1 - 20 of 216 Posts
Discussion Starter · #1 ·
Escher Vibe
Following on from yesterday's 'Trip to the Wood Shop' let me show you where the Escher vibe has taken me.
Well to this
A beautifully simple, yet impossible pattern. Look at it long enough and you'll see why the three dimensional world it represents is impossible. Even if you accept that its possible as a pattern in two dimensions ( you have to you're looking at it) then the long slim rods and the triangles are possible to make in wood but the cubes that the rods go into would be a nightmare to cut out, even with a scroll saw.
What we need to do is reduce the pattern into repeatable, manageable pieces. You'll have to trust me on the first stage (have I ever lied to you?)
OK thats gone over to the right of the screen but you can see what I've done. Simply by extending the lines at the ends of the long rods the pattern is now reduced to only rhomboids and triangles. Both possible to cut in wood. All I have to do to maintain the illusion of the sides of the cubes being a single entity is to keep the grain direction consistant and minimise the visibility of the joins by accurate cutting. The thin red rectangle is the area of the pattern I intend to make in wood.
These are the pieces the pattern is reduced to
Materials will be Ebony, Sycamore and Purpleheart. I don't know if you can get your head around this at this stage. I apologise in advance if you can't. I know some of my patterns screw with other LJ's minds. Suffice it to say that Escher's screw with mine. I think that with 82 of the top shapes and 27 triangles (or parts thereof) I will acheive this.
It should become more apparent what is happening :
1. Later when I have cut the wood shapes.
2. If the medication doesn't wear off.
I'll continue to post the pictures of what I'm doing, as I do it and even if you can't get it at the time I'm sure that when (or should I say IF) the pattern starts emerging you'll be able to look back and see where my train of thought was going. All I can say is 'Good Luck', we are both going to need it and trust me. I believe the impossible is possible and I hope to show it to you. If I don't suceed at least I will have had a bloody good try and you can all have a good laugh on me. I suspect that some of you are already thinking 'He's really lost the plot this time'. We shall see…...........
Escher Vibe
Well to this
yikes. I had to cut one out to believe it would work. It does…
Escher Vibe
Well to this
Wow I can't wait to see a real one.
Get to work!
Escher Vibe
Well to this
What a great project this will be! I often thought of doing the Eschler flying geese in some sort of scroll saw pattern, as it is much easier to cut curves than precision straight lines on the scroll saw. I can't wait to see this progress!
Keep up the medication!!!!
Sheila
PS - How thick is the wood going to be? What are you going to cut it on?
Escher Vibe
Well to this
Hey Martyn
I thought the last board you did was complicated. Looking forward to seeing this one.
Thanks for this and the other blogs you've done.
Escher Vibe
Well to this
And I thought I was on strong medication!! I can see it, but it still looks impossible to me.
Good luck, Martyn.
Escher Vibe
Well to this
O.K. Martyn….......... now youv'e gone and lost your marbles!!! completely gone bannanas!!! LOL
I love Escher's work and wish you all the luck in the world. If anyone can do this, you can!
This is a great design….....
Looking forward to seeing the process and the final piece.
Discussion Starter · #8 ·
Escher Vibe
Well to this
Shiela, its going to be a box top pattern approx. 200×130 x 8mm in size. As with the 'Little Bess Challenge' blog I'm using a standard 10" table saw and a disc sander. In addition this time I'll be using my drum sander to precision thickness components.
Escher Vibe
Well to this
If you say so, Martyn… I am complete with faith in you… :cool:
Escher Vibe
Well to this
Hey Martyn, I found your marbles! They are way over here. Just in case you are looking for them.
Steve
Escher Vibe
Well to this
I'll have what he's having! WOW!
Escher Vibe
Well to this
this needs a complete how to martyn cant wait to see this one
Escher Vibe
Well to this
Now I understand the "impossible." An optical illusion that demonstrates a structure that can't exist into a structure that does.
I think I need a case of those XXXX beers of Larry's….
Looking forward to this one.
David
Escher Vibe
Well to this
WHOA!!!!!!!!!! Cant wait to see this one
Escher Vibe
Well to this
wow….a few pints from now that will probably look do-able….right now it looks scary. :)
Escher Vibe
Well to this
From The Matrix
Martyn: Do not try and bend the spoon. That's impossible. Instead… only try to realize the truth.
Neo: What truth?
Martyn: There is no spoon.
Neo: There is no spoon?
Martyn: Then you'll see, that it is not the spoon that bends, it is only yourself.
Escher Vibe
Well to this
Here's one to think about:
Escher Vibe
Well to this
this looks like to be an impossiple mission to me
are you sure you have taken your medic lately…..lol
I know I´m going down and take a big glass of single malt right now
cheers Martyn
Dennis
Escher Vibe
Well to this
YES! I was strongly hoping you were going Escher when you called it the impossible!
Discussion Starter · #20 ·
Escher Vibe
Well to this
Yes guys but I've got to be up for work at six tomorrow morning. I have to wait 'til tomorrow night for beer!
Hairy, yes but only more so.
Scott, LMAO. Loved The Matrix.
Steve, they really do roll once they get going, don't they.
1 - 20 of 216 Posts
