1 - 13 of 13 Posts
Discussion Starter · #1 ·
Finally finished
I wanted to try my hand at making hand planes, the shop needs several.
Struggling with the design concept, I bought a book "Making Traditional Wooden Planes" by John M. Whelan, it was no novel but a good source of wood plane design info. It's worth reading if you're researching wooden hand planes.
Trying to keep the first plane simple I decided on making a small shoulder plane in the Krenov style.
Looking around my shop I found an old 1" chisel. It is harder than heck, so I took it apart and used my Dremel tool to narrow the tang to within about an inch of the edge.
old chisel-1
old chisel-3
Having already made 1 attempt, the results weren't as desired. I had however thicknessed the oak slabs for the infill and sides.
25 degrees was the chosen bedding angle and I cut the front and rear pieces.
fitting the infill
Using small pieces of double stick tape to hold the front and rear infills in place so I could fit the wedge.
fitting the wedge
I chose the lay-out and drilled and holes for hardwood reinforcing pegs through all three layers. I also drew up the relief cuts for the outer layers, and cut them out with my scoll saw.
glued and pegged
I used a piece of ash as the plane sole, fitted the rear portion, and glued it in place. After that dried I screwed the front in place taking this time to adjust the throat opening.
With all of the components at hand, I worked toward final fit-up. When the plane was completely assembled, I tensioned the wedge and started to flatten the front and rear portion of the sole. (Notice the change in sheen around the first inch or so near the mouth. That's how much the plane nose flexes with the wedge tightened).
tensioning the plane
I didn't glue the nose portion on so that I could replace it to compensate for wear. Any thinning of the plane sole will only make the mouth opening larger.
At this point the plane of technically complete, so while it was still all square I decided to add a front tote and either a provision for a rear tote or "tap button" so that hammer blows for adjustment doesn't damage the plane body
adding a tote
Now it's time to start smoothing the edges for comfort.
Smoothing the body
It's almost done but I have made a few shavings with it :cool:
it's alive
Now I have to learn the feel of adjusting the blade with hammer taps :cool:
Thanks for looking guys.
later,
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
That is a great plane! Thanks for sharing. I just love home made tools!
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
Super little plane.
Neat idea using the chisel for the blade.
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
Nice job. It's very satisfying when you make a tool and it actually works. Especially a handplane. Well done and thanks for the informative blog. Looking forward to your next one.
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
This is cool! I love how you used the old chisel as an iron.
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
Really impressive. I like the simplicity and it looks like it makes very nice shavings.
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
Thanks for the detailed pics. Having just made my first plane the bug has bitten. Will put this in my favorites list.
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
very nice
Thanks for sharing
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
I love handmade shop tools. This post was very interesting and you did a very good job of posting this and also have made an excellent plane. Thanks
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
I like it! Handy and very nicely made plane. I'm favoriting it for future reference. Thanks!
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
nothing like a handmade tool to use
well done
Dennis
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
Thanks for writing this, it is very clear and makes me want to find an old chisel and follow in your footsteps.
Finally finished
old chisel-1
old chisel-3
fitting the infill
fitting the wedge
glued and pegged
adding a tote
Smoothing the body
it's alive
later,
That's really nice. I think I might have to do as others have suggested and try this out for myself. Thanks for posting.
1 - 13 of 13 Posts
