Storing a Dewalt dw734 planer on its side?
2252 Views 8 Replies 6 Participants Last post by  LeeRoyMan
4
I have a Dewalt dw734 planer that I want to put into some sort of 'hideaway' storage.
I have seen a lot of examples of flip top cabinets and have not seen any reported issues caused by having the machine hang upside down, so no apparent problem there.
What I would like to do however is store the planer on its side. The reason for this is I want to make it fit inside of an existing cabinet and if I do the flip top I would need more space than the cabinet allows (no open front or back to allow the machine to swing by).
The specific plan I currently have is something similar to a sewing machine table where the sewing machine folds down into it. Something like the following picture, sorry I couldn't find any pictures where you could see the specifics of how it works.
Sewing machine feet Sewing machine Sewing machine needle Sewing Home appliance
For those of you who are not familiar, the board just in front of the machine in the picture acts as a support when in this configuration and hinges toward the front giving room for the machine to fold down. The machine is hinged to the rear of the cabinet so it folds forward into the table and is facing the ground when it settles.
In my case I want to fold the planer so it is facing with the 'left' side down. The machine itself would be bolted to a platform that would then be hinged to the cabinet. The planer will not touch the cabinet except through that platform.
Tire Vehicle Automotive lighting Wheel Gas
Picture sideways on purpose :)
Would this cause issues with the alignment of the machine over time since the force of gravity is perpendicular to 'normal'? throwing the planer out of square, etc, Any other issues you can foresee?
I feel that I have a pretty good handle on the strength required in the cabinet and hinged components, I am mainly concerned with the effect on the machine itself.
Thanks
1 - 9 of 9 Posts
I cannot see any issues with this. To me it is no different than hanging it upside-down on a flip-top stand.
There is no oil reservoir in that planer so sure it can be stored any way you want.
Thank you for the feedback on the idea. Makes me feel a bit better about doing it.
i see nothing wrong with this GR8 idea will not harm the machine 1 bit :<))
DO IT
FOXBC
What exactly is the source of your concern? It sounds like perhaps you are thinking the machine will not be stable while in use?
I am quite confident that the design I have in mind will be just as stable as the many flip top carts that others have. The moving platform sort of 'locks' in place when raised, no side to side or downward movement possible at all and upward movement would be virtually impossible due to the design of the mechanism, weight of the machine and the manner in which it is used.
Certainly more stable than just having it sitting on a bench like I do today.
If you are thinking of something else, I would love to hear about it so I can make sure I am looking at all angles.
Thank you for the feedback.
gr8hunter, thank you for your response. I may not get to this for a couple of months, but I am certainly looking forward to doing it.
I've got 2 of them in the shop.
They get used on their sides and are stored on their sides. I don't think they've ever been stored or run in the upright position.
No problems at all.
2
I ve got 2 of them in the shop.
They get used on their sides and are stored on their sides. I don t think they ve ever been stored or run in the upright position.
No problems at all.
- Tony_S
I converted my table saw into a vertical panel saw.
Fixture Gas Machine Composite material Audio equipment
1 - 9 of 9 Posts
