Small Projects
59930 Views 205 Replies 59 Participants Last post by  joebob1611
Vape pen stand
As an amputee I have intense phantom pain that only a relief vape can stop. If you lay them on their side all the juice pools on the side instead of at the base of the wick. The vape pens themselves have a small, tippy, footprint that easily falls over even if your hand is steady enough to balance it in the first place.
I took a length of 2×2 select pine and planed the mill marks off it. Then some drill press work and I have a pen stand. I chamfered all the holes and waxed it with Johnson's paste floor wax.
Wood Wood stain Hardwood Gas Varnish
I try to do a little project every day or so. Being 'the hump with the stump and the pump' and retired means I have to keep busy even if the project is trivial.
M
161 - 180 of 206 Posts
Perfect Mitered Cube Crystal Display Case
SWMBO is a Yankees fan and for Valentines day I got her a Waterford crystal baseball engraved with the Yankees logo. It's about 2-1/2" dia and leaded crystal.
Tableware Dishware Plate Serveware Porcelain
Waterford Crystal Baseball.
There was a thread here recently about how to build a cubical bin. The OP already had a joinery method in mind but I suggested a mitered panel box. This box is made from 12 identical pieces all cut on the TS.
Each piece needs to have a 3/32" dado in two sides for the lexan panel inserts. Both ends of each piece are double mitered and assemble into a perfect cube.
I started with a piece of 1×6 about 2' long. I rIpped three 3/4" square pieces. Each piece is then dado'd 1/4" deep 7/16" in from the inside face. Once you have cut the first dado you must flip the piece end for end for the 2nd cut. (DAMHIKT)
Once the dados have been cut the ends of the three pieces are squared off and then cut into four equal pieces creating a total of twelve 3/4" square x 6" long blocks.
Setting my miter gauge to 45° and adjusting the stop block until the back corner just touches the kerf on my ZCI. Each end of each piece is double mitered. Each cut should have the dado facing the blade. Once both miters have been made to all 12 pieces, the miter stop is reset so the corner of the piece again is just over the ZCI again and all the other ends are double mitered. Again be sure to feed the dado face towards the blade.
You should have 12 identical pieces double mitered and pointy on both ends. Sand to 220.
Now finishing the box presents a challenge to do so without getting finish on the lexan panels. Prefinishing sounds like a good idea, but final sanding would ruin it.
Glue up has to be done in stages. Make sure you have a bunch of lexan scraps to hold the pieces in alignment while gluing. A small brush is needed to spread the glue to 100% coverage without getting any glue in the dados.
Use an assembly corner take any three pieces, and keeping the dados to the inside form a corner. Use pieces of lexan to hold the pieces in place while the glue dries. Make a total of three, 3 piece corners.
Glue two of the remaining pieces into a 90°. The 12th piece is set aside for now.
While the glue is drying this is a good time to cut the six lexan panels. All are cut identical squares about 1" smaller than the length of the sides. The saw may leave a burr on the edges making the lexan hard to insert. I eased the edges with 220 grit on the ROS.
Once the glue has dried on all three corners and the 90° piece, it's time to start assembling. Take two of the three piece corners and insert a piece of lexan prior to gluing. Once these pieces have set two more lexan pieces are inserted and the 3rd corner added.
The 90° piece is glued in with the lexan in place. Both remaining lexan pieces should be inserted until the glue sets.
The 12th piece is ripped on the dado line. Save both pieces. The thick piece is glued in place holding the back in place. Make sthat the top of this piece is glued even or just below the side dados.
The lexan piece for the top should have two adjacent corners rounded to about a 3/32" radius (not critical, round by eye) and the edges eased to make it easier to insert and slide.
Leaving the top piece of lexan sticking out slightly as a spacer, use the remaining cutoff from the 12th piece and glue it just above the sliding lexan to complete the box.
Once the glue is fully set the outside was sanded to 220 on the ROS.
I had some mirrored lexan that was cut to fit inside the sides. One piece was used on the bottom and the other on the back. The mirrored lexan is attached to the sides with double stick tape.
After cleaning the sawdust out the piece now appears as:
Brown Wood Display case Glass Rectangle
Mirror reflection adds depth.
Wood Rectangle Shelving Hardwood Glass
3/4 view.
Plan is to add LED lighting and a stand to better show off the crystal.
SWMBO has previously criticized my finishing skills so I told her she could apply whatever finish she wanted.
Update 10SEP21:
Here is pic with lighting puck. Bar effect is because of strobe, not visible to naked eye.
Water Gas Art Electric blue Glass
Color change LED puck gives remote control lighting.
That turned out great. Only issue I can see is the logo on that crystal. ;)
3/4 view.
Update 10SEP21:
Grand slam Mark. The miters came out great!
A lot of planning in this one.
I'm working on a project with a lexan panel and was thinking of pre-finishing the frame but I'm know taping it. I did press the tape in good. I hope it doesn't bleed through.
I'm sure your better half will do a great job and she'll also get to contribute to your fine project..
PS great photos.
3/4 view.
Update 10SEP21:
Nice display Mark. That many compound miters make most Men a little weak in the knees.
I think lit it would be really really cool to see.
3/4 view.
Update 10SEP21:
Thanks! It was an easy, fun project..
The miters were actually all cut with one setup just using the miter gauge with a stop. They're NOT compound, just two identical passes with the blade straight up. It's easier than it looks!
The key is to finish the material BEFORE you make the first cut.
  1. Fully finish squared stock
  2. Rip the grooves, remembering to flip ends
  3. Crosscut to length- not critical as long as all are "long enough", 12 pcs
  4. set miter gauge to dead on 45°
  5. adjust stop to length of shortest
  6. cut all 4 miters on SLOT SIDE of each piece
  7. glue 3 piece corners, one 2 piece L, leave last piece loose
  8. cut 4 clear & 2 mirror lexan squares 1/16" under sized vs measured dim
  9. glue assemblies from previous step, inserting lexan as you go.
  10. rip last piece at dado
  11. Glue last piece in using lexan as spacer
The light is a remote control waterproof color changing LED module modified to run off a USB charger.
Automotive lighting Rectangle Circle Font Pattern
$10 at SuperbrightLEDs
3/4 view.
Update 10SEP21:
Looks amazing Mark, You make it sound simple haha.
A superb piece that should get you sliding into home plate.
Gary
3/4 view.
Update 10SEP21:
TYVM!
Really, it is easier than it looks. Give it a shot the next time you have some square stock
3/4 view.
Update 10SEP21:
Lacewood Box with Brazilian Rosewood Tray
SWMBO had a friend visiting us in Fla from TGWN (The Great White North) and I made this box.
Wood Rectangle Table Audio equipment Wood stain
SWMBO put the final finish on it.
Table Wood Rectangle Outdoor furniture Hardwood
Ready to ship.
Brown Product Rectangle Wood Musical instrument
Waiting on final finished coat of poly.
The box is from a 15/16" x 5" x 18" piece of S2S lace wood. The tray is from a 13/16" x 2" x 24" piece of Brazilian rosewood with a big worm trail about 6" from one end.
There were only two pieces of scrap from the lace wood, both from trimming the bottom to length & width. Beyond those two, small, cutoffs, all the waste from the lace wood was dust.
