1 - 3 of 3 Posts
I'm working on several home projects that I need a little help with
I want to know how to make difficult cuts on a bead board panel
the most cost effective way of staining bathroom wall panels
*a cost effective way of making my own adjustable bar stool
Thanks any information will help
I've had success on the straight cuts with a table saw using a 60 tooth combo blade. Don't forget a zero clearance insert and "Table Saw cuts finish side up - Circular saw cuts finish side down". For tight spot cuts how about the cutting attachment on a fein multimaster or rockwell multi tool. I've had good results with mine. Staining is a chore in itself. The prep work is the most laborious. Although not a method I recommend for safety reasons, but a method used widely in days gone by, is fuming. If you are not familiar with the process, don't even consider it. But it was a way to "stain" large areas of exposed wood in a short period of time. Again, it is a chemical process and can be very dangerous. But boy, is the result stunning. Cost effective adjustable bar stool? How about a threaded wood center post?
1 - 3 of 3 Posts
