1 - 10 of 10 Posts
Discussion Starter · #1 ·
home made tools
I recently posted a platter on the projects page. I mentioned that I used a home made chatter tool on this. Karson asked that I post a picture of the chatter tool with the project. The photo shows an assortment of lathe tools, some home made some store bought. My challenge is to see how many lunberjocks can correctly identify the shop made tools. Correct answer will be posted sometime January 7. In the meantime you can see the tools with the project.
"here" http://lumberjocks.com/projects/12754
home made tools
No fair. You lock us woodworkers with no turning time to be left out in the cold. (30 deg this morning. I know because I was loading the smoker with chickens, rib tips and italian sausage)
home made tools
Karson, I'll be over later to help "unload" the smoker!
home made tools
The 3 with copper ferruls and (?) unfinished or finished with h2o poly and possibly the all metal one
home made tools
I like the use of copper pipe for ferrules and old files shaped into specialize tools. Have a bunch similar to yours. I have also used schedule 40 PVC pipe as a ferrule- not as pretty but seems to work OK.
Does the air tool have a unique function?
home made tools
I think its the tools with the copper furrules
Discussion Starter · #7 ·
Shop made turning tools
I recently posted a maple platter with chatter work done between the rim treatment. Karson asked that I post picture of the chatter tool. I posted a photo of several home made or shop altered tools that I use on the same project page. Several jocks volunteered guesses as to which tools were home made and which were not. Following is a recap of what each tool is from left to right:
1. bowl gouge custom ground the left wing is ground back very shallow enables me to get into tight spaces
2. old file ground down, heat tempered, fitted to a handle and used as a scraper
3. custom scraper cut from an old hand saw, ground down to shape, heat tempered. Attached to a piece of HSS rod that had a slot cut, drill and tapped to hold the scraper in place
4. piece of HSS rod sharpen to a V point
5. old gear tooth fitted to HHS bar that had slot cut drilled and tapped this is now a custom chatter tool
6. old window spline tool used as a chatter tool
7. old broken diamond point skew resharpened and profiled used as a parting tool
8. HSS bar steel ground to bedan shape
9. HSS bar steel ground to small spindle gouge
10. HSS bar steel ground to spindle gouge
11. high speed air saw with blade removed. I drilled a hole the size of a 16 penny framing nail in the blade holder. Cut the head off one end of a 16 penny framing nail and sharpened the other end. What used to be the head end of the nail is pushed into the hole that was drilled in the saw blade holder. This is now a high speed chatter tool.
Most the handles are salvaged from turning tools that I pick up at junk sales and flea markets. All those extra allen wrenches that are laying around become custom made small hollowing tools.
You can see the project and the tools by clicking here:
Great collection, Jeff!
Thanks Jeff.
Discussion Starter · #10 ·
I bought the high speed air saw at Harbor Freight on sale for $10.00 also picked up an high speed air powered mini-right angle drill that will take a 1/4" shaft. I use this to sand the inside of bowls. It is great for getting into tight spaces.
1 - 10 of 10 Posts