Brown Rectangle Product Wood Material property
Lacewood box with Brazilian rosewood tray ready for finish
Continue reading for build details:
Starting with the above, thinner stock, was called for in the actual project. This is to maximize yield and to have the box and tray read "lighter". This is essentially a zero waste project sized to fit the avaliable single piece of lumber with as close to 100% utilization as possible. As my father would say, "You can put the scrap in your eye!"
The finished box is 6-3/8" long x 4-5/8" high x 5-1/8" wide with the tray 5-13/16" x 4-1/2" x 1-7/8"
Both pieces were resawn and then lightly planed to even out the odd 1/32". Actual box thickness wasn't critical as long as everything was even. The lace wood was split down the center and yielded two ~3/8" pieces. The rosewood was cut from both faces at 9/32" and with the TK blade I have a 1/16" piece of veneer left over. The rosewood was planed to .250".
The box was built first and then the tray to fit. The tray is spaced off the bottom by four scraps of rosewood. I put the worm track to the inside on one of the spacers so not even that went to scrap.
Since the box side thickness and width isn't specified beyond "start with even thickness and width" cutting was done "self referentially".
I started by squaring one end of both slabs. Then I set the cross cut stop to the width of the board. I just put the random width piece against the blade and moved the miter stop over. This is the maximum width of the end.
The top, at maximum width, makes the box one side thickness wider than the lid. The ends are two sides thinner than the box, or one thickness thinner than the width of the top. Since we just set the miter stop to the max width of the board (the top), we simply use one of the pieces as a spacer next to the miter stop. This automatically subtracts the correct side thickness from the crosscut no matter what the thickness actually is! One end is cut from each slab to maximize yield.
Once the ends have been cut, the remaining stock is cut into four even lengths, two from each slab. There should be little, if any, cutoffs.
Of the four equal slabs select the best piece as the top, the worst the bottom, and the last two are the sides. Select and mark best side of all pieces.
The bottom is trimmed the same way as the ends but with both ends as self referential spacers.
The ends are then used to set the rip fence to the bottom width. The bottom has to be exactly the width of the ends.
The pieces are dry fit at this point just as a sanity check. The lid is both longer and wider than the dry fit. Tweak basics as needed.
Sliding Lid:
The trick to getting the top essentially flush with the sides, and cutting effectively, is to correctly sequence the operations, as the top and sides interact. First, rabbet both sides of and one end of the lid with a square profile half the material thickness. The rabbet should be a few thou (~0.005") deeper than half. Not too much, or the bottom of the dado will make the sides too thin.
Without adjusting the blade depth, use the lid to set the dado spacing for the top of the sides. Set the rip fence to match the rabbet depth on the lid. It's easy to set if you have a ZCI. Put the top side of the lid against the rip fence. Move the fence over until the edge of the bottom of the rabbet aligns with the fence side of the edge of the kerf in the ZCI.
Run two sides and one end with the bad (inside) face down.
Check to see if the lid slides in the side dados. If needed, widen the two sides first & retest. If the lid slides, DO NOT widen the end piece rabbet. The end of the lid should NOT want to go into the end dado. if there is 1/16" or more interference between the end of the lid and the dado in the end piece, widen the end dado of the interference is about 1/32". The front lip of the lid will be sanded to fit after gluing, during final fitment.
Once the dado width is correct, raise the blade and rip thru cut the remaining end. This insures the top of the end doesn't intrude into the dado, blocking the lid. Save the cutoff as it will be attached to the lid in a later step.
Box Assembly:
Time for another dry fit & tweak.
Once the dry fit is good, sand the inside faces to 220.
My corner assembly jig is my locked TS fence with one of those Rockler plastic "assembly corners" and a 6" Jorgensen wood clamp. The huge surface area of the block clamp locks and releases with a quarter-turn making setup and teardown a snap. Additionally both the corner and fence can be moved away from a freshly glued piece without disturbing it.
I assemble in this order:
  1. left side along side assembly block.
  2. far end (tall with dado) against fence into side
  3. bottom.
  4. near (short) end.
  5. right side
Everything dries for at least an hour before the clamps come off.
The outside is scraped of big glue clumps and sanded with 120.
While waiting for the glue to dry on the box, this is a good time to attach the push-to-open/close bar to the near end of the lid. Because of the dado, the lid is always half a side thickness too long. Subtracting 1/2 a thickness is hard to do. We know it's going to get trimmed so we glue and clamp the offcut from the near end no more than 1/16" back from the edge. Since the offcut is being glued directly over where it was cut from, try to orient it correctly. Sand off about 1/16" from the end and the round the corners and edges of the top side for finger comfort. The bottom edges, being the glue surface, should be left square and flat.
Lid Fitment:
In a sliding lid box a "perfect" fit is where the lid slides easily and automatically locks in place when dropped in. The end dado is intentionally 1/32" to 1/16" narrower than the front lip of the lid. To get it to seat and hold, slowly fine grit sand a bevel on the lip. Test after every couple of quick passes as it's real easy to take too much off. Once the lip can be seated (a little gap is OK as long as the lid holds in place when upended), mark and trim most of the extra off. Leave it a little proud so the final sanding will get it dead flush with the end.
Rectangle Font Parallel Pattern Slope
Detail of lid lip fitment.
The edge of the push/pull bar may need additional sanding.
Tray Fab:
The rosewood was sliced into two sides, three bottom/divider pieces, and two ends. One of the three bottom/divider pieces is ripped 1/4" off and used as both a center divider and lift grip for removing the tray.
The better sides of the rosewood was faced up or in since the interior of the tray is more visible
Rectangle Wood Hardwood Varnish Flooring
Rosewood grain is beautiful.
Glue up order:
  1. left side
  2. far end
  3. both bottom pieces
  4. near end
  5. right side
The last piece was rounded on the top and eyeballed in place and tweaked until even.
Final Fab Touches:
Both pieces received a decorative 1/8"R bead around the base. This adds interest and visually raises the pieces. Although the detail on the tray is seldom seen, it serves to tie the two different species together. The use of the rosewood as spacers attached to the lacewood ties the two species together. All the rosewood was oriented with the visually most interesting side inward because the inside of the tray will be seen more often. No attempt was made at grain sequencing. On the lacewood the best side was faced out, again without sequencing.
After beading, a final 220 sanding removes the bearing marks and smooths. The edges and corners are lightly chamfered with the 5" ROS to avoid splintering.
Felt feet (Always!), shop stamp and build date complete the fab portion of the project.
Finishing:
Wood Rectangle Bag Hardwood Wood stain
Fully fitted & detailed, ready for SWMBO to finish.
Truthfully, I detest finishing. I do it because I have to. My soft finish is just wax. Hard finish is two coats of 50%-50% poly-MS and a final coat of 100% poly. The base coats are slopped on and I don't have a lot of patience between coats.
SWMBO has previously critiqued my finishing prompting me to say "Ok, YOU do it!" She replied "Ok." and here we are.
Brown Rectangle Product Wood Wood stain
Finished pics soon! (I hope!)
Two coats of 50%-50% of poly-MS mix later we've got:
Brown Product Wood Rectangle Wood stain
Slop coats are for penetration and coverage, not finish.
After the base coats were fully dry the outside of both the box and tray were scuffed with a 220 grit sanding sponge as prep for final finish.
SWMBO just put the final coat of full strength poly on.
Pack and ship to friend is last, last step.
Ready to ship.
Sliding Lid:
Box Assembly:
  3. bottom.
