Sounds a bit fishy to me Dick,
Maybe Dave Polaschek can help with this one he is pressure pot man
That's what is on my chicago - walnutMy Chicago cutlery has black walnut handles / scales. They also sell cherry. Ours never had a finish. I just oil them with mineral oil. 35 years old and counting.
- ibewjon
Thanks Nick - I appreciate the offer but I have to think about it a while.Dick, we have a vacuum pot and Cactus juice, and a pressure pot if you have resin and want to try one or both some time. Just give me a call if you want to experiment with them.
Nick
- Nick424
I just looked and I've got 2 blocks of Olive wood 8 1/2" x 13" x 1 1/2" thick plus some more smaller hunks laying around. That should be plenty for what I had in mind. Problem now is that it all seems so daunting that I'm not sure I even want to attempt the project because it's so far out of my comfort zone.I ve made lots of knives with wood scales and never had a failure yet. The wood type is a consideration for sure but so is the environment. Kitchen knife handles see a lot more moisture and acid (like from cutting fruits and vegetables) than a shop or field knife. If you were making a single knife, I d say just try whatever you want because it s easy to replace damaged scales. But a full set is a different story since there s significantly more work involved.
If it were my set of knives, I d probably get the wood stabilized before using it just to be on the safe side. Sounds like Nick 424 is set up to help you out with that. If he can t for some reason though and if Dave P keeps dragging his feet on setting his up ;-p, shoot me a message and I ll put you in touch with another LJ that should be able to square you away.
If you happened to have enough of that Olive wood to handle your knives, that would be my choice. That stuff makes dead sexy knife scales! But even that, I would try to get stabilized for kitchen knives. It s not rated particularly durable against moisture.
- HokieKen
