1 - 20 of 35 Posts
Discussion Starter · #1 ·
Routing inlays
Hi all;
Recently I needed to cut some wenge veneer to inlay into a Demilune table. The table is part of a private veneer course I'm teaching, and will be included in either an e-book, or a printed book. The fellow is writting it as I'm teaching, taking pictures as we go. One of the projects in the book has an wenge inlay.
If you've ever worked with wenge, you know it's a bit of a nasty wood to work with. Cutting it with a knife is difficult, as the wood tends to split. Since I'm doing a 1/4" wide inlay on a half round, and my usual tools weren't working out too well I had to come up with a different way.
I got to thinking a router would be a good way to go. I decided to make use of a Dremel set I got a few years back, since it was small and easily managed. It did have an edge quide, which doubled as a circle cutter but it was a bit cumbersome to use.
I decided to make an adapter to fit the base of the router, using a piece of 1" thick lexan. I threaded it to accept a Veritas compass beam.
Wood Rectangle Font Beige Plywood
The compass beam is very nice, and will making circles as small as 1", and as large as 40", with the pieces that come with it. It has small sections of rod that screw together allowing different lengths.
Tool Wood Gas Rectangle Metal
Using a jig and laminate trimmer, I routed a ledge to sit on the router base, giving it a bit more stability.
Wood Automotive tire Floor Flooring Gas
Then I drilled and tapped the edge for the compass beam.
Wood Milling Drilling Gas Machine
I then mounted it to an existing hole on the base of the router. The lexan fits tightly against a piece in the casting, so it doesn't pivot. I'm happy to say it was worth the effort, as it worked quite well.
Wood Gas Plumbing fixture Metal Mechanical fan
Sports equipment Gas Tool Personal protective equipment Recreation
Wood Table Measuring instrument Wood stain Flooring
Table Furniture Wood Tree Tints and shades
Table Wood Folk instrument Hardwood Wood stain
Wood Desk Table Door Floor
The woods are Figured Black Limba, Swiss Pear, and Wenge
Thanks for looking.
Routing inlays
Hi all;
Thanks for looking.
saweeeeeeeeeet looking table.
Routing inlays
Hi all;
Thanks for looking.
Thanks for the tutorial, Lee. That's a nice adapter for the router. I guess most of what I know about veneering, I learned from you. Beautiful table. Thanks for the post.
Routing inlays
Hi all;
Thanks for looking.
very nice. the colors work very well together.
Routing inlays
Hi all;
Thanks for looking.
Nice work Lee.
Routing inlays
Hi all;
Thanks for looking.
Absolutely beautiful work, Lee. Thanks for sharing!
Routing inlays
Hi all;
Thanks for looking.
You know I love your work Lee, this is no exception, how are you, I need to call and say hi. It's been awhile.
Routing inlays
Hi all;
Thanks for looking.
Lee Beautiful and a great jig tip.
You da man!!
In Loving Memory
Routing inlays
Hi all;
Thanks for looking.
Lee, there is nothing like a great jig that works well. An excellent result on the table buddy.
Routing inlays
Hi all;
Thanks for looking.
oh come on lee, couldnt ya just slap this table together…ha..great job and a great way to figure out your inlay…its a beautiful table…
Routing inlays
Hi all;
Thanks for looking.
Great idea, Lee, and stunning work as always.
Routing inlays
Hi all;
Thanks for looking.
Thanks for the information about the technique, the adapter, and the compass beam. All very useful. The table is pretty great too. Nice job!
In Loving Memory
Routing inlays
Hi all;
Thanks for looking.
More than one way to skin a cat, huh?
Great looking table. Swiss pear is a great wood to work with, isn't it? I wish I could afford it to use it all the time.
Routing inlays
Hi all;
Thanks for looking.
Great looking table. Very nice work.
Routing inlays
Hi all;
Thanks for looking.
excellent work as always lee
and a great trammel
and adaption for it
Routing inlays
Hi all;
Thanks for looking.
As everyone said, it is certainly a beautiful table. Thanks so much for the tutorial on how you accomplished it. It is absolutely gorgeous! Your work is always top notch!
Sheila
Routing inlays
Hi all;
Thanks for looking.
Great work and an imaginative and effective set up. I have worked a bit with wenge ans swore never again - maybe I will rethink that.
Great post
Don
Discussion Starter · #18 ·
Routing inlays
Hi all;
Thanks for looking.
Hi all;
Thank you for the kind comments.
Routing inlays
Hi all;
Thanks for looking.
Hey Lee,
Fantastic. Not only great inlay, but a fine table to boot.
Someday…. someday.
Steve
Routing inlays
Hi all;
Thanks for looking.
Nice choice of woods Lee. What more can be said, you do beautiful work. Let us know when that book becomes available.
1 - 20 of 35 Posts