  5. right side
Lid Fitment:
Tray Fab:
Glue up order:
  1. left side
  2. far end
  4. near end
  5. right side
Final Fab Touches:
Finishing:
That's a beautiful box, Mark. Great work.
Steampunk Unity Weather Station Done!
This started out as an offshoot of my humidor project. I buy in pairs and so I had a spare hygrometer. An idea of a weather station began to form.
Light Electronic instrument Audio equipment Gadget Gas
Unity Weather Station, on top of a table stereo, on top of an Edison Phonograph.
Wax to Bluetooth in one century.
I call it the "unity" box because of the variety of woods:
  • White (maple)
  • Black (wenge)
  • Brown (walnut)
  • Red (purpleheart)
  • Yellow (yellowheart)
I found a $12 LED module with time, indoor temp, outdoor temp, and power voltage. It can be programmed to cycle at various speeds and display more or less info. It even allows calibration of the two temp sensors and the voltage reading. Pretty cool for a little $12 unit.
The black thing projecting up in front of the Storm Glass is the indoor temperature sensor. The longer (~24") outdoor probe is routed out the back. The cord was double knotted and glued in place with some loctite adhesive. The indoor probe was held in place temporarily with a pair of wire ties as the probe mount was glued with more loctite.
Product Font Clock Rectangle Display device
$11.69 at Walmart
Here you can see both modules on the project CAD drawing.
Line Font Material property Parallel Rectangle
Modules on front of box.
So now I've got time, temp, and RH% data but I wanted something a little more esoteric. I found this thing called a "storm glass" that changes from liquid to flakes and clouds up for storms. This will be projecting up from the top.
Liquid Fluid Cylinder Font Cosmetics
Storm Glass. From WalMart
Here is what the Storm Glass is supposed to indicate:
Brown Amber Font Tints and shades Pattern
How it's supposed to work.
Because the layout was tight & complex (and I just got the free nanocad program working), I drew the plan in CAD.
Rectangle Slope Schematic Font Parallel
Fuzzy CAD drawing.
All the required holes were laid out and then piloted using a jig to ensure consistency. The 1/16" pilot holes were enlarged as needed but also acted as transfer markers.
I'm sorta on a steam punk kick, and for access to the interior, the top and back are secured with stainless steel allen cap head screws. Six on top and four on the back. The wood is drilled and tapped for 6-32 machine screws.
Wood Rectangle Material property Hardwood Wood stain
Steampunk!
The time/temp display self dims at night but could still throw an annoying amount of light. So I added a couple of sustained push buttons. One will blank the time/temp module and the other will control a RGB multi color changing LED hidden under the storm glass. This should make a really pretty night light.
The push buttons are fancy with a glowing blue LED ring around the buttons.
Light Product Font Camera accessory Material property
$5 ea. at SuperbrightLEDs
The whole thing runs on a cheap "wall wart" 12vdc power supply. The current draw is minimal so small barrel connections will work.
The storm glass comes with a simple 2×2 bock of cheap wood with a 1-1/16" by 1/2" flat bottom hole. Between the glass itself (~31/32" dia) and the hole is a thin plastic ring. I pried it out and will reuse it in my stand. This should give the "correct" mount. The instructions for the sealed weather glass are very firm that the contents should be treated as sorta-HAZMAT if the vial is broken.
The hole for the vial is 1/2" deep but the lid is only 1/4" thick so obviously it can't directly mount. The color changing LED is 1/2" diameter and about the same high. So a total lid mount of 1" is needed. Solved with a 2×2x3/4 block of scrap glued to the underside of the top.
Rectangle Wood Amber Flooring Floor
Mounting block.
Time to cut the panel holes.
Hole cutting went great. I'm getting better at scroll sawing, but am still having issues with the lower blade clamp.
One of the modules dropped in after light cleanup with 80 grit on the 1" nose sander (a wonderful gadget for things like this). The other took a bit of rasp filing in the corners but went in easily.
Wood Rectangle Art Font Creative arts
Out of the clamps after panel cutting. Finishing next.
50%-50% poly-MS mix is "flooded" on for maximum penetration and fewest "holidays".
Product Wood Rectangle Hardwood Font
After first soak of 50%-50% poly the colors are great!
I'm waiting on the 1-1/16" forstner to drill the hole for the storm glass, so more to come.
Bit arrived today. When I checked in the original hole it seemed a hair loose. [email protected]#$%&() hole is metric! I drilled it and the plastic collar wanted to buckle when I tried to insert it. It went in, but wouldn't seat. Hrrumpf! Try as I might, I couldn't get the storm glass to seat.
Soo … I pulled the collar out and used loctite adhesive to mount the Storm Glass. A small bead around the hole worked and looks fine.
Friggin' giant LED wasn't the size the Chinese data sheet said nor was it the same size of the one I used to size the hole. Gel superglue acted as filler and doesn't show.
I got everything wired and tested and it all worked. All the wiring was soldered and covered with heat shrink tubing (Factory don't use no steenkin' electrical tape!).
Everything worked on the first try and looks both steampunk and Fronk-en-STEEN!
Natural material Wood Rectangle Hardwood Wood stain
Ready for final assembly.
Completed project. Time/temp is set to sequence every five seconds. The color changing LED cycles at its own pace (they come in two unspecified speeds, slow and fast.)
Light Wood Technology Audio equipment Electronic device
Steampunk unity weather station.
Product Wood Electronic instrument Audio equipment Table
Pretty cool! And it sorta matches my table stereo project.
Details:
  • RH% gauge - $8
  • Time/Temp indicator -‐ $12
  • Storm Glass thing - $22
  • Lighted push buttons, 2 @ $5 ea. - $10
  • Power Jack & plug - $7
  • Wall Wart (on hand)- $5
  • 10×6-32×1/2" Allen cap screws & plastic washers, $.15 ea - $1.5
  • 4x rubber feet - $3
    Around $70 in hardware
About 1/4 bf each of:
  • Walnut
  • Maple
  • Wenge
  • Yellowheart
  • Purpleheart
    Prices too crazy right now to make a meaningful estimate. Guess at $30?
Labor, umm, about 20 hrs counting CAD. But this was for me, so price wasn't really an issue.
Walnut Air Filter Stand
We have pets and with pets comes pet dander and allergies. We bought a Grizzly G0738 two stage (5um & 1um) filter.
Gadget Gas Electronic device Cable Wire
Grizzly G0738 two stage, three speed air filter w/ remote.
It really makes a difference but it's not the most attractive box in the bedroom. It's been sitting on a faux walnut MDF stand that's falling apart. I decided, and SWMBO agreed, that something better was needed.
Wood Rectangle Flooring Fixture Wood stain
Completed top is gorgeous!
I came up with a design for a real walnut (& walnut A-A ply) stand. Here it is after the first coat of MS thinned 50%-50% poly and waiting on the top (which will have a live edge but isn't built yet.)
Brown Cabinetry Drawer Wood Chest of drawers
Cabinet with lower storage.
I had to CAD the carcass. It is built out of four panels with 3/4" walnut ply base and middle shelf. The base is 32" tall by 24" wide x 22" deep. The top is 28" x 24" with 2" overhang on the live edge front and sides. The top will be flush to the back.
