Big walnut slab destined for my entryway as a bench. I laid down a thorough coat of Watco Danish Oil (yes, yes, applied correctly, dried and cured for 3 weeks, looked awesome), and being happy with the appearance but not durability, I decided I would fill the pores to improve the appearance of the urethane finish I was planning for (at the time was Arm-R-Seal satin which I thought looked kinda weird over the open pore structure; this was before I changed the plan from ARS to Enduro-Var II since it comes in flat, which was my original preference since it doesn't look as bad over irregularly-grainy surfaces).
I applied Aqua Coat Clear Grain Filler as instructed, 3 coats, sufficient dry-time, after which I applied a thin coat of Enduro-Var II flat. It was then that I noticed that the Aqua Coat was not clear as much as it was a light brown - something I noticed when I was applying/scraping/squeegeeing it along the slab surface. Based on previous tests I thought it would still dry clear (I was wrong). So now I have a smooth flat surface with a water-based urethane covering what appear to be dust-filled pores in an otherwise lovely piece of walnut. Bummer.
So, how do I remove the Aqua Coat from the pores? Any recommendations on strippers, or am I destined to be the new owner of an electric hand-planer, or test how flat I can keep the surface while sanding 1/32-1/16" off with my 6" ROS 60 grit? I don't think removing the single coat of EVII will be difficult since it was applied to a pore-filled flat surface - I'm more worried about how to get tainted grain filler out without having to remove all that wood...
I really appreciate any input. And if it does come down to taking the wood down a bit, advice on how best to do that (short of replaning) would be appreciated.
