Was routing a groove in an (red) oak board. The bit is a Freud 1/2" straight bit, 2 carbide cutters, and the groove was less than 1/4" deep, probably closer to 3/16". Router (3 hp, no variable speed) was in a router table and fence was about 1/2" from bit (so bit was obscured from view). Bit, although a few years old, has only been used a few times and this cut was the first of the day. Forward pressure was enough to cut a steady pace and was not forced.
After only about an inch into the cut, I heard a bang. Stopped pushing, withdrew the wood and turned off the router. Found a fairly large chip missing from the tip of the bit, triangular shaped, about 1/4" in length along the cutting edge and about the same length along the top edge (so the broken edge was between the two 90 degree edges), with that chip now laying on the table.
The workpiece was damaged to the point that I cannot use it.
So, a couple questions. I am unable to get another bit at the moment, so what is the chance I can continue to use the bit for a couple more cuts? And, has anyone had any experience with getting Freud to replace a broken bit? I have done quite a bit of routing over the years and have never experienced a bit breaking like this. Although I doubt I would be able to prove it, I don't believe my technique had anything to do with this issue. In fact, I was initially going to go a bit deeper into the wood, but decided not to and changed it to take a bit lighter cut.
Any input would be appreciated.
Marv
Marv