Rectangle Parallel Pattern Engineering Symmetry
Doors:
Construction started with the two raised panel doors. I have the Grizzly H5553 reversable rail/stile and panel set with the classic ogee profile. This was the first project that I used this on and the doors gave me an opportunity to dial in the reversable rail and stile set. Being anal (engineer) I had to draw up the stacks in assembly order locating the various thickness washers, bearing, and cutters. After cleaning, all the washers and cutter spacings were mike'd with my digital caliper and noted on the drawings to insure accuracy.
Rectangle Cross Slope Font Parallel
Stack for stile dado.
Rectangle Slope Font Parallel Schematic
Stack for rail tenon.
By cutting the dado's first, the finished face is used as a reference. The 1/4" dado position becomes a reference for cutting the rail tenons.
Rectangle Handwriting Font Cross Slope
Alignment Diagram.
The 4/4 S2S walnut from Craftsmen Supply (Ybor City/Tampa) came in at ~7/8". Rather than plane down the extra thickness into dust, I used it as-is. The only issue this caused was some extra tweaking of the ply deck and the face frame was too thick for the hinges. To get around this the sides of the door frame were undercut with a router and rabbeting bit to exactly 3/4". The hinges fit perfectly and the rabbet is essentially invisible.
I used one piece of 1×6x28 walnut per door with sawdust left over. The doors were given a slathering of wax as a "shop finish" to protect them until the rest of the cabinet was ready. The thinned poly went thru the wax like it wasn't there during the actual finish process.
Wood Floor Wall Rectangle Pedestal
UL: Panel cutting jig,
UR: Botched rout on rear,
LL: Test fit,
LR: Under clamps.
Brown Rectangle Wood Door Wood stain
Before and after waxing.
The doors were set aside until the front frame was built. The hinge positions were verified against the frame opening and door size before drilling the 35mm hinge cups. I set the centerline stop on the drill press to 13/16" and just drill at the marks for perfectly positioned hinge cups. I set the panel flat on the drill press table and set the depth stop flush with the surface. A piece of 1/2" scrap under the stock raises the stock the thickness needed to drill the cups. Then I use the self centering drill bits in the corded VSR hand power drill in a hinge set in the cup to pilot the two mounting screws. This perfectly aligns the mounting holes with the cup using the hinge itself as the jig.
Sides:
Next came the two side panels, these are traditional rail and stile frames with 1/4" walnut ply panel inserts.
These went together easily because of the CAD analysis allowed me to set and reset the extra thickness rail and stile pieces with precision.
Wood Rectangle Composite material Gas Parallel
Four L's form two panels
The side panels are the strength members. The middle deck 3/4" plywood is supported by 3/4" sq cleats biscuited into the rails of side panels. The bottom of the sides have another biscuited cleat in the bottom rail. This cleat is glued to and rests on the 3/4" ply base, transferring the load down to the legs.
The cleats were positioned self referentially so the ~3/4" walnut decking would sit flush with the edge of the side, hiding the plywood grain. Setting the stock and biscuiter flush on the saw top "zeroed" the slots in the cleats. Then I used a cutoff from the ply as a spacer to lift the biscuiter up and cut the slots in the sides. Without measuring, the biscuiter cutter height, or the ply thickness, I was able to blind glue the cleats and it came out dead flush.
Wood Chair Hardwood Wood stain Rectangle
Self referential parts fit perfectly flush.
Front:
I hadn't fully thought thru the front face frame design. I had sketched it as two full height stiles with top, middle, and bottom rails. The bottom was to have two euro hinged doors and needed a flat 3/4" mounting surface. The top half was to have flat panels in rabbeted stiles and tenon edged rails. There was no clean way to transition one piece from flat to rabbeted so a different answer was needed. The rails were run full width with the stiles tenoned instead. The bottom was done with biscuits on the butt joints. The center rail was flat on the lower edge and rabbeted on the top. This solved the problem but leaves exposed end grain on the sides. I may make some trim to cover it.
The top panel looked boring and too wide so I added a center stile. This made the inset panels almost square. I mis-cut the panels 1/4" too narrow but they fit well with the spaceballs in the rabbets. I was careful to orient and sequence the panel plys consecutively.
Back:
The back also had three full width rails but was easier to make as everything was rabbeted in one go. As luck would have it, I cut the bottom stiles 1/4" too long. Better long than short and a quick trim brought everything back in spec.
Bottom:
The bottom had holes drilled for the screw on legs 3" in from each corner of the base or 3-7/8" from the outer edges. For some reason the screw studs were over an inch long and, with no way to trim them down, they project completely thru the 3/4 ply lower deck. The legs had small plastic protector caps on the screws that I trimmed and used to cap the exposed ends inside the lower shelf. Its not the best solution, but it's neat and better than leaving the studs exposed.
Wood Wood stain Rectangle Hardwood Gas
3×3x6 pyramid legs.
The top plates were installed using the supplied #6 hardware directly over the 3/8" hole for the studs. The inverted pyramid feet were set back to prevent the puppies from using them as a fire hydrant. The tops were recessed slightly to hide the mounting plates.
Wheel Tire Motor vehicle Automotive tire Plant
5/16-18 top plates.
Assembly:
The sides are biscuited into the front and back. The panels were set up on the saw in the same assembly corner I use for small boxes. The deck ply was fitted but not glued while the sides were glued to the back. Once these had set up, the front was glued on and the deck was glued down and weighted.
Finally the cab was inverted onto the floor and the bottom, feet and all, was glued in place, weighted and left to set overnight.
Finishing:
The completed box was sanded to 120 all round. One thing about gluing on the saw top is that all squeezeout in contact with the iron turns black and is easy to see where sanding is needed (LOL).
After sanding, a flood coat of 50%-50% MS-Poly mix is applied everywhere. The ply and end grains drank the poly up almost instantly. I reapply until it appears slightly wet.
I use 3" and 1-1/2" disposable foam brushes for streak free and easy application. Disposable brushes are easier on the environment than cleaning good brushes with a pint of MS. It took a while, but I got every square inch (except the top edge where the top will attach) inside and out.
The doors are mounted and the knobs attached. SWMBO selected and ordered nice real crystal round knobs with dark bases. These pair nicely with the walnut and, being round, can't be misaligned. The holes were drilled with a simple stop block on the drill press for perfect alignment.
Brown Cabinetry Furniture Wood Wood stain
Doors closed, open, and closing .
I haven't dialed the hinges in yet, but they self close with less than 1/8" gap between them.
Top:
The top was supposed to be 28×24 out of a 5 board glueup with 2" overhang on the front and sides. As I sorted and squared I came up with a really good grain match across four pieces that was great but only 23-1/2". Guess what?! The top is now 28×23-1/2"! LOL I'm not a slave to the plan and I'm more concerned about yield than having to hit an arbitrary dimension.
  • After all, how much overhang on a top is "right"? 1/2"?, none?, 2"?, 6"? I've seen tables with dimensions all over the place. 2" was a nice, round number, but 1-1/2" will work too. None of you would know if I didn't tell you. LOL
Anyway the four pieces were laid out and cut for #20 biscuits in three places and glued up as two pairs, I-II and III-IV. Both pieces came in under 13" which is the limit on my planer so that's good. I was hoping to use the new scraper set that came today instead of planing.
The two halves are under clamps now.
Wood Gas Machine Rectangle Hardwood
Halves clamping.
