Shop Cabinet build
8650 Views 21 Replies 6 Participants Last post by  robscastle
Start of a plan, and a mess
Things are getting messy, dis-organized, and just needs something better,,,
Motor vehicle Gas Machine Engineering Auto part
This entire area needs a "facelift" from the left side's messy pile..
Motor vehicle Helmet Automotive tire Wood Tool
All the way to the right..
Saw Gas Tool Machine Toolroom
Lines show the limits I can go to. IF a door would swing open on a new cabinet…it has to clear the plane til.
Wood Engineering Gas Machine Auto part
This side, nears to clear the drill press handles….
I can go until the ceiling joists, about 48" above the benchtop. And 36" in width….maybe. Depth?
Automotive tire Motor vehicle Automotive exterior Electrical wiring Gas
IF I clean off the "back porch", I'd have up to 4' deep….way too much for my arms…
I could slide the drill press to the left a bit…IF need be..
Automotive tire Motor vehicle Bumper Gas Automotive exterior
4" at the most..meh.
Plan is, the next time Menard's has a sale on 1×12 x 4' planks, I'm buying a stack of the best on the pallet….4 planks for the top, bottom and 2 sides. The rest will be for shelves, and any drawers. Doors will get a 2-4" deep frame around a panel. Panel will be used to hang a few tools on. Back of the cabinet will be T&G planks, so I can hang racks, hooks, shelves and such….May just buy a plank of Car Siding? Or, just make my own.
Some of the tools will get sorted through….keeping the better for use, rest over in a drawer…
Tool Wood Hand tool Set tool Metalworking hand tool
Need to sort through this drawer. Other piles need cleaned up..
Wood Gas Brick Wheel Automotive wheel system
Maybe find a better place for the cases? And NOT sitting with the laundry soap…
Gas Motor vehicle Audio equipment Electrical wiring Toy
So..about the first week of April….I'll get the lumber….and then we'll see how this goes…..
Stay tuned….
21 - 22 of 22 Posts
Plugs done, latches installed, stain applied
Update on that plug cutter, needed sharpened…and a skinny board for the vise on the drill press. was having trouble cutting the plugs..
Wood Gas Rectangle Road surface Font
Once they were made, a small screwdriver could pop them out, dab of glue on the narrow end, and tap into place..
Wood Tool Gas Hand tool Metalworking hand tool
let the glue set a bit. Chisel and a tap with the hammer to trim the plugs down…block plane to smooth things out.
Sharpened the cutter, today..
Hand tool Wood Tool Garden tool Line
And made the last 11 plugs. made a road trip to Lowes, and picked up the latches..
Rectangle Tints and shades Jewellery Font Metal
used a tool by Irwin, to start the screw holes..
Wood Wood stain Hardwood Art Metal
hard part was setting the latches so they closed the doors up tight..
Brown Wood Fixture Hardwood Wood stain
Then installed the last of the plugs, trimmed them flush, and sanded them smooth..
Brown Wood Natural material Hardwood Material property
IF you watch how the grain runs, plugs will almost disappear…almost…Then gave the door#2 a brushed on coat of Witch's Brew..
Wood Rectangle Wood stain Door Hardwood
Added a strip to the bottom edge of #2
Hand tool Wood Tool Metalworking hand tool Household hardware
And a couple more keepers for the braces..
Hand tool Product Wood Metalworking hand tool Tool
getting a bit crowded? Chisel rack also got a finish…to protect the steel from the Oak in the rack..
Wood Hand tool Tool Gas Metalworking hand tool
So…I think this is about ready to "open for business"?
Wood Gas Machine Metal Toolroom
just be sure to close the doors, when done..
Wood Rectangle Gas Wood stain Hardwood
Might be ready to post as a "Project"?
Insides are still a work in progress, trying to find the best way to stash things…without a crowd…
Wood Retail Display case Room Collection
Piling up in the corners…
Hand tool Wood Rebate plane Tool Set tool
Stay tuned..
used a needle file. just followed the angles already there.
Wood Automotive tire Gas Automotive wheel system Font
It had a lot of carbon build up, from burning it's way through Ash and Oak…
I had it clamp points upward in the vise. And just followed the angles.
Stay tuned..
I will have to give it a try …Thanks
21 - 22 of 22 Posts
