1 - 20 of 26 Posts
Discussion Starter · #1 ·
How far I got in class
I took Roy Underhill's hand tool only class on making a tool chest. It was a wonderful class and I learned a great deal. I highly recommend his classes. We learned about many hand tools and built a dovetailed tool chest. In class I finished the chest and only had to assemble it at home because it had to ship knocked down. The lid I am fitting together and should glue it tomorrow night.
This is a picture of fitting the first section of skirt on to the top portion of the side.
This is the chest with the skirt and bottom attached.
This is a close up of the hand cut dovetails with out any wedges. Roy and his assistant Bill are great teachers because I did not have this skill when I came to class.
Wow. Great work. I'm envious that you got a chance to work with Roy.
Looks very impressive, I'm sure you learnt a lot in his class.
I look forward to seeing this come together - you've done a great job with the main case - it's goodto see that you enjoyed the class.
Hi Rob,
Great job on this.
I bet that was a fun class.
Wow, what a great opportunity for you. I'm jealous, but am really glad for you.
Your work is looking good.
Thanks for sharing
Discussion Starter · #7 ·
Thank you for your kind comments. Roy is just as enthusiastic and interesting as he is on his shows. He has a wonderful shop with a very complete set of hand tools. He has ten + of all the common tools.
In Loving Memory
Really good job on those dovetails Rob. I hope you post it when finished. I sure envy you that Veritas Jack plane.
Nice start on the tool chest.
great work. there is something special about having handcut dovetails on a project like this. the slight inperfections add to the personal nature of the piece.
Discussion Starter · #11 ·
It makes the piece really yours. More personal some how. Thanks for stopping by.
great work!
Discussion Starter · #13 ·
Fitting the lid
Fitting the lid is taking a lot longer than I thought. I had to trim the sides to length freehand as I don't have a miter box. The grooves on the sided required trimming and deepening. Deepening the grooves was with a mortising chisel as I don't have a plow plane.
These pictures how the groove in the frame fits into the groove in the panel and the halves of the mitered bridle joint go together to make the lid. The antique clamp was my Dad's.
Shows the groove in the lid and the mitered bridle joint. Roy gave me a lot of help with these!!!
Discussion Starter · #14 ·
Top is finished
Here is the lid after glue up. Turned ot well. Thanks Roy!!
Discussion Starter · #17 ·
Shaping and adding Spacers to the Handles
Roy (Underhill) had the basic shape of the handles turned for us by a local chair maker. I shaped mine and added a spacer so I could get my stubbie fingers around the grip. I put a thread insert on the back side of the spacer to aid in mountng them to the chest.
i
This picture shows the profile I came up with.
i
Looks good Rob. good ole Roy
i
Looks very nice, I'm sure Roy's class was both a joy and very educational.
Discussion Starter · #20 ·
Lid on and rejected as a blanket chest
Well I finally got the lid back together. My better half thought it looked too good to stay in the garage, but after checking it out in the bed room, it is too small for the foot of the bed. Close call.
As I was mortising the hinges, I dropped the lid onto a front corner. Popped one of the mitered bridle joints. I thought I had clamped the frame to tightly onto the panel but the fit is ok. Reglued the joint, doweled it from underneath. Fit is good and looks ak. It is a tool chest, not fine furniture. I am very pleased wit how it turned out. I learned so much. Thank You Roy Underhill for having such a great school!!
This shows the back with the lid support attached with cut nails. (Trying to stay in period)
Thank you for looking.
1 - 20 of 26 Posts