As luck would have it I just bought (arrived today!) a six pack of assorted shape scrapers, Grizzly D3294 (yes, I do know how to use hand tools!)
The scraper made quick work of the squeeze out.
Brown Rectangle Wood Door mat Grey
Before and after. Sharp scraper curls. Nice clean seam.
Finally both halves are biscuited, glued, and clamped to final size.
Wood Rectangle Line Plank Slope
Final top glue up. The color sequence helps hide the seams. This will be beautiful when finished.
The plan is to wire brush the live edge to remove any loose material, then round the corners and rout a profile on the sides.
One of my (many) pet peeves is pointy corners. I tend to carom off things and have been gouged by pointy corners furniture and the like my whole life. So the two front corners will be radiused and the edges profiled as an architectural detail.
Rectangle Wood Table Floor Flooring
Looking great!
  • Joinery Aside:
    Some insist that a jointer is mandatory for getting glue edge seam. The seams on this top are tight and straight off the saw with my favorite blade, the Freud LU83 combo. The lumber was all S2S and some was slightly bowed yet the seams are straight and tight. It gives glassy crosscuts and glue line rips. This is why there's no joiner in my shop. I just haven't found the need.
Because of expansion I'm going to biscuit the top to the back but let the front float on clips.
I've been kicking around the thought of milling some cove for under the table lip but wasn't sure I'd have enough walnut left. The savings on the top gives me a 1×6x32 board to spare so I've got the material. The only secondary woods are whatever is inside the walnut ply and the biscuits. Everything including cleats and supports is solid walnut.
Brown Furniture Product Drawer Rectangle
Completed project.
Materials:
  • 4/4×6 S2S walnut - 21bf @ $12/bf ~ $252 (includes top)
  • 3×3x6 pyramid 5/16-18 screw on legs - $40/set of 4
  • 5/16-18 top plates - $15/set of 4
  • 1/4 A-A walnut ply, 2×4 sheet - $40
  • 3/4 A-B walnut ply, 2×2 sheet - 2 @ $20 ea ~ $40
  • knobs - 2 @ $2.50 ea ~ $5
  • biscuits - 20 @ $0.05 ea ~ $1
  • glue brushes - 8 @ $0.50 ~ $4
  • foam brushes - 8 @ $0.50 ~ $4
  • poly, 1 qt @ $12
  • soft close euro hinges - 2 pr @ $14/pr ~ $28
Matl. Total: ~$440
Labor: 20 hrs @ $20/hr = $400
COGS: ~$850
Doors:
Alignment Diagram.
LL: Test fit,
LR: Under clamps.
Sides:
Front:
Back:
Bottom:
3×3x6 pyramid legs.
5/16-18 top plates.
Assembly:
Finishing:
Top:
Halves clamping.
Looking great!
  • Joinery Aside:
Completed project.
Materials:
  • poly, 1 qt @ $12
Matl. Total: ~$440
COGS: ~$850
mark i gotta say some guys give you a lot of crap here but they cant say honestly that this isn't a damn nice piece of furniture.pretty good for the hump with a stump and the pump. ;-)
Doors:
Alignment Diagram.
LL: Test fit,
LR: Under clamps.
Sides:
Front:
Back:
Bottom:
3×3x6 pyramid legs.
5/16-18 top plates.
Assembly:
Finishing:
Top:
Halves clamping.
Looking great!
  • Joinery Aside:
Completed project.
Materials:
  • poly, 1 qt @ $12
Matl. Total: ~$440
COGS: ~$850
TYVM!
Doors:
Alignment Diagram.
LL: Test fit,
LR: Under clamps.
Sides:
Front:
Back:
Bottom:
3×3x6 pyramid legs.
5/16-18 top plates.
Assembly:
Finishing:
Top:
Halves clamping.
Looking great!
  • Joinery Aside:
Completed project.
Materials:
  • poly, 1 qt @ $12
Matl. Total: ~$440
COGS: ~$850
Looks great Mark. The tip on the wax before thinned poly finish is interesting and something I'll consider for some things. For guitars, I usually give everything a coat of shellac and then sand it all off before spraying lacquer.
Doors:
Alignment Diagram.
LL: Test fit,
LR: Under clamps.
Sides:
Front:
Back:
Bottom:
3×3x6 pyramid legs.
5/16-18 top plates.
Assembly:
Finishing:
Top:
Halves clamping.
Looking great!
  • Joinery Aside:
Completed project.
Materials:
  • poly, 1 qt @ $12
Matl. Total: ~$440
COGS: ~$850
Nice build Mark. So the air grid shown on the CAD drawing in green is open to the back? Is there any other air flow?
I have the same units (2), and use them in the shop, not hung, but placed atop of counters, work tables and such close to where I am creating the dust, and by looking out windows I see MANY less floaters, floating around when I use them. I always place them on top of blocks of wood to allow for air flow all around mine, it seems they do much better like that then just flat on a surface. That is why I asked about your airflow on the enclosed cabinet.
Doors:
Alignment Diagram.
LL: Test fit,
LR: Under clamps.
Sides:
Front:
Back:
Bottom:
3×3x6 pyramid legs.
5/16-18 top plates.
Assembly:
Finishing:
Top:
Halves clamping.
Looking great!
  • Joinery Aside:
Completed project.
Materials:
  • poly, 1 qt @ $12
Matl. Total: ~$440
COGS: ~$850
That came out great, good job. Thanks for the details.
Doors:
Alignment Diagram.
LL: Test fit,
LR: Under clamps.
Sides:
Front:
Back:
Bottom:
3×3x6 pyramid legs.
5/16-18 top plates.
Assembly:
Finishing:
Top:
Halves clamping.
Looking great!
  • Joinery Aside:
Completed project.
Materials:
  • poly, 1 qt @ $12
Matl. Total: ~$440
COGS: ~$850
Both sides are fully open. The air filter unit can be rotated 180° and there is about 1-1/2" on either side and maybe 3/4" at the top.
Doors:
Alignment Diagram.
LL: Test fit,
LR: Under clamps.
Sides:
Front:
Back:
Bottom:
3×3x6 pyramid legs.
5/16-18 top plates.
Assembly:
Finishing:
Top:
Halves clamping.
Looking great!
  • Joinery Aside:
Completed project.
Materials:
  • poly, 1 qt @ $12
Matl. Total: ~$440
COGS: ~$850
Mark
The grain of the wood is awesome. Nice build.
Thinned poly over wax, would have never thought of that.
Rick's Steampunk Stereo Weather Science Station
Purple Electronic instrument Entertainment Interior design Audio equipment
It's Ricktacular!
Blue Purple Entertainment Interior design Gadget
Light show.
Wood Cabinetry Entertainment Audio equipment Gas
Steampunk Rulz!
Shop has been on a bit of a hiatus for a couple of months. First, parts have been taking forever. Second, we've been waiting on the mini-split to be installed.
SWMBO had cleaned in anticipation of the AC install and had vacuumed to the point that we were able to actually see the floor. Having been instructed to keep things clean and clear for the AC tech, sawdust production stopped.
Things took a bit longer to get installed, mostly on paperwork, but once the day came, it was a 1/2 day job and done. The weather has broken here in Fla and we're FINALLY under 90° F but the humidity is still high and having AC is all the difference in the world. I ordered a grizzly air cleaner to help keep the AC clean. It should be here soon. It's been a lifetime dream to have an air conditioned shop and it's finally here!
