1 - 1 of 1 Posts
Help if you can. I have a powermatic lathe model 90. When I turn on the power the lathe starts spinning even though the control lever is in the stop position. From that point if I turn the lever up the speed increases but will not stop spinning when I move the lever to stop. Should the lathe stop when I move the lever to stop. If it should can someone head me in the correct direction to make the needed repair. Thanks in advance.
1 - 1 of 1 Posts
