It seems kind of impractical to make cuts like either of the cuts called rift or quarter sawn in those diagrams. You will see various diagrams about what rift and quarter sawn are and some show different definitions of the various cuts. Both of the quarter and rift sawn cuts you show above I would have called radial cut. I would think that either of those would be tough to do without special work holding and you will waste a lot of wood if you can even pull off what they call the rift cut. Also, the (radial) rift sawn cut above may actually reduce the ray fleck appearance when cutting oak.
I do my quarter sawn cuts like this. Much easier and probably how old time saw mills did it:
I learned that the reddish boards are the quarter sawn pieces and the rest were rift sawn. This image from Wikipedia is how I learned it in my logging and milling class in college:
