I guess I will have to join in on this, I built my bench two years ago to the size that would best fit in my small 220sqft shop. It measures 63" by 20" and is 34" in height. the top is two layers of 3/4" OSB glued together then sandwiched between two layers of 1" MDF, which is then edged with 2" cherry to dress it up a bit. the base is straight up 4×4 and 2×4 construction with pegged half lap joints. there are 1 1/2" dowels in tops of the legs which slide into mortises in the bottom of the top to hold it in place. I wanted it to be removable in case it needed to be rehabed. the edge banding of two inch cherry is held together with condor tails on the corners so if I ever need to replace the MDF top I can remove the top and the edging and just slip in a new piece of MDF.
I have a Wilton end vise and a shop made leg vise. I bore dog holes in the side rail on the leg vise side so that I can stick a long dog in there to support long boards as they are being jointed. So far it has been all I have needed it to be, the top is holding up excellently, would like to add some support to the footprint as I can get it rocking a little if I am really bearing down with the planes. otherwise its works great.. here are a couple pics..
P.S. don't mind the mess, I am to busy building to worry about sweeping up the shavings under the bench.. that's what I tell my wife every time she comes in a says something about it.. just the sign of a busy furniture maker at work..
