Does anyone remember when, around 1983, Sears began purchasing from Black & Decker and Skil for some of its power tools? Many of their power tools were still made by Singer (Sears power tools often had model numbers beginning with "315"), whose operations were purchased by Ryobi in the 1980s.
Manufacturer codes:
315 - Singer/Ryobi
135 - Skil
900 - Black & Decker
A lot of their industrial tools were made by these two firms.
SEARS CRAFTSMAN CROSS REFERENCE OF POWER TOOLS
9-1080 7-1/4" 2 HP Circular Saw (10 amps, 4600 RPM) - Skil 576 (type 2)
9-1089 5-1/2" Circular Saw (5 amps, 4000 RPM) - B&D 7300
9-10908 7-1/4" 2-1/8 HP Circular Saw (10 amps, 4600 RPM) - Skil 576 (type 4)
9-10912 7-1/4" 2-1/4 HP Circular Saw (10 amps, 4600 RPM) - Skil 5250
9-1112 3/8" Dual Range Variable Speed Reversing Cordless Drill & Screwdriver (7.2 volts, 0-250/750 RPM) - Skil 2016/2725
9-1116 3/8" Cordless Drill & Screwdriver, 2 Speed (3.6 volts, 100/300 RPM) - Skil 2323 (2007)
9-1120 Cordless Screwdriver (3.6 volts, 130 RPM) - Skil 2305 (2000)
9-11211 Cordless Inline Screwdriver (2.4 volts, 130 RPM) - Skil Twist 2105
9-11212 3/8" Cordless Drill/Screwdriver (2.4 volts, 300 RPM) - B&D 9021
9-11215 3/8" Cordless Drill/Screwdriver, 2 Speed (6 volts, 200/500 RPM) - B&D 9020 (type 5)
9-11770 Paint Peeler (11 amps) - B&D 9750 "Heat 'n' Strip"
9-17249 Cordless Jig Saw (9.6 volts, 2400 SPM) - B&D 9011
9-2701 Industrial 3/8" Variable Speed Reversing Drill (1/2 HP, 4.5 amps, 0-1200 RPM) - B&D 1180-09
9-2702 Industrial 3/8" Dual-Range Variable Speed Reversing Drill (1/3 HP, 3.5 amps, 0-1200/0-2500 RPM) - B&D 1170-10
9-2703 Industrial 3/8" Variable Speed Screwdriver/Drill (1/3 HP, 3.5 amps, 0-1200 RPM) - B&D 1575-10
9-2708 Industrial Variable Speed Reversing Drywall Screwdriver (with adjustable clutch) (1/2 HP, 4.5 amps, 0-2500 RPM) - B&D 2054-09
9-27100 Industrial 3/8" Variable Speed Reversing Drill (1/3 HP, 3.5 amps, 0-2000 RPM) - B&D 1175
9-27101 Industrial 3/8" Variable Speed Reversing Drill (1/2 HP, 4.5 amps, 0-1200 RPM) - B&D 1180, DeWalt DW103
9-27102 Industrial 3/8" Dual-Range Variable Speed Reversing Drill (1/2 HP, 4.5 amps, 0-1200/0-2500 RPM) - B&D 1170
9-27103 Industrial 3/8" Variable Speed Screwdriver/Drill (1/2 HP, 4.5 amps, 0-1200 RPM) - B&D 1575
9-27108 Industrial Versa-Clutch Variable Speed Reversing Drywall Screwdriver (1/2 HP, 4.5 amps, 0-2500 RPM) - B&D 2054, DeWalt DW254
9-2711 Industrial 1/2" Reversing Spade Handle Drill (3/4 HP, 6-7 amps, 450 RPM) - B&D 1321, DeWalt DW131
9-27110 Industrial Variable Speed Reversing Drywall Screwdriver (4.5 amps, 0-4000 RPM) - B&D 2034
