1 - 20 of 33 Posts
Discussion Starter · #1 ·
Description and explanation
I have made a number of woodworking Sketchup Textures. Just private message me and I will email you the file. I used to keep a link to a server, but that server is no longer active. I will need your email address, obviously.
The textures I could find were not very realistic, or had limited usability, so I made my own. These are seamlessly tiling textures, so dramatic large grain patterns are avoided. I prefer the type of textures I have made over some that I have seen on the internet, or that can be made using specific programs designed for woodworking textures.
1) Unzip it into your materials folder, it should leave a folder under materials named Woodworking.
2) The textures include vertical and horizontal textures if the material has an orientation, so that you don't have to reposition them just for those changes.
3) There are also Finished wood textures, they start with 'Fin'. There are plywood edge textures that you will probably have to position. The textures without the prefix of 'Fin' are supposed to be raw wood.
And as usual, I accept all suggestions and criticism, so wail away. Also if you would like a particular texture just for your particular need, let me know, and I will create it as time allows. Since I am now retired, I have a lot of allowable time…(-: It is usually not a difficult task for me, since I have done a lot of this in another hobby.
nice collection, thanks for sharing :)
I agree, thanks.
Very nice, thanks for posting this.
Excellent. Thank you!
Thanks Jim… good instructions too. Woks great.
In Loving Memory
I downloaded the files, but it said I would need a program to open them. Is that Sketchup? I'm not very good with computers. Also, thanks to Dave for the tip on Vert./horiz. orientation. Thanks for making these available Jim.
Thanks Jim, nice of you to share.
Mike, I think you will need a program to unzip the file.
Discussion Starter · #9 ·
Mike
If you right click a zip file, in Windows XP, Vista, etc you should get a context menu that will include extract, to extract the files. The key is to place the files such that they are in a folder under materials and I named the folder WoodWorking. The address for the folder would be something like this:
C:\Program Files\Google\Google SketchUp 7\Materials\WoodWorking
and inside that folder should be all the material files in that zip file. I have trouble explaining placing files to others, because my computers are set up to look like old Windows 95, because I do so much file manipulation, and do some programming that manipulates files directly. Send me a PM if you are still having difficulty.
Discussion Starter · #10 ·
All
It seems as though you find these useful, so I will maintain this file, and post when I add new textures. I didn't know if others would like these or not. As Dave noted, if you want individual looking boards with unique grain, or a highly figured large surface, for instance, then these will not do that. There are some resources for those out there on the net. These are meant for everyday use, they are small in size, so they won't bog down your computer much, and are easy to use so they invite use in quick and dirty projects.
Can I use these with SketchUp 7 on an Intel Mac?
Thanks Dave, and thank you Jim for sharing these textures.
I'm rapidly becoming a SketchUp zealot!
Oops, the Mac doesn't want to deal with those .skm files.
Thanks Dave.
Simultaneously, probably while you were typing your reply, I went to the SketchUp Help site and found the same directions. As soon as I got Jim's "Woodworking" folder into ~/Library/Application Support/SketchUp, the program recognized them. However, I did have to close and then restart SketchUp for that to happen.
This is really cool! Thanks for your due diligence.
Discussion Starter · #15 ·
DaveR
Thanks for your help with the texture files Dave. I am off to Hawaii tomorrow, but I think we have internet at the condo we are renting. It's the same one we rented last year and they had it. I have one project I am diddling around with, and will probably do some Sketchup stuff at odd moments, so you might hear from me. Hope all is well for the New Year….........
JKC
Looks like Dave got you squared away, hope you find the textures useful. If I have time, I may increase the number when I am in Hawaii. I like to do easy computer stuff early in the morning there. Making the textures is something I am used to, and it is kinda fun. Whenever I change the file I will post it with a blog entry.
Dave, I just downloaded the texture file and installed on my Mac, and it works great!! Thanks for developing this, its is a excellent addition to sketchup.
Pasul
In that case thanks to Jim for coming up with these texture files. I applied one (white oak) to a project I drew and it looks more realistic than with one of the textures that came with the sketchup download.
Paul
Discussion Starter · #18 ·
Paul
DaveR always helps out with the Sketchup stuff, which is most appreciated, so it gets a little confusing. Hope you enjoy the textures, I hope to make more over time…...........I'm in Hawaii on holiday….....Happy New Year….......
Hope the weather in Hawaii has been good!! I agree, Dave has been a lot of help to me. He and Daltxguy were very helpful in getting the cutlist up and running on my Mac. Great to have such knowledgeable people around to pick their brains when a question arises. Happy New Year.
Paul
Thanks Jim! Great Set of Materials
1 - 20 of 33 Posts
