1 - 12 of 12 Posts
Discussion Starter · #1 ·
1st Blog
I started this project because I needed something to keep me busy until I decided on my next big project. I got the initial idea of doing a serving tray from the summer contest, not because I thought I could win but because it would give me something to do and also allow me to challenge myself.
The bottom is a glued up panel of soft maple with a 1/8" walnut inlay of walnut. I cut the inlay out using the router with a 1/8" bit held free hand cutting close to the line and then chiseling out the remaining material along the line. </a>[URL=http://s39.photobucket.com/albums/e166/gigantius/?action=view&current=IMG_5925.jpg]Photobucket
To help set it of and get some practice inlaying square silver wire I am going to inlay a peice of 22 g square silver wire around the edge. I had a little trouble initially getting the wire to fit snugly but after a couple of attempts it is staring to go in much easier. To make the channel tha holds the wire I cut of a peice of an old hacksaw blade and gound it down on a wheel to get it to match the size of the wire. Once the channel is cut is spread a little dab of yellow glue mixed with water to hold it in place.!IMG](2)!]http://i39.photobucket.com/albums/e166/gigantius/IMG_5927copy.jpg[/IMG](2)!:Photobucket
!IMG](3)!]http://i39.photobucket.com/albums/e166/gigantius/IMG_5932copy.jpg[/IMG](3)!:Photobucket
The sides were mide with some bubunga I had laying around. I mitered the corners and then added some maple keys. The two outside keys were made with the blade tilted at 15 degrees to give a unique look. I am thinking it might look better if I add another one outside of these near the edge at ~20-25 degrees, but I haven't decided for sure
(4)!]http://i39.photobucket.com/albums/e166/gigantius/IMG_5928copy.jpg[/IMG](4)![/URL]:Photobucket
Now I need to finish the handles, edge profile on the sides and finish it but that will have to wait until I get back from my fishing trip so I won't be finishing in time for the contest anyway. All comments and suggestions are welcomed.
Thanks for looking
1st Blog
Thanks for looking
oooh look at the angle of those corner pieces. Lovely
1st Blog
Thanks for looking
Very nice work.
1st Blog
Thanks for looking
Great build and blog. Thank you for sharing Glenn.
1st Blog
Thanks for looking
I love the angled splines. Such a simple thing, but a very striking effect when combined with the straight ones. Great work!
1st Blog
Thanks for looking
Great looking project Glenn. A masterpiece to please the Master, for sure.
Discussion Starter · #7 ·
Done
Well had a interesting time in the mountains. We had a bear that kept coming around, until the Game and fish finally came and took care of him after he broke into a couple of other cabins in the area. After that it was a relaxing time spent catching fish and enjoing the cool mountains
Anyway, back to the serving tray. I decided not to add any more keys for fear of messing up a good thing. The silver wire inlay proved to be a little more difficult than I anticipated but for the first time it turned out ok, but I definately need more practice.
For the handles i just milled up a couple small blocks of bubinga and attached them using dowls.
The finish is 3 coats of tung oil and 4 coats of wiped on poly.
Thanks for looking
Done
Thanks for looking
it sure is beautiful
flyfishing.. sure is beautiful :)
Haven't had a rod in my hands for the past couple years… maybe next year
Done
Thanks for looking
Interesting blog
Done
Thanks for looking
Man that is beautiful. Great job.
Done
Thanks for looking
I really like this tray. I think you've done an over the top job on it, it's terrific! Those splines really get me… that maple is perfect in there.
Done
Thanks for looking
The splines look great, and add a really nice touch as if to combine the clean lines of a miter joint and the beauty of a dovetail in the same joint.
1 - 12 of 12 Posts
