Jay, I used to pull a stock trailer and found the aluminum ones to be preferable since they were the lightest. There are a number of manufacturers. I had a Featherlite and was very happy with it.
A V-nose will improve gas mileage a bit. You probably won't want one large enough or carry enough weight for dual axles and the extra axle adds weight. I would definitely get stabilizer bars. If you have to load and unload by yourself, get a ramp door, but the step usually isn't much of a bother and the ramp can be a nuisance. I definitely recommend brakes.
Seriously, I would probably go with a proportional brake because of the distances you will tow. Finally, depending on the dimensions of the furniture you might transport, consider a low profile.
The main issue with trailers is that the tail/brake lights don't work. That is almost always due to a lack of or a poor ground. HTH
