Thinning paint for spraying - Dialing it in
49293 Views 36 Replies 14 Participants Last post by  dave_oh
2
I'm about to paint cabinets with Benjamin Moore Advance Waterborne Alkyd and would like to spray it with my Earlex 5500.
Out of the can, the viscosity of BM Advance is over 400 seconds. The Earlex will spray anything 160 seconds or better but I saw someone say on another thread that they can spray the BM Advance just fine after thinning it 10%.
But, I'm a cheap lazy B:$tard so before I thin a quart and potentially waste paint & cleanup time, I wanted to see if I could verify that statement. It seems hard to believe that adding 1 part water (which has a viscosity around 12 seconds) to 9 parts BW advance would bring its viscosity from 400+ seconds down to under 160.
Anybody out there want to try a simple science experiment? If not, maybe the folks who've sprayed this successfully can convince me to give it a try :)
Thanks in advance for the help, everyone!
Edit: After reading the very useful advice below, I got a good result by:
1. Thinning the BM Advance by 10% with tap water and mixing it thoroughly - this cut the viscosity from 400 down to 160 or so.
2. Using a 2mm needle
3. Mixing the thinned paint (I made a 300 mL batch) for 2 minutes with a 1 gallon helix paint mixer from Home Depot:
Rectangle Tints and shades Parallel Font Magenta
Surprisingly, the last step was absolutely critical. I'd tried the exact same mix of paint earlier and hand-stirred it for a minute instead of mixing with the mixer above. The paint did not flow well out of the gun and I got a very rough finish. I didn't measure the viscosity of the drill-stirred mix but it definitely seemed to flow better.
Now it's time to spray some cabinets. Thanks, everyone, for the advice!
1 - 20 of 37 Posts
I work for a paint company I personally wouldn't thin the product more than 20% . More with start to break down the paint and could cause it to fail.
I attended a seminar given by an Earlex rep and he said that you would thin paint somewhere between 10-15%
You will be quite amazed at how quickly the flow increases with the addition of a little thinner. That said, water borne finishes cannot be thinned on a wim…be sure to check what the max is that BM suggests and don't exceed that. To do so may impact the chemistry of the paint.
Thanks guys. I've seen the BM recommendation to thin "slightly" if needed for airless sprayers. I'm wondering if 10% will get me anywhere close to the needed viscosity - Fred's comment about how fast things start to thin out has me encouraged, though.
Fred, do you know how the chemistry is affected? Is it sheen, color, bonding ability, or "all of the above"?
Fred, I just sprayed some water based poly thru my 5500 today. I asked earlextech about how much to thin and he said about 10%. I doubt I went that far and it worked perfectly. I'd be interested to know how yours works out.
I don't know how the water-based poly compares to the BM Advance on viscosity…how long does it take to drain through the magic viscosity cup before it's thinned?
2
Wood Beige Shade Flooring Tints and shades
Just finished a project with latex paint. You need to thin until it works. I have both the earlex 5000 and Fuji 4 stage.
I thin the paint with 10 percent water.
double the leveling stuff frestol (sp) recommended
than waterbase poly until I get it to where I want it.
thin down to 30 sec and see how you like it. My project I just did came out perfect. I will try to edit this in a few with a picture.
I have been told that stiring with a drill helps but have yet to try it.
at 160sec your earlex will not work. try a small cup of my meothod
This may help…. I have sprayed BM Advance and SW pro Classic….with excellent results in my Earlex 6900
This is what I do….I start with 32 oz of paint in a separate container add 1 viscosity cup( 4 oz )of water….2 oz of Flotrol
( Some BM paints you have to use BM's paint conditioner but not Advance)....mix with a low speed drill for 2 minutes….per Earlextech advice…..then filter into another container…..then mix with a stir stick….Here is the important part…....When the paint quits running off the stick in a stream….within 1 or two seconds….it should drip like a rain drop….perfect circular beads….if not add 1/2 to 1 oz more water and mix with the stick until you get the rain drops at the end…..this method ended all the mystery about thinning for me and my Earlex 6900
FWIW…BM Advance flowed well with about 5 oz of water…..And SW proclassic worked very well with 6 oz of water
Both got 2 oz of Flotrol
Hope this helps
RocketDogs
ducky911, great finish! thanks for the info.
RocketDogs, that's really helpful - I really appreciate the detailed description!
If you want cheap paint to practice with Sherwin Williams has sample quarts for around $7.00 a quart…..same thickness as regular paint….but it will fade over time so its not really paint….plus you get to keep the handy quart container….her is a link
http://www.sherwin-williams.com/homeowners/products/catalog/color_to_go/
RocketDogs
Thanks, RocketDogs.
