1 - 15 of 15 Posts
Hey guys.
Been trying to figure out the best way to use my router for cutting shapes while using guide bushings.
I made a simple rectangular template that will guide the router and I wanted to know if I should grab a straight bit or a spiral bit. If the latter, I know they have different types (up and down?).
I have a Makita palm router and I want to cut out handles in board stock.
Thanks.
Either will work but the spiral bits will give a cleaner cut. Upcut or downcut? I use both depending on whether the router is in the table or hand held. My goal is for the bit to pull chips out of the cut.
Will you be plunging the bit down into the wood or going into it from the side? If plunging, get a spiral bit. You have to make a ramped cut with a straight bit when going into the wood.
Discussion Starter · #5 ·
Thanks very much guys.
Basically I'm going to be doing both plunge and side cuts. I've found that with the straight bits I've had, they seem to struggle a little. I might be trying to take too much stock at one time or I'm just buying cruddy bits.
With the spiral bit, do I have to make gradual cuts or is it possible to cut, say 1/2" ply in one pass?
You say a "Palm" router, if which you mean one of the smaller "compact" routers that only runs a 1/4" shank bit I would really hesitate to be cutting 1/2" ply in a single pass. It's always easier to take two or three passes than get agressive and then spend 2 to 3 times as much time fixing a "Boo-Boo", plus the one time I snapped a 1/4" bit I nearly wet my pants
Discussion Starter · #14 ·
Hey guys… update.
I got that WHITESIDE #RD2100 bit.
This is my first go round with a spiral bit so it might just be their nature but wow, what an amazing tool. I'm using my HF 1/4" guide bushing with it and this thing cuts like a hot knife through butter. I created a template for some long cutouts that are about 1" in width and used it on 3/8" birch ply. Started with a pilot hole and made the first cuts with a couple of passes. Then, tried it with one pass with my router at a speed of about 4 of 6 on the dial. No problem at all. Beautiful, clean cuts.
I should have done this earlier.
Thanks again for your guidance everyone.
1 - 15 of 15 Posts
