Thanks for the compliments everyone.Mobile Tool Cart (with photos)
This post relates to a project I've been designing in my mind for a couple of years. I've had a lot of trouble figuring out exactly how I wanted to configure everything on my cart to effectively utilize 4 bench tools (miter saw saw, band saw, drill press, and bench grinder) while still fitting a lot of storage underneath and remaining mobile.
Here is what I built
It is about 3 feet tall (not counting the casters) is 4 feet wide, and is 20" deep. I used about 1 1/2 sheets of 3/4 inch poplar plywood and half a sheet of 1/4 ply for the back. I bought casters online. They seem to work well. I'll try to remember to post a a review of them.
I think the most important part of the build is the layout of the bench tools on the top. I can cut a 3 ft piece of lumber on the miter saw without extra support. I also have good access to the drill press and bandsaw with zero interference from other tools. All the dust collection of the tools point in the same direction so hooking up some hoses to a shop vac should be easy enough. Here is an overhead shot so you can see the layout.
I know I mentioned that it holds four bench tools. The fourth tool would be the bench grinder. That will temporarily be put right in front of the bandsaw. I think that will work fine for the occasional use it gets.
Here is a shot of the storage that the cart offers. This is more than any other item in my shop offers:
Finally, here is a shot of one of the sides. I plan to hang some tools on there like my framing square, speed square, some smaller tools like my mallet, chisels, etc. On the other side I'll probably hang my shop vac hoses, pipes, and attachments.
Vicki,
For the price, I like it. I don't remember off the top of my head, but I think it was a 10 inch. I think 14 is the usual size for being able to resaw wider boards. I'd upgrade to that in a heartbeat if it was in the budget, but for now I'm quite content. Because I plan to upgrade though, I am not investing much more in blades so I'm limited to the 2 high grade blades I bought at the outset.
