Reclaimed Glory
31521 Views 89 Replies 39 Participants Last post by  palaswood
14
Salvaged Mystery Wood
Hi Wood lovers - I came upon some "trash" wood with some casters attached (not sure what it once was) discarded in a dumpster behind a renovator's shop destined for the landfill, but fate would have other plans for it. The wood seemed in great shape with some good character beneath, so I rescued it, bundled it up, and rode it home on my bicycle (yes, thats right).
Wood Wood stain Bottle Hardwood Flooring
When I got it home and sanded it down, I was AMAZED at the figure of these boards. Problem is I couldn't figure out what species it is (see what I did there), and it soon drove me mad (not stark raving, but close).
Wood Wood stain Floor Composite material Flooring
I hand sanded down a portion of the most striking board to 400 grit and rubbed it lightly with Watco rejuvinating oil to show the gorgeous grain pattern. Wow!
Brown Wood Automotive tire Table Flooring
(**Pic above has been changed after I remembered I used an instagram filter on the previous one, which really doesnt help the identification process, sorry guys. This is the original image)
I became so caught up in identifying this wood, as some of you may have seen my forum topic on this, that I neglected the wood itself, leaving it in its gnarly found condition for weeks.
Everyone was really helpful on the forums: suggestions ranged from Black Locust/Honey Locust to Osage Orange or a tropical variety, Lauan (Meranti/Phillipine Mahogany). I'm not certain what it is and due to my discovery of this band of deep orange in another of the boards from the same lot, im now more confused. Recent comments suggest meranti/lauan, and rule out osage orange.
Water Wood Road surface Asphalt Flooring
I cleaned up another couple of boards to see that we may be dealing with 2 species of wood here anyway.
Brown Rectangle Wood Floor Flooring
I have it in my mind to turn this into a tabletop. I'm really excited to get a replacement hook & loop pad for the Makita 5" orbital sander (it fell apart on me one early summer afternoon, it was quite old), and the Black & Decker sandstorm locked up (don't buy this POS), so I did it all by hand.
Hand sanding, if you're not used to it, is a great workout. Make sure your doors and windows are open, for dust sure, but more because you WILL be sweating. But I did notice a distinct lack of gouges in the wood from using the power tools to sand, and I was pleased with the results. Very pleased.
Brown Wood Grey Flooring Floor
Check out the wavy grain pattern - I was so stoked to uncover this:
Grey Wood Tints and shades Pattern Wool
Stay tuned for further progress, and PLEASE, if you have a definitive answer as to what species I may be dealing with, let me know.
-Joseph, Lake Forest, CA
1 - 20 of 90 Posts
14
free casters and nice wood. It's a good day.
Edit: and I have no idea on species.
Are they still casters if they don't swivel? makes me think its from a bedframe… A good day indeed!
From looking at the poures in the grain it looks like Oak.
Good score.
I have a trike with a basket on the back with two dog power when they pull (which is all the time).
Not sure what wood it is but I vote against Osage Orange (hedge) as it doesn't have pores like your wood has. It is VERY heavy and tight grained.
Thanks for the help gfadvm.
Hmmm…. looks a lot like the rubber wood you see in lots of imported stuff. (wood from rubber trees). I agree with gfadvm, I think it's not Osage.
Looks a ton like meranti/luan. It would be fairly lightweight if it is.
It's definitely not Osage Orange.
Found wood It's the best!!
I agree terry. Check out my blog posts for testament to that VERY FACT!
I agree with Rubber Wood. Looks just like my kitchen table (made in Vietnam).
Reclaimed Construction Lumber Bench
So I'm working on another project: I have some various pieces of what I believe is Douglas Fir, some 4×4x4 posts, shorter 4×4 pieces and a nice Pine slab (I think, could be Fir as well) from a construction project nearby that was advertised as "free firewood" after they were done pouring the concrete, & why you would wanna burn such great wood, I'll never know.
I set the slab up on some 12 inch 4×4s to get a feel for how it might look.
Wood Ruler Office ruler Rectangle Wood stain
I've hand-sanded the posts to 400 grit (started with 80 > 120/150 > 220 > 320 > 400) and applied a couple coats of tung oil (steel wool in between applications). I plan on putting on at least 4 more coats, but we'll see how it comes out.
These posts have great character and seem quite old. One even has some great burn marks as if it was in a fire previously.
Wood Floor Rectangle Flooring Wood stain
The color and figure of what will be the bench seat really pleases me. This is without the flash, for a more true representation of the color. (although its blurry)
Wood Table Flooring Wood stain Hardwood
I'd like to use this bench in the backyard patio, so I may need to look into waterproofing it. Will Tung Oil do that for me? Please someone comment on that, if you know how many coats i'll need or if i need a sealer too. I have Danish oil too (Watco).
I'm gonna be going for a chunky, simplistic design. I want it to be rock solid and yet actually quite comfortable.
I'm wondering if I should slant the bench seat back, about 7 degrees, for comfort. We shall see. Any ideas?
From what I've seen comfort has a lot to do with getting the seat height correct. Find a chair that feels comfortable to you and borrow the dimensions from that. Height, slant, etc.
May want to look into Thompson's water seal deck sealant for water proofing. It won't be 100% water proof, and will need to be refreshed occasionally, but will probably do that trick.
Thanks Steve. I forgot about Thompson's water seal, duh. I'm a novice, but I remember seeing those commercials way back when I was a boy watching This Old House.
For the seat height, I know thats the most important. I found that for me, about 16,17 inches is the most comfortable. I'm gonna have to do an extended test before I start cutting; I plan on spending a good deal of time on that bench, book reading in the sun, etc. Nice tip on borrowing dimensions from a comfy chair.
My girlfriend is always on me about when I'm going to actually make something, but she doesnt understand how pleasing just acquiring, choosing and preparing the wood can be, before actually taking a saw to it.
I came up on a few more pieces from where I got the upper post in the pic. I think they may have come from a mechanic shop or something, cause they are layered in grease and gunk.
When I found them, 4 pieces in all, I could only take the long post on my bicycle (I've gotten good at balancing the beams on my handlebars), so I stashed the other pieces in a bush. I had a buddy of mine pick them up for me one night when he was giving me a lift home from our BJJ gym (thats Brazilian Jiu-Jitsu), and I left them in his car.
He stashed them for me in an alley and I got them today. I'm gonna clean them up and see how I can add them to this project.
Wood Hardwood Wood stain Flooring Lumber
here's a pic
Will found oak ladder lead to new heights of woodworking adventure? Lets find out
Riding home I came upon a discarded solid oak ladder from a nice bunk bed bed I'm sure. ( I love Orange County).
Plant Sky Bicycle Wheel Tire
I parked the the bike to inspect it closer
Plant Natural material Wood Rectangle Grass
It was super heavy but I managed to balance it on my handlebars and ride it home. (not my first rodeo)
Wood Floor Natural material Plank Wood stain
I got it onto my workbench and sanded down a section, put a lil oil on
Brown Table Wood Flooring Floor
The posts and rungs are laminated but all in all, not too shabby. gonna think about how to use the lumber here. The possibilites are ENDless…
Great snag! That's got 'legs' written all over it. Legs for a table, legs for a bench. Could also be a good re-saw candidate into smaller lumber. Some of the pieces look like they have some quatersawn ray flecks.
Great find, I have taken old cabinet doors that are maple and re-used them for boxes. One pass through the planer and the old finish is gone.
I saw the "legs" in there too, I am thinking about turning the rung pieces. Is oak workable on a lathe? I'm into so many projects right now this might have to sit awhile though.
1 - 20 of 90 Posts
