1 - 20 of 103 Posts
· Registered
Discussion Starter · #1 ·
LowBoy Heavy Duty Trailer
I just love making low boy trailers and being able to put my models on them,
No I am not playing with my models. LOL
Getting started,
Wood Floor Rectangle Wood stain Flooring
Hand tool Metalworking hand tool Wood Tool Wrench
Needed a pop can for size picture.
Table Wood Wheel Floor Flooring
Wood Hardwood Flooring Plywood Wood stain
Gluing up a slab, I clamp a board down so I can glue up the parts one at a time and hold them in place with hand pressure
It's 1/4" thick so clamps would just be a pain and get in the way.
Wood Floor Flooring Hardwood Wood stain
Wood Floor Hardwood Flooring Rectangle
#4 over and out.
· Registered
Getting started,
#4 over and out.
Looking Great
as always. I am sure it will be a top contender.
· Registered
Getting started,
#4 over and out.
That laminated deck is going to really make this dropdeck trailer look something very special Bruce.
· Registered
Discussion Starter · #4 ·
Really doesn't look like I got much done but there's a ton a work in there, plus I went ahead and made up wheel blanks for the trailer and also the truck I may build to match.
Table Wood Floor Flooring Hardwood
Waste container Wood Wood stain Rectangle Hardwood
Wood Rectangle Table Hardwood Wood stain
25 wheel blanks, glued up and sized.
There's a ton a work ahead on the tires but you all know I LOVE building wheels!!! LOL
Wood Rectangle Basket Hardwood Shelf
· Premium Member
gonna look real nice when finished :<))
· Registered
Looking good Bruce but cutting the tyre tread on 25 wheels will take the patience of a saint.
· Registered
Discussion Starter · #7 ·
It can be accomplished as I have the technology needed to get er done. lol
· Registered
Discussion Starter · #8 ·
Figuring out the wheels
Worked on gluing up and then cutting out the wheel blanks yesterday and shaped the out sides.
Twenty five of them.
Then today I cut out the treads.
First cut out the treads on the tread cutting jig.
Wood Gas Automotive tire Engineering Hardwood
Had to load the jig 4 times to get er done.
Wood Machine tool Gas Composite material Machine
Automotive tire Wood Gas Engineering Machine
Then needed to set up the table saw fence for cutting the treads in the other direction.
It takes some time playing around with the fence to get just the right spacing for the treads.
I would have loved adding one more groove but didn't think the wood could handle that kind a abuse.
Automotive tire Road surface Wood Tread Asphalt
Wood Road surface Rectangle Asphalt Flooring
You can see where I did the extra groove in these tires but the wood was just a bit thicker so they could handle it.
Tire Wheel Automotive tire Synthetic rubber Tread
I then got down the spare wheel box and looked through it for ideas for the rims.
Automotive tire Tread Wood Tire Trunk
LOL While I was at it I took some pictures of them, you probable remember where a lot of them came from.
When I make wheels I try to all ways make a few extras so if one doesn't work out there's no problem I have another.
Tire Automotive tire Tread Wood Gas
Automotive tire Wood Tread Artifact Automotive wheel system
Automotive tire Wheel Wood Tread Automotive wheel system
My brain went blank after that, it's really hot and humid around here, so time to sleep on it and something will come to mind.
HTL over and out!!!.
· Premium Member
Always interesting blogs!!!
· Registered
Your skills are disturbing. I would love to be as talented as the people I follow on this site.
· Registered
Discussion Starter · #11 ·
FGTOYS You've made a great start, just keep building and the skill will grow as it has for me and all that follow each other as we build and have fun.
· Registered
Thanks for the words of encouragement. Meaningful.
· Registered
French is right, you have some serious skills…... also serious patience. All the wheels looks good. Ever try to sell them to ur local tire shop? No pun intended. They'd make nice key chains with their name on it as advertisement
· Registered
Absolutely Bruce you are for sure a model wheel master.
· Registered
Discussion Starter · #15 ·
Got the trailer wheels under control
Finished up the trailer wheels and will save the semi wheels for when I build the truck.
I took me more time to make these rims than to make the tires and there's twice as many tires as the rims just need to be on the out side looking pretty.
Automotive tire Wood Circle Font Engineering
Wood Table Automotive tire Rectangle Hardwood
Drilling out the spokes for the rims.
Wood Floor Flooring Drilling Tool
Wood Flooring Floor Gas Hardwood
Wood Art Flooring Gas Hardwood
Wood Flooring Hardwood Circle Wood stain
Wood Floor Flooring Tool Sundial
Wood Circle Art Hardwood Plywood
Wood Sundial Flooring Tool Hardwood
Wood Drilling Gas Workbench Tool
Wood Circle Gas Engineering Plywood
Drilling for the lug nuts.
Different jig but same steps gets the lug nuts drilled.
I just used every fourth hole to get my spacing, got to love jigs, once set up just pin and drill no measuring what so ever.
Art Wood Circle Flooring Cuisine
Adding all the lug bolts.
I found some dowels just a tad bigger than tooth picks so gave them a try.
Wood Art Wood stain Flooring Table
Food Tableware Table Ingredient Kitchen utensil
Watch Baked goods Art Cuisine Font
Just about ready to put it all together but a ton a sanding has and will be done before that happens.
Tire Automotive tire Wood Tread Wheel
Tire Automotive tire Wood Rim Motor vehicle
Wood Rectangle Serveware Beige Circle
Wood Gas Hardwood Flooring Plywood
#4 over and out
· Registered
#4 over and out
Nice.
· Registered
#4 over and out
Man oh man, you certainly do beautiful wheels Bruce.
· Registered
Discussion Starter · #18 ·
Adding more to the trailer
HI!!
Table Wood Flooring Hardwood Workbench
Just had to put the wheels on and give it a look, lol
Wood Shelf Table Hardwood Desk
Ton more to do to this but look at how big this thing is.
Wood Flooring Rectangle Floor Wood stain
Wood Table Vehicle Hardwood Plywood
Wood Automotive tire Table Circle Hardwood
Plant Automotive tire Tread Table Wood
· Registered
HI!!
That's one very impressive looking trailer Bruce.
· Registered
HI!!
Looking great htl.
1 - 20 of 103 Posts
