1 - 8 of 8 Posts
· Registered
Discussion Starter · #1 ·
Designing the Till
As my hand-tool usage has grown, I have gradually expanded my collection of saws. I started with three (rip, crosscut, and back) and over time I've added other restored specialty saws until I have no place to put them all. At that point I realized I had to build a saw till.
My workshop is in a shared basement of a multi-apartment building. While normally the other residents of my building are quite nice and respectfully don't mess with my stuff (I don't mess with theirs), I wanted a till that would deter easily-tempted eyes from my tools. Ideally I'd also be able to lock it.
To accomplish this, I began surveying the saw tills that others have done. There are several designs out there that use rubber balls (like Timberframe Tool's example) to hold the saws in place. I have never cared for this design as it just seemed hokey to me. I don't want to rely on plastic children's toys to support and protect my antique saws.
I really like Dan's version but unfortunately, it's not enclosed. I loved Phil's design but that's waaaay too big for my tiny little shop. Finally, Old Wolf's was closer to what I was looking for. Again, it wasn't enclosed, but at least the basic shape worked.
So, I came up with my own design. I made the design mirror the toolbox I made previously. I wanted it to sit on top of the toolchest, but I was worried about the depth of till necessary to keep the saws vertical. I ran some quick numbers and I thought I could get everything within 12" of depth, but I needed to test. So I got some blue tape, laid down various designs on my dining room floor and tested them out. After doing so, I figured that I could build the till with a 10" depth and a 30" height.
Brown Wood Material property Wood stain Hardwood
I chose to mount the saws teeth-out for identification purposes. A couple of my saws have almost identical handles and it's just easier to me to look at teeth rather than try to memorize handles.
While most other designs call for a drawer of some kind, I decided against it mainly due to height restrictions. The till was slready going to be pretty high and I didn't want to have the strain to pull down a saw. Besides, since my design has doors, I can mount sharpening-related items there.
Now that I had my design in hand it was time to get started!
· Registered
Designing the Till
I am excited to see this develop. I am currently figuring out how my till is going to work out (it will be a section of my tool chest). I have one 28" bow saw that really is messing up my design.
Nice looking Disston, how does it sound when you cut?
· Registered
Designing the Till
I particularly love the step of laying it all down it all down with tape to figure out if the dimensions will work. That's awesome.
· Registered
Discussion Starter · #4 ·
Starting the build
The basic frame for my saw till couldn't be simpler: four pieces of 10" wide poplar. The bottom is simply screwed into the sides and the top is attached with recessed figure 8s.
To support the saws, I created two levels of slotted crossbars. They are mortised into the sides of the carcase. I cut repetitive slots across them to allow me to insert a saw into them. Through trial and error I decided that having a slot every two inches gave me just enough room to store the saws and still get my hand in there to pull one out. I then built a 2 1/2" high support along the bottom of the case to force the saws to sit at a tilt. As explained previously, I keep my saws with the teeth pointed outwards. During the planning stage I noticed that doing so allowed me to position the saws at a higher angle than I would have been able to do had the teeth been pointed inwards.
Wood Floor Gas Composite material Glass
Once I got the basic case together I used my trusty Stanley 48 plane to put together a series of tongue and groove back panels.
Wood Bicycle part Gas Auto part Hardwood
Trust me, by the end of it I was a sweaty mess.
Furniture Table Wood Automotive tire Hardwood
I then mounted the panels and screwed them into the carcase, allowing a little room for expansion and contraction. My shop is in a basement, so it stays somewhat stable year-round, but there is still more variability than I would have liked.
Rectangle Wood Interior design Shade Floor
I then put everything in for a test-fit….
Wood Floor Flooring Hardwood Wood stain
Now I just need to get up off my butt and go buy some more poplar to fashion the doors then time to fashion mounts for my saw vise, files, and sets!
· Registered
Starting the build
Loving this build man. Poplar is a such a treat to work by hand, especially when you can find wide boards.
Keep up the good work. And make sure to drink lots of water you big sweaty mess.
· Registered
Starting the build
I hadn't thought of facing the teeth outward, I am following along for any lessons I can learn from your build since I've got to get my saws organized soon. Thanks.
· Registered
Starting the build
Very nice.
· Registered
Starting the build
That's excellent… you just helped me figure out how I was going to store my saws in that shop cabinet I just built!
Nicely done… thanks!
1 - 8 of 8 Posts
