ·
Making spoke wheels
So here we go.
Woodclaver On these I took the hole saw I used to make the hole and slowly drilled out the backs but I seem to remember on one project I left them on.
· Registered
