Hmm, MrSkills first post is to rant about PM issues?
Ok, thanks for sharing. IMHO shipping issues are widespread. Have never received a mobile base package that didn't have at least a little paint missing due rubbing, or box damage.
Have no experience with these two jointer models.
Am a fan of Grizzly machines. Most of their tools are mode in Taiwan these days, thanks to China tariffs a few years ago. Taiwan suppliers they use, have been making the same WW machines for 40 years. They get minor updates, tweaks and cost reductions; but they have making them so long; they also know what NOT to change. Grizzly parts support is phenomenal. When a tool is subpar, it goes out of stock and just disappears.
Many years back when I was touring mfg plant in Taiwan, saw both green and yellow jointers sitting in same holding area, waiting to be boxed for shipping. So I have never believed that PM was significantly better?
The key difference has always been PM uses Baldor motors. But since these are often made in same factories as motors used by Grizzly. The key motor difference is minimal, usually related to fit/finish, or Taiwan made bearings .vs. Chinese bearings. If you use a tool 24/7, the PM motor and head bearings should last longer than Grizzly.
Since Covid has reduce international travel; have to believe everyone is suffering when it comes to quality. When the OEM rep visits every month, to inspect machines before shipment; the quality is improved, even in an ISO9000 facility. BTDTGTTS Combine overseas shipping shortages, with trucking shortages in USA, and it's a wonder anyone can a machine without damage due all the pent up rage in supply chain.
All that said, there is two key differences between these machines you didn't mention:
1) Grizzly has fewer inserts or cutting edges than PM. The PM should offer a higher feed rate compared to Grizzly, or smoother surface at same feed rate. If you work with mainly figured wood, then more inserts/less HP would be better compromise. If not working burl everyday, then doubt you see much difference.
2) The PM machine has dovetail ways. The Grizzly has parallelogram tables. Parallelogram jointer table is superior design, and is much easier to keep tables aligned.
Have a 8" jointer with straight knives and 2HP is more than enough. Have used a friends Byrd converted 8" jointer with 2HP motor on some figured wood giving me issues; and it would bog down slightly when attempting to machine a full width board face. The power issue was not a problem, as you just feed a little slower. If I was running production with segmented carbide head, would prefer 3HP if all things were equal.
IMHO, the design comes down to type of wood processed, choice of cutting head, and table design choice; not 2HP .vs. 3 HP and who has best quality.
My choice would be Grizzly for parallelogram tables and more power.
YMMV
