Running a Hard Air Line for Compressor.
I was asked to write up a blog for this project, not a woodworking one though, but it does go with woodworking.
From the planning of my shop build a had plans to install a hard air line for the compressor. I park the compressor up on the Loft with a dicated circuit which had a pilot switch below. Most of the time I keep the regulator set at 100 PSI. Main use is trim nailer and blow stuff off.
I am in the process of refacing some cabinets, and decided to spray them using HVLP System. I Saud it's time to run the air line first.
So I started out with most of the parts today, dud need a trip to Lowe's fir a few other things. I chose 1/2" copper for the lines. With the standard 1/4 quick disconnects.
From the compressor I used a 3/8" rubber line rated at 300 PSI, connecting it the copper line with a quick disconnect. This is up on the loft, and my reasoning was to isolate any vibrations from the compressor.
From the loft I came down the wall. I put a "Tee" in and made a drop directly from the tank pressure which I bumped up to 110 PSI, auto use if needed. From there I ran into a regulator and a filter, then back up the wall.
From there I ran the line 2/3rd length of the shop, with a "Tee" at the first beam and an Elbow at the 2nd beam.
I then ran a line under each beam to the shop center and brought the line down to a quick disconnect.
1st beam.
2nd beam.
Close up of drop below beams. I have the disconnect, then I installed a ball valve in the event I need to clear any water out of the lines.
Everything is hooked up and running, with no known leaks. It's been a good 10 years since I have sweated copper. Not pretty but solid, I did get better the more I did.
And I managed to get the shop clean, so some updated shop photos.
Northwest corner
Northeast corner
Southeast corner
Southwest corner
Thanks for reading and comments are always welcome and appreciated.
1st beam.
2nd beam.
Northwest corner
Northeast corner
Southeast corner
Southwest corner