This is another steampunk inspired, kitchen-sink gadget. It does lots of things, much of which is geared to looking cool.
  1. Bluetooth radio w/LED display
  2. separate LED volume bar graph meter & green LED sw
  3. time/temp green LED module & green LED sw
  4. RH% LCD meter (always on)
  5. storm glass w/RGB LED & blue LED sw
  6. prism w/RGB LED & red LED sw
  7. display stand uplight RGB LED puck & white LED sw
  8. high voltage antenna terminals
This is a conglomeration of three or four other projects into one big overly ornate and complex gadget.
Peektures:
Light Lighting Entertainment Electronic instrument Font
Here it is in all of its glory. You can see the various displays cycling. The top buttons control the associated device and each can be turned off and on separately. The puck, Storm Glass and Prism are all RGB LED lighted. The puck has a remote control. The Storm Glass and the Prism have independent (not synchronized) RGB lighting.
The time, internal and external temps appear in the first three frames. The bar-graph is also active.
Motor vehicle Font Art Rectangle Advertising
Internal wiring details showing:
  • Wiring in process. All units were pre-wired and tested prior to installation
  • +5 vdc regulator mounted on LED support block.
  • Bar-graph module on lexan.
  • Bar-graph mounted in case
  • Each device had power and ground leads soldered to common bussbars.
  • Top view shows final layout
Circuit component Electrical wiring Amber Cable Audio equipment
Rather than make a six way spider, I installed ground and +12vdc bussbars made out of 12ga solid wire. This greatly simplified final interconnects. The ends of the buss wire were flared out a little bit for retention in the pilot holes.
Wood Pliers Household hardware Hand tool Fastener
Heat sink was mounted at first random location on LED mounting block. A hole was drilled & tapped 6-32 to hold the heat sink and +5vdc regulator. Yellow wires are +5, red +12, and black is, of course, gnd.
Wood Amber Gas Audio equipment Machine
The bar-graph has built in connector, and display mode select button. Although the module retains the selected mode, I thought it might be cute to bring the button out so the display mode can be changed without opening the case. As luck would have it, the fenestration needed a "nose", and what better than a (push) button nose?! LOL
Pressing the display mode "nose" cycles the bar-graph thru the following modes:
  • Standard Bar-graph, full height bars, no peak hold
  • Standard Bar-graph, full height bars, peak, hold & fall
  • Instant/Peak, Single LED shows instant value, 2nd LED shows peak, hold & fall
  • Center expanding, no peak hold
The display module didn't really have mounting tabs, just a semicircular M2 sized notch on the far ends. Additionally, any mounting hardware would contact the fragile traces, so that was out. It obviously was shaped to fit a specific application, not ours. I put a nice bead of clear RTV down the center of the module and attached it to a 1-1/2" x 3" piece of smoked Lexan.
The Lexan with the bar-graph module was, in turn, glued (more clear RTV) to the inside of the case, centered in the beveled slot. The beveling makes the bar-graph easier to see and is an intentional rhyme with old tube radio panels.
Brown Wood Sleeve Wood stain Hardwood
Bar-graph recess.
Brown Plant Wood Musical instrument Font
Old Philco radio beveled panel.
For most projects I only need small pieces of Lexan. Only problem is that if you want anything other than clear you generally have to buy a full sheet. Wayyyy overkill. I did manage to find one plastics company, ePlastics.com that
that sold sample packs of a half dozen assorted 4" x 6" x 1/8" shades of grays or colors (I bought a pack of each colors and grays) and now I have enough assorted pieces to last for years.
You can see the antenna and bar-graph connections to the stereo. The bar-graph, terminals, speakers, and stereo balance, all agree on L & R.
FINALLY moving forward. That last stray parts and pieces have shown up, including a very cute, and very tiny, chamfer bit.
The woods were selected as
  • Flame wood front and bottom
  • Walnut ends with dual racing stripe inlay
  • Sapele top
  • back is a piece of clear pine resawn to 9/32"
The pine back works, but is the least proud part of the project. I didn't even bother to finish it as I'm really considering a remake on it. I over drilled the cord hole, have it a hair too tall, mis-aligned to mounting screws and forgot to drill the hole for the "outside" temp probe. (Sigh.) Nothing is ever perfect.
The front and top were complex layouts with multiple rectangular cutouts, various diameter holes and ornate joints. Here is the box receiving its 2nd coat of thinned poly.
Brown Wood Rectangle Wood stain Hardwood
Check out the fine ripples in the flame wood grain:
Brown Rectangle Wood Door mat Wood stain
The screws are in place to keep the poly out of the holes. They were replaced with fresh ones as the originals were slopped with poly from the finishing process.
The two large diameter recesses are for the Storm Glass and prism and have hidden blocks with 3/8" holes for color changing LED'S. The Storm Glass needs at least 1/2" of support and the LED needs another 1/2". This means that top to bottom we need 1" of material. Since the top itself is only 1/4" (actually an RCH under) I needed to attach a 3/4" block under the mounting location to hold everything. The blocks are 1-7/8" by virtue of that being the size of the piece of scrap pine I used.
The prism shows what it's mounted on so I wanted the Sapele to show under it. Initially I considered trapping the prism vertically to allow it to rotate, but I just couldn't figure out a good, sturdy mount. So I decided to just RTV it down like the puck. However, just plopping down near the LED hole didn't seem like a good plan. Since I'd already made a Stand for another prism of the same size I already have the 1-5/8" forstner to make a centering recess. With this in mind I piloted the center of the recess and then glued the backing block in place, extending the pilot hole once the glue dried. I then used the big forstner to drill about 1/2 way thru the top, leaving the sapele showing. Then I thru drilled the 3/8" thru LED mounting hole. The recess helped hide the RTV squeeze out and insured the prism was centered over the LED. I squared one face to the top to insure it looked centered and not cockeyed. I think it came out well.
Wood Rectangle Art Font Brick
You may be wondering why I used a highly figured flame wood on the bottom. Well its a salvage from a botch on the first front I cut. The design was to be 11" overall so I cut my front and top to be 11-1/2" figuring this would be enough to hs some margin. Wellll I forgot to trim the front and routered the ends at 11-1/2" instead of 11". I'll just trim 1/2" off and reroute the end sez I. I trim 1/4" off (the original routing took 3/16" off already) and reroute the fancy crowns. Only problem is that some of the pattern was left and interfered with rerouting and looked like bleccch. Ahh, so the original front is now the bottom.
The crazy electrodes aren't just decorative. They are the antenna leads but they look cool. Due to the thickness of the lid I had to order longer 2-1/2" 10-32 screws than the 2" ones that came with them originally. Now I only needed 1/4", but the screw is 1/2" longer. I both took up some of the slack, and added another touch of steampunk detail, by padding out the mount with a stack of different color washers, black, white, and brass. The antenna has a 32" vertical rod and a 32" grounding chain that hangs down from the back like a thin brass tail. I had extra clamps and I used one on the end of the chain as a weight. Again, more steampunk details.
The Storm Glass has four decorative screws around it to imply something of power. The five screws on each end of the top are functional to allow internal access. With all the crap and wiring its a little messy on the inside.
