Raised Panel Door Calculator
52634 Views 123 Replies 68 Participants Last post by  hanna3368
2
Rectangle Product Azure Font Screenshot
I wrote a raised panel door calculator using Excel. I included detailed graphics and calculations. I have been told by my woodworking friends that it is an EXCELLENT spreadsheet that is very clear and simple to use. This raised panel door calculator is a Microsoft Excel file that will take any size cabinet opening and automatically calculate the overall door size, all individual door part sizes and the required board feet. It calculates three types of doors, single doors, single doors with double panels and double doors.
I would like to share my work with the forum but I am unclear as to how I can do this? I do not want to give out my e-mail address to folks I do not know. Any suggestions?
Jerry
1 - 20 of 124 Posts
I for one would love to have a copy of it, but I understand your reluctance to pass your email addy around. Maybe you could open a gmail email account to use for incoming inquiries. If you post it, be sure to use dot instead of ., c o m instead of com, etc. to thwart the spammers.
you could host in on google documents and share the link they give for the document. That shouldn't share your email address with those viewing it, and you can make it so others can view the document, but not save it. If they want, they could save it to their computer as well.
Sounds interesting, could you post it using Google documents?
"Sounds interesting, could you post it using Google documents?"
I will look into that soon. Jerry
There is also a service called Box Net. You get 5G of free storage.
i did the same thing. wrote an excell sheet that tells you all the dimensions needed to make raised panels and it works to a tee! i just told people to send me an email and i would send it back to them. Worked out nicely.
If you want the spreadsheet send me a private message with your e-mail address and I will send it to you.
Todd and Jerry, I'm sending you both a pm with my email address. I'll host them both and share the link for everyone if you would like. If either of you have gmail, I will set it up so you have the ability to edit the documents as well.
Ok, here is a link to the file that Jerry made. It can't be used online as it doesn't convert over, but you are able to download it to your computer to use it from there. Jerry, if at any time you update it and want me to update the version, just let me know. Thanks for sharing your work
https://docs.google.com/leaf?id=0B8gl7F3Xqk-zYzI1ZWZjMzUtMzRjZS00YmI3LWE0MzAtODcxNDJlMjNmNTQ3&hl=en&authkey=CP6Y0-YN
Pawky,
I just tried your "Google link"
and got the following message:
Sorry, the page (or document) you have requested is not available.
Please check the address and try again.
Am I doing something wrong?
I really would like a copy of that spreadsheet.
Thanks
Jim Davenport
Sorry about that Jim. Hopefully this link works. Let me know if you have any further problems and I'll try to fix it. Thanks
I tried the link - you need to be a registered googlehead in order to download it. OK for me, but not, I suspect, for everyone.
When I want to share documents rather than pictures I use…
http://www.4shared.com/
Oh, and
http://tinyurl.com/
would let you make that massive massive url into a small one - one that you can remember even!
(Ah, and the instructions say "A5 & B5" - should be "A6 & B6")
Thanks Jerry.
Thanks Pawky
Got it in one. I'm on Google.
Jamie
That is really nice of you guys to do that. Too bad I don't make raised panel doors. Maybe now that you have all the work done, maybe I shouid start planning something that needs them ;-)) i'm going to favorite this just in case.
"(Ah, and the instructions say "A5 & B5" - should be "A6 & B6")"
OK, I fixed that. If anyone else finds errors please let me know. I will send Pakwy the revision.
Thanks
Jerry, that is definitely an excellent spreadsheet you've designed. Thanks for sharing it, and thanks to Pawky for posting it!
Jerry & Pawky,
Thank you so much.
I really appreciate the effort that went into the creation and listing of this wonderful spreadsheet.
New kitchen cabinets are on my list. I think this will be a big help.
I have a question.
I want to make cathedral style panels for my doors.
If I use the thinnest part of the rail as my rail width, I think that that would work for defining
my panel dimensions. Do you think that that would work?
Thanks again for your effort.
Jim
I considered making a tab for arched doors but the only difference between a regular door and an arched door is the width of the upper rail…all other parts have the same dimentions. I am not an expert here by any means but it seems to me that the upper rail on arched doors is somewhere between 3 ¼ to 4 ¼ inches wide depending on the significance of the arch. I suppose it could be even wider for an even more dramatic arch.
After cutting out the arched pattern from the upper rail, the thinnest part of the upper rail should still be 2 ¼ inches wide. The panel dimensions will be the same as a regular door but you will end up with more waste cutting out the arch.
The calculator can be used for arched doors. Once you get all your dimensions… simply increase the width of the upper rail to accommodate the arch that you desire.
Nice work on this spreadsheet, Jerry! It should come in handy.
Pawky - thanks for posting it.
1 - 20 of 124 Posts
