1 - 12 of 12 Posts
Hello all. I'm working on trying to finish up my tool cabinet. Have fun into a snag.
It's all glued together, most of it is square. Except one spot.
I have two spaces on the top half. 15 inches to the left of the middle divider is shelves with a door, to the right is a space for the planes.
Upon installing the door i noticed a gap at the top corner/side. I figured it wasn't possible to get it in square. I put a clamp on it in a wracked manner and it pulled it square. I figured removing the back cleats and re-installing them with it racked would hold it in square. Not true…
What could i do to keep it square?
Brown Wood Beige Wood stain Plank
Brown Table Wood Desk Flooring
Wood Flooring Electricity Tints and shades Gas
Premium Member
Not exactly sure of the problem. Typically as long as measurements are correct and the sides and shelves are square, it is the back that pulls everything into square. Is the back on permanently or can you remove it and resquare. Attach one side all the way along it and then measure for square. Use a clamp to pull it square and then attach all the way around.
Discussion Starter · #4 ·
I dont understand either lol.
All dividers and dados etc were cut at the same time. I know all measurements are the same.
There is no back, as i needed room for a cleat. I have a 10" wide cleat. Refer to the bottom picture.
The white piece of wood is the back i guess? its the cleat and its screwed in. The bottom piece is a back for the bottm portion.
As one half of the cabinet is plane till, i didnt need a back so thats why there isn't a full back piece.
The cabinet is square except the top bit. Dont know why. If i use a clamp at the top and put it at an angle and clamp it it goes square.
Heres a sketchup image of the back as it sits. The areas in "yellow" are the back panels. The top piece is the cleat for hanging. The half section below that is an additional piece to affix the back piece for that side of the cabinet. The left side didn't need one as there is a ramp for planes so it wasn't "visually" necessary.
The bottom section of the cabinet has a full back.
Is it because the top section doesn't have a full back? Would making a full back section help keep it square?
Rectangle Wood Building House Screenshot
you can't have all measurements the same and one corner out of square. If you clamped and racked it square, 2 corners were out.
A picture overall would help I think,
Discussion Starter · #10 ·
Don- Basically what is happening is the top half of the cabinet, is leaning to the right. So it's "racked" to the right. But offsetting the clamp heads, it pulls them to the left thus making it square.
Which leads me to believe Fires aforementioned comment of something being bowed. Then again, I am by no means a "Cabinet maker" As this is the first cabinet I've built.
Got it. I agree with Bill. Put a back on it. I usually datto it in. 1/4" ply would probably work. For hanging add a stiffener inside.
If can't or don't want a back, some corner brackets would work.
Another option would be a face frame.
1 - 12 of 12 Posts
