1 - 5 of 5 Posts
Is it just me or does the Pearl hide glue stink like dead animal much worse than Granular hide glue.
I use the pearl for veneering because it gives you more time before it gel's and granular I use for joints with a shorter dry time. Just wondering if anybody's has a good nose like myself?
I have only used ground hide from Homestead Finishing (192g strength), and Liquid Hide from titebond.
I did add urea when I worked on a chair restoration to lengthen the set time.
Have heard that burned glue will stink. Used to be a common thing in old shops to keep the glue in a double walled gluepot, but add hide glue to the water bath.
If your gluepot water ran out, you would smell the glue burning, and know to go add more water.
Hi Dennis. If the granular hide glue you are using is Milligan and Higgins 192 gm, I believe that they add a fungus deterrent that helps keep it sweet. I've never had a problem with it. I have used the pearl stuff from Lee Valley (180 gm I think) and didn't notice any particular worse smell but maybe yours is getting "ripe". If you want more time for veneering (but not hammer veneering) I would recommend Old Brown Glue.
If you want definitive answers about HHG, give Patrick or Patrice a call at ASFM or the Old Brown Glue site. Nobody knows more about animal protein glues than they do.
Hmmmm. Maybe the dead-er the animal the stickier the glue . . . just sayin' . . . }:0~
1 - 5 of 5 Posts