9-27115 Industrial 3/8" Variable Speed Reversing Hammer Drill (5 amps, 0-3000 RPM, 0-48,000 BPM) - B&D 5070, DeWalt DW500
9-2712 Industrial 1/2" Variable Speed Reversing Drill (1/3 HP, 3.5 amps, 0-550 RPM) - B&D 1310-10
9-27121 Industrial 1/2" Variable Speed Reversing Drill (1/2 HP, 4.5 amps, 0-550 RPM) - B&D 1311
9-27122 Industrial 2-Speed Reciprocating Saw (3/4 HP, 6 amps, 1800/2400 SPM) - B&D 3103/3108
9-27124 Industrial 1/2" Reversing Spade Handle Drill (7 amps, 450 RPM) - B&D 1317/2610, DeWalt DW130
9-27126 Industrial Variable Speed Reciprocating Saw (3/4 HP, 6 amps, 0-1800/2400 SPM) - B&D 3104/3105, DeWalt DW304
9-27131 Industrial 3/8" Cordless Drill (9.6 volts, 800 RPM) - B&D 1950
9-27133 Industrial 3/8" Cordless Screwdriver/Drill (with adjustable clutch) (9.6 volts, 800 RPM) - B&D 1980
9-2717 Industrial 3/8" Shorty/Stubby Right Angle Drill (1/6 HP, 2.8 amps, 1200 RPM) - B&D 1165/6016
9-2721 Industrial 2-Speed Reciprocating Saw Kit (3/4 HP, 6 amps, 1800/2400 SPM) - B&D 3103-09
9-2724 Industrial 2-Speed Orbital Action Jig Saw (4.5 amps, 2400/3100 SPM) - B&D 3159-10
9-27241 Industrial 2-Speed Orbital Action Jig Saw (4.5 amps, 2400/3100 SPM) - B&D 3159
9-2725 Industrial Variable Speed Orbital Action Jig Saw (4.5 amps, 0-3100 SPM) - B&D 3157-10
9-27251 Industrial Variable Speed Orbital Action Jig Saw (4.5 amps, 0-3100 SPM) - B&D 3157/3158, DeWalt DW318
9-2750 Industrial 7-1/4" Circular Saw (2-1/4 HP, 12 amps, 5500 RPM) - Skil 553/5650 (replaced by 9-27541)
9-2751 Industrial 7-1/4" Drop Foot Circular Saw (2-1/2 HP, 13 amps, 5800 RPM) - Skil 807/5750
9-27512 Industrial 1/2" Impact Wrench (7.5 amps, 2700 IPM) - B&D 2214/2670
9-2753 Industrial 10-1/4" Drop Foot Circular Saw (2-3/4 HP, 15 amps, 5200 RPM) - Skil 810/5790/HD5790
9-2754 Industrial 5-1/2" Trim Saw (4/5 HP, 6.5 amps, 4000 RPM) - Skil 551/5510/HD5510
9-27541 Industrial 7-1/4" Circular Saw (2-1/3 HP, 12 amps, 5500 RPM) - Skil 5656
9-2760 Industrial 7-1/4" Worm Drive Circular Saw (2-1/2 HP, 13 amps, 4300 RPM) - B&D 7395/3051
9-2761 Industrial 7-1/4" Worm Drive Circular Saw (2-1/3 HP, 13 amps, 4400 RPM) - Skil 77/HD77
9-2770 Industrial 4-1/2" Right Angle Grinder (3/4 HP, 4.5 amps, 12000 RPM) - Skil 915
9-2774 Industrial 7" Heavy Duty Grinder (3 HP, 13 amps, 5000 RPM) - Skil 987
9-2776 Industrial 3" x 24" Worm Drive Belt Sander (12 amps, 600 SFPM) - Skil 449
9-2791 Industrial 3/8" Cordless Reversing Drill (9.6 volts, 800 RPM) - B&D 1940
I am also creating this topic as if to find out whether or not any of you have any pictures of any of the above items after all those years ago.
Regards,
Ben (BDFan1981)
EDIT: 12-25-2013
Manufacturer codes:
315 - Singer/Ryobi
135 - Skil
Regards,
Ben (BDFan1981)
EDIT: 12-25-2013