You can see where the chamfer bit was used around the LED sound bar graph opening. This is a style I've seen on old radios. The inside of the opening will have a piece of smoked Lexan covering the back of the hole. The Lexan and the bar graph will be glued in place with clear silicon RTV. This solves trying to mount the LED bar-graph with essentially no mounting holes. It only has an M2 semicircle at each end. How cheap is that? They could only afford one hole, and at that, had to split it, half a hole at each end!
Anyway, the cutout for the bar graph is only 1/2" and I had to special order a tiny, 3/16" bearing, chamfer bit to route the edge of the opening. $28 just to edge that one hole.
Cylinder Font Rectangle Metal Test tube
Amana Tool MR0108 Miniature 45 Degree Chamfer with 3/16 D Ball Bearing x 9/16 D x 1/4 CH x 1/4 Inch SHK Carbide Tipped Router Bit-$28 + shipping!
The striped inlay was ordered from Grizzly. For some reason, one of our cats decided that it tasted good and chewed up about 6" of it. The strips were sold as 3/8" wide and I have a 3/8" straight router bit so I figured no biggie. Only thing is that actual strip width is 13/32". The Incra saves the day! One pass on both edges of both ends with the 12/32" (3/8) bit, move exactly one tooth (1/32") and run 'em again-perfect fit!
Brown Wood Brick Brickwork Rectangle
Grizzly T23918 - Bloodwood/Maple Diamond Inlay Banding Strip
Got one more 3/8" hole to drill in the center of the front face for the nose. When doing the layout I was conscious of the fenestration. The radio is the wide big mouth (since it makes the noise), the meters are the eyes, giving insight (into the time, temp & humidity), and the last will be the push-button nose for changing the bar-graph mode.
I think of the Storm Glass like the cartoon image of an idea light bulb coming on over your head.
The electrodes: I had thought about mounting them on the sides as neck bolts, but the layout didn't work. So they're top mounted for practical attachment.
The color puck and prism will just be glued in place, along with the LED's, using clear silicon RTV. The puck has a small, black, IR sensor at one point on its circumference. Be sure to mount with the sensor facing front, otherwise the remote may not work. As long as the puck has power (even if commanded off) it will retain it's display settings. This is nice so you can set the mode you want and just on/off from there. This is also why the pucks are battery eaters. They're on standby as soon as the batteries are inserted and even when commanded off. Since the puck has its own dedicated +5vdc power supply, standby power consumption isn't an issue.
Moving on to final assembly:
Furniture Cabinetry Table Orange Interior design
Since I had pre-wired, tested, and clearance checked everything early on, assembly was easy. I had even gone so far as bagging all the parts and pieces to keep dust out and all parts needed in one kit. Much easier, especially when weeks elapse between stages.
Everything is screwed down or glued with RTV. The fitments are snug so it's going together just as planned.
I still have the back to do.
Need to drill & mount feet. Used 6-32 cap screws to mount on bottom. Looks good. Seems to float as feet are dark and not obvious.
Internal wiring will take a bit. Still have to figure out where to mount +5v regulator. Thinking of adding ground and +12vdc buss bars to make tying all those leads together easier. Actually the buss bar idea worked great.
You think this one is wild? My next weather station will have an LCD, IR remote, and an Arduino controller! (Cackling like Kamala while wringing hands …)
Design:
Light Product Rectangle Electronic instrument Gadget
Ancestors.
The final dimensions are still fluid as I'm waiting on parts. I can't do more than doodle until the real parts are on hand. It worked out to be 11"W x 5"H (plus 1/2" for the black rubber feet) by 4-3/4"D. The gadgets add height, depth and heft. The antenna rod is nominally 30" (~100 MHz FM band) high and I added a zigzag bend in it to give it a more sci-fi feel and to reduce the mechanical length without severely impacting the antenna's function. I have a COTS T antenna and an "hi power" antenna and my simple rod antenna pulls in the same stations with the same clarity as the others.
I started by looking for an inexpensive yet functional car radio. I found a nice one in my budget ($25) that had 4×50w outputs and USB, Bluetooth, etc features. Its also controllable by smartphone. This means I can use it like a stereo even when offline.
I settled on the Dual XDM17BT single DIN (50mm x 180mm, 2-1/8" x 7-3/16") unit. This is a very shallow (under 1-3/4") box so it will fit in a small sized box.
Gadget Font Auto part Electric blue Audio equipment
Full featured car stereo, $25 at Walmart .
I purchased a 10A @ 12VDC power brick and put a car cigarette lighter socket on it this gives safe, UL approved power with no liability or safety issues.
Technology Electronic device Font Electronics accessory Musical instrument accessory
AC adapter is UL approved and puts out 12VDC @ 10A, ~$25 from Walmart
Here is the lighter cord set:
Cable Auto part Wire Fiber Font
Lighter connector can carry 10A, $10 at Walmart
The speaker terminal block is readily available at Walmart.
Font Metal Circle Rectangle Fashion accessory
About $10 at Walmart
Audio equipment Gadget Electrical wiring Electronic component Cable
Bluetooth radio & PS pre-wires.
Some of the parts have been trickling in and I've pre-wired & tested as much of the support electronics as possible. I'm using these really cool lighted push buttons to turn off and on each gadget individually. This adds more needless complexity and ornamentation that, to me, hallmarks steampunk. Lots of machine screws!
Found these cool lighted push buttons:
Found this car clock/temp/voltage display. It comes with dual (short & long) temp sensors and has all sorts of options but no docs. It's not that hard to figure out but a cheat sheet would be nice. I'll see if I can work one up.
$11.69 at Walmart
Font Number Parallel Document
My cheat sheet.
Top center I'm going to mount a waterproof remote control RGB LED puck. It's designed to run off three AAA batteries, but I've modified it to run off a small 12v to 5v regulator. I'm going to add a USB charger port out the back so the regulator has a heat sink to carry the heat load (potentially ~15w).
Puck with remote is $10 from SuperbrightLEDs
The prism and Storm Glass are both under-lit with RGB oversize (3/8" dia) LED's. They have 365 ohm ½W series limiter resistors in the power lead to prevent overload.
Font Metal Fashion accessory Nickel Titanium
8mm (3/8") color changing LED is under $1 ea. from Digi-Key
The 12v to 5v regulator IC has just three terminals; in, gnd, and out. The red leads are 12v while the yellow are the +5v power. Again, purchased thru Digi-Key.
Circuit component Electrical wiring Electronic engineering Cable Audio equipment
Pre-wires for: RGB LED w/sw, time/temp w/sw, 5v RGB puck w/sw, remote, and v reg.
This will be the living room stereo with a nice set of Bose speakers as well as a night light. Each item is individually switched so the entire thing can be turned off or lit up like a carnival. Big color changing LEDs go under the prism and storm glass. There is a 3" dia remore control LED puck that will be used as a lighted base for a display stand. None of the lights are synchronized so the color mixes and patterns will be strange - the stranger the better!
Light Circuit component Audio equipment Gadget Font
RGB Puck and 12v-5v regulator with wiring to battery clips.
These LCD humidity modules are cheap and cool.
Rectangle Font Wood Box Clock
A pair for under $15 from Walmart
A Storm Glass is an old piece of technology. It responds to changing weather conditions by having crystals in the fluid go up and down. If the top is clear the weather will be. The more crystals at the top the worse the weather. It looks really cool under-lit by a giant RGB LED.
A 6" prism was to be captive mounted upward to balance the Storm Glass visually, but was on back order. The shorter 2-1/2" prism was available, and you can see it here. It's a good piece of quality optical glass and comes in a nice protective case.
