1 - 17 of 17 Posts
I purchased a Stanley 271, well I thought it was, off eBay. It was obviously dirty and kind of "yellowish" looking in the two photos. Which some older nickel plated dirty Stanley tools get that yellow tinge to them.
Well, it came today and it's bronze, not nickel plated cast iron. And the markings are very vague and hard to make out (like a copy would be). You can just barely make out the 271 and the USA… You can tell that the Stanley logo is there but only by looking at a photo of a "real" 271. The "screws" are slotted head screws and were extremely difficult to get out. Not thumb screws as they should be. There were (2) 1/4" blades and one is wore to nothing. I believe the dirt is really casting sand. It's on there like concrete (like casting sand would be). I don't even think it's all that old.
I'm not a collector, I only want it to use it. I didn't give a lot for it (cheaper than a St. James Bay copy, but not much) but it was advertised as a Stanley 271. Should I keep it or file a case with eBay and get my money back. I wish I'd only given about half of what I gave for it… I am, as a good eBay'er, talking with the seller.
Dan Reynolds
Central IL
does it function? I am all about results, and i do have a plane that is a forgery, but i find it performs better than then real thing. Plus, not being genuine, there is no worries about destroying it's value by modifying the tool to suit your needs. So adding better thumbscrews or buying a fresh blade does not detract from it's collect-ability.
Casting bronze is not cheap, so i have to believe whomever made it, it was not to deceive, but to improve upon.
so, try it, see if it works.
Sounds like a recondition job. I'd try to get the money back if it's a dud when you clean it an use it. I try to stay with only original Stanley. I have them from 4 to 9 in excellent shape. You can get a vintage 1940's plane at antique stores. Cost from $20 to $40 but you have to clean and sharpen first.
Discussion Starter · #5 ·
The seller did contact me and offered to refund my money if I returned it. I decided against it.
I already have a thumbscrew made and I sanded down the sole. It was flat and square with the cutter. He told me it was old - that his father-in-law's grandfather used it. Of course that doesn't stop it from being counterfeit but I want it to use not collect. So, that's why I decided to keep it. And now it has kind of a history.
I'm not a hand tool fanatic but I want to start using hand tools. I've been collecting stuff for years and years. I have an old #5 that needs rebuilt, a #8 jointer with corrugated sole that needs cleaned up good.
I've recently eBay'd a pretty decent #45, #75.
I bought a Chinese spokeshave and once you flatten the sole (and get the paint off the sole) it seems to be pretty darn good. I've also bought all the HF planes. I know they're not great but they'll be good enough for me most likely. And if the #4 copy doesn't work great I'll turn it into a scrub plane.
I just want to make a few small things, a tool box or two, some keepsakes and work with my hands a little.
Thanks for the comments. I've been lurking here for a couple of years now.
Years ago, hardware stores used Stanley planes slightly altered as their 'in store' brand. This is likely one of those.
For further research take some photos and ask DonW about it. He's our resident plane expert.
I've seen a lot of cast router planes, many that looked just like a Stanley (it's possible Stanley stole the design from somebody else as well) but I've never seen one with a Stanley logo.
Would you post some pictures? I'd like to see it.
I've never really figured out how one goes about finding out if a plane is a prototype, but I see a lot of them listed in antique books.
Don thanks for asking! I've seen your posts on other planes. I have a #45 that I just love. It's a weird model too. An early 1900's in between model. But I won't change the thread here on that.
I honestly don't think the guy knew it wasn't real. I'll warn you - you have to use your imagination to "see" the logo, 271, Made In, and USA. But they're there. I think someone just decided to make some copies.
I cleaned it up some today. And made the thumbscrew fit. I plan to put a stop collar on the bit to control the depth. It's kind a rough looking but like I said the cutter is square to the base. And the base if pretty flat so what else do I need. I'm planning on making me a larger router out of wood ($5 router plane plans).
Wood Grey Font Gas Road surface
Guitar accessory Musical instrument Road surface Wood Asphalt
Road surface Wood Font Asphalt Jewellery
You can file an eBay claim; "Item significantly not as advertised."
You have 45 days from receipt to file this.
Write factual info, do not rant or call names.
You should be refunded in full and not penalized for shipping expense either way.
that is one ugly copy, looks like somebody's garage foundry work.
I'd return it without hesitation. You want a #271, get a #271, not that glob. Kinda harsh, I release, but don't settle. You were mislead, and that fact shouldn't be allowed to stand. My .02
Discussion Starter · #11 ·
that is one ugly copy, looks like somebody s garage foundry work.
- poopiekat
I agree but I've kind of gotten attached to it. It works fine so far. It's just a hunk of bronze and it's square so I think I'll keep it. It sure has a story anyway. Plus, it sort of matches me and my abilities! :)
that looks like something I'd make ;-)
It's different and unique, and definitely not a prototype.
I can't believe somebody sold it as a Stanley!
I doubt it's a forgery strictly speaking.
Guys who worked in pattern shops would often make
planes from Stanley castings. That may be why
it's bronze.
Personally I think it's kind of cool to get one of
those craftsman made copies.
They are usually just a little smaller than the
originals owing to shrinkage. The originals
shrunk too but they were made from larger
wood patterns.
I agree with Loren. I think because of it's simplicity that the #271 is the most directly copied of the Stanley planes. Instead of using a wooden pattern for the mold the founder/copier/patternmaker just used an original #271. There is always some shrinkage of the casting from whatever pattern is used and bronze/brass shrinks at a different % than cast iron. If you get a chance to hold yours up to an original #271 I think that you will see/feel a few percentages difference in size.
What to do about it is strictly your choice.
Banned
Loren has the most probable explanation
In my years of tool collecting I have encountered many patternmaker copies of mass-manufactured tools.
The most common examples being No. 80 scrapers and 71 and 71 1/2 routers.
Here is an all aluminum No. 80-never made by Stanley.
Hand tool Tool Wood Household hardware Metalworking hand tool
Wood Rectangle Automotive exterior Hardwood Natural material
Discussion Starter · #17 ·
I doubt it s a forgery strictly speaking.
Yeah, Loren I didn't mean a forgery - I called it counterfeit, but it copy is probably correct. I doubt whomever made copies to sell or anything.
It is neat in a ugly sort of way. And it works. I've been watching the Paul Seller's series on his workbench project, which I seriously want to make, and he makes a "poor many's router" by stuffing a chisel through a board!
Thanks guys for the warm welcome. This is my first real posting. I do have to admit to being a little intimidated-you guys are good! I checked out Don W's handplane site. Holy Cow!
1 - 17 of 17 Posts
