1 - 5 of 5 Posts
Evening all. I'm part way through my table build and am gearing up to make the top. Is there any hard and fast rules about how wide each board should be. I was going to go with 6.5" wide boards. But when I bought my material a lot of it is 8". With machining , cut it down to 7.5. Any problems with the boards that wide? They will be running side ways rather than length ways as I am put table expansions in it? I just don't like the waste.
Thank you.
Mark, I have never done a table like yours, but IMO there shouldn't be any problem with 7.5" that would be any different than using 6.5" other than possibly a slightly increased likelihood of cupping. However, if your stock is well dried and finished the same on both sides, I doubt that that will ever be an issue for you. FWIW
1 - 5 of 5 Posts