Brown Product Rectangle Wood Material property
About $16 at Walmart
I've always loved watching the VU meters while listening to music. The particular radio used here doesn't have built-in VU metering functionality so I'm hoping to be able to add it via the pre-amp output jacks. I'll cobble it up on the bench first before finalizing the layout. Centered over the radio module might work … vertically on the side fit better.
White Light Font Line Electrical wiring
Dual LED VU meter, $15 at Walmart .
I got the device in and the hookup was easy, R & L inputs, power & ground. I wired a pair of short, shielded RCA cables to the supplied harness, added power and it worked on the first try. The meter has a variety of display modes, selected by a tiny surface mount push button on the back that simply won't be easily accessible once the project is completed. So now I'm waiting on a plain momentary PB switch to wire in parallel to the rear panel. Inside every small problem, is a larger problem, struggling to escape. This one part delayed the project almost a month …
Again, I'm going to mix lots of colors and patterns in the wood and joinery. Finally settled on Sapele, Flame wood, and walnut.
I normally use a two terminal barrier strip for the antenna leads on the radio. These are plain-Jane but functional. For this monstrosity I'm going to use a couple of high voltage ceramic insulators just for nonsense as the actual antenna leads. Maybe put a Jacob's ladder shaped coat hanger on it. LOL
White Light Product Auto part Engineering
Should be impressive as antenna terminals!
I researched FM antennas and there are basically the classic (fugly) "T" dipole and a vertical monopole. The monopole has an 30" (for FM band) vertical rod with a vertical ground wire of the same length. Having a rod sticking up is cool, but the same sticking down causes no end of positioning issues. What is called for is a flexible rod ... a chain! Conductive, will hang straight down, flexible. Brass pull chain!
The electrodes are #10 studs and the aluminum rod I found was .125" or just a hair under 8 ga wire dia so I had to locate an 8 ga to #10 wire terminal. nothing was really available in crimp type terminals, esp. as I wanted specifically un-insulated type. Regular crimp terminal aren't that thick or strong and I had concerns they might not be stiff enough to hold the rod upright. McMaster had these copper plated steel ones that were the right sizes but also looked (and was) very rigid.
Wood Line Wood stain Hardwood Gas
Electrode and rod assembled, tip was rounded over for eye safety.
One issue is that these electrodes were designed to mount in thin (metal) panels and not 1/4" wood. I may have to use longer bolts or countersink the underside. We'll see. -The bolts were 2" for 1/16" metal panels. Using a thick 1/4" panel didn't leave more that a thread or two for the hardware, without the crimp terminals. So I looked around and no one really has 10-32×2-1/4", its 2" or 2-1/2" and I didn't need a box of 100 so I bought what I could get, 2-1/2". I had a lot of stud left so I ordered brass, clear, and black #10 washers. I stacked these on the top of the electrodes to give a more complex, steampunk, look.
Figuring out all the electrics is the major part. I've CAD'd the layout but still have a couple of unknowns and missing parts.
Rectangle Slope Font Schematic Parallel
Bottom line:
radio - $25
speaker terminal bloc - $10
12v/10a power supply - $30
car lighter plug/socket pair - $12
Antenna lead - $8
Crimp terminals - 2
chain, bead, 36" - $5
rod, 1/8 alum, 36"
electrodes - 2 - $10ea - $20
2-1/2 10-32 screws - 2 - $2
#10-8ga terminals - 3 - $6
#10 flat washer, brass - 10
#10 flat washer, nylon - 4
#10 flat washer, fiber - 4
Storm glass - $25
prism - $20
bar-graph - $15
no pb - $5
RCA patch cord - $5
Dumont jumper - $0.50
Lexan - $30 sample kit
- chamfer bit - $28
Jumbo RGB LED's - 2 - $2ea - $4
Resistors, 360ohm, 1/4w - 8, $0.05 ea, $0.40
humidity gage - $8
Time/temp gage - $15
RGB puck w/IR remote - $10
5v reg, TO-220 - $2
heat sink - $1
bypass caps - 2 @ $0.10 ea, $0.20
1×6x12 (1/2 bf) walnut ends - full 15/16" thk - $8
1×6x12 (1/4 bf) sapele top - resawn 9/32"
1×6x12 (1/2 bf) flame wood front & bottom - resawn 9/32"
1×6x12 (1/4 bf) clear pine back - resawn 9/32"
1×3x6 (1/8 bf) clear pine blocks
Lighted, sustained, spdt, push buttons - 5 at $5 - $25
Wire, 22ga, stranded, asst. colors, ~30'
Wire, 12ga, solid, bare, 12"
HS tubing, asst. colors, 1/8", 3/16", 1/4", 2' ea
Wire ties, 4", ~25
6-32×1/2 SS allen cap machine screws - 23, 14 top, 4 back, 1 interior, 4 feet.
6-32×3/4 SS allen cap machine screws - 4, spkr pnl
6-32 SS nylok nuts - 4, spirits pnl
glue, titebond III
poly, 3 coats, Minwax Varathane
brushes, foam - 3 (one per coat), $0.25 ea, $0.75
inlay strip, 2' - $10
feet - 4 at $0.75 - $3
RTV, clear, 1 tube - $7
Total - around $350 matls only!
Tools req:
TS, cross/rip/resaw
Planer
DP
5" ROS
router, 1/2", table - dovetails & inlay
Fast-Joint kit - dovetails
3/8" straight router bit - inlay
router, 1/4", hand - bar-graph bevel
scroll saw - cutouts - 5, radio, hygrometer, time/temp, bar-graph, speakers
band saw (cord slot) - could use scroll saw
square, small - plumb storm glass & align prism
layout rule & .5 mm pencil
glue brush, disposable
clamps, 2×6", 2×12"
6-32 D&T
5/16" box wrench (nylok nuts)
1/16" pilot drill for all hole locations
3/32" drill (buss bar mtg holes)
1/8" drill (#6 clearance drill)
3/16" drill (temp probe holes & puck feedthru)
Bits, forstner: 3/8" nose button, LED's, 7/16" electrodes, 5/8" lighted buttons, 1" Storm Glass, 1-5/8" prism
VSR Hand power drill
diagonal cutters
wire strippers
needle nose pliers
wire bending/cutting pliers - antenna rod forming
reverse tweezers - soldering 3rd hand
allen driver bit
Soldering iron & solder
lighter - HS tubing
It's Ricktacular!
Light show.
Steampunk Rulz!
Peektures:
Bar-graph recess.
  • Sapele top
Design:
Ancestors.
$11.69 at Walmart
My cheat sheet.
Bottom line:
radio - $25
Antenna lead - $8
Crimp terminals - 2
rod, 1/8 alum, 36"
Storm glass - $25
prism - $20
bar-graph - $15
no pb - $5
RCA patch cord - $5
- chamfer bit - $28
humidity gage - $8
5v reg, TO-220 - $2
heat sink - $1
Wire ties, 4", ~25
glue, titebond III
Tools req:
TS, cross/rip/resaw
Planer
DP
5" ROS
clamps, 2×6", 2×12"
6-32 D&T
diagonal cutters
wire strippers
needle nose pliers
allen driver bit
lighter - HS tubing
I really like project. I hope you post a list of components.
161 - 180 of 206 Posts