I wanted to post a follow-up. After the advice above I thinned the BM Advance 10% (1 part water to 10 parts paint) and re-measured. The viscosity was just a hair over 160 sec - down from over 400 sec without thinning.
When I sprayed the stuff I got OK atomization - not awesome, not horrible - but then I realized during cleanup that I also had my 2mm needle mounted. That's probably the culprit behind the mediocre atomizing so I'll try the next coat with a 1.5mm needle and dial back the paint flow a bit.
Once I get things tuned in I'll post some pics. Thanks, all.
Well, now I'm confused. Tonight I tried spraying the same 10% thinned BM advance with a 1.5mm tip, thinking the 2mm might have been too big for complete atomization.
I adjusted the spray with the 1.5 and was still getting so-so atomization so I tried the smallest paint flow I could…low enough that it took holding the gun stationary 4-5 seconds to even coat the spray pattern on the test sheet. Even so, I still got some splatter. I also opened up and tried some higher flows - all the way up to "splatter city". No matter what I tried, nothing gave me good results. So, I picked the best compromise between splatter & paint flow and tried a coat of paint. I got similar results to my first spray with the 2mm tip but it took over twice as long due to the lower paint flow. So much for better atomization (at least with the BM advance) with the smaller needle.
So, my only conclusion is that the paint is STILL too thick. Could it something else I'm doing (or not doing)? Do I thin the BM Advance more than 10% (i.e. faster than 160 sec), go back to the 2mm needle and try again, buy a better gun, or go back to my Purdy brush (which is giving me a smoother finish than the gun so far)?
Thanks guys.
I think I finally dialed in a good combination. I went back to the 2mm needle and the 10%-thinned BM Advance but this time I used a drill to stir it for 2 minutes instead of hand-stirring for 1 minute. It laid down with much less splatter and, while it's still not a piano-grade finish, it was nice and smooth. Certainly good enough for my purposes.
I'd heard that's the case with stirring these paints - something about the long molecules of paint lining up like spaghetti in a whirlpool when you stir well - which makes it easier to get out of the gun when you spray.
Whew, that was tedious - but a good lesson learned…
Rocketdogs was exactly right and you're exactly right about the molecules. In all other finishes the molecules are dots already (designed to be sprayed). It's easy to atomize dots into smaller dots. In "latex or waterborne paints" the molecules are spagetti shaped (not desgned to be sprayed) and stirring with a stick does not break them up. Using the paddle mixer in a drill does.
Some people get better results with different needles. One thing to keep in mind is that we are all different and our expectations are different. There is no "one answer fits all" final answer. Sometimes it takes some experimentation to find what works for you and I'm glad you did.
Exactly. You and Rocketdogs seem to have the right approach. Now I might see if the Flotrol helps the coat flow out even more smoothly. I was afraid to tinker too much with the chemistry of the paint.
Dave
Glad you are getting better results….Also play with the distance from the object you are spraying….sometimes 4 inches will give you less splatter…..remember a dollar bill is a hair over 6 inches….use that as your guide….I think I am usually spraying less than 6 inches more like 4 or 5…..also the Flotrol helps …..I have gone up to 4 oz. for 32 oz. of SW pro Classic….using a 1.5 needle….with great results…..I am almost done with my kitchen spraying over 40 doors and drawers….2 thin coats SW primer front and back….2 coats SW Pro Classic front and back….and 2 coats General Finish High Performance water based poly on the backs then 4 coats on the front…..a lot more work than I realized I was getting into….But it is coming out beautiful…..far beyond my expectations….couldn't be happier….Earlextech (Sam)....is very well versed about this stuff….he wouldn't send you in the wrong direction
Also…..when spraying ….always check for build up on the needle tip….clean it with your fingernail or an old toothbrush….sometime it can build up quick….when the gun get a little warm
Hope this helps
RocketDogs
Dave I have the 6900 and something I have tried that believe it or not works very well is to use winter grade auto washer fluid, to thin the paint. I picked this up from a youtube video and although I couldn't believe it, I tried it and it really works. The fluid I use is from Walmart and it's blue but it doesn't seem to affect the final color at all, even white. There is methanol in the fluid and it really helps make the paint flow. I have sprayed SW, BM and Valspar paint with excellent results and never needed to thin but 10%, or less. I also stir the mix with an electric drill mixer and that helps.
I have also had better results with non-alkyd type latex paint. If you have some leftover paint from a project, give it a try and see if it works for you.
1 - 20 of 37 Posts
