1 - 14 of 14 Posts
I am looking for a (wheel) face plate for a powermatic model 90. Basically the thing that lets you spin you work around without actually cranking on the project itself. Can anybody send me in the right direction for one of these parts?
After re-reading our posting, think you are asking about a hand wheel, PM 90 came with a combination faceplate & hand wheel mounted outboard left hand thread 1 1/8" do not know TPI inboard is 1 ½ x 8 TPI right hand thread.
Grizzly's G1633 8" face plate might work if your spindle is 1 1/8" x 12 TPI they sell a an insert D111 that should work.
http://www.vintagemachinery.org/files/PDF/Powermatic/1965-PM90.pdf
Discussion Starter · #4 ·
I am guessing the term (faceplate) was wrong. I am looking for the actual wheel that would go on the left side of the head stock. So when you have a project on the spindal you can rotate it with your hand.
If you look at the vintage machinery link I am looking for #9 on page #5. I am guessing it would be called the hand wheel?
Thanks
Matt
Get a life!
If you are going to give me a reading lesson why not hit me on where it tells you outboard spindle thread is 1 1/8" x 8 TPI, listed in the reference and that Grizzly thread adapter 1 1/8" x 12 TPI I linked will not work?
On this lathe hand wheel and face plate interchangeable! So if go back and read that reference will see the term combination and hand wheel & face plate also used?
Using a faceplate as a hand wheel has gone out of style but not unusual back in the day. Only thing to remember is out board hand wheels or face plates need left hand threads!
If you can't find one, you might try finding a machinist or vo-tech school to turn a 1-1/8-8 left hand flange that you could mount a nice piece of wood to and turn something nicer looking than aluminum. The BOYD section of OWWM.org might yield one also.
Dan Coleman
The part your looking at on the PDF is an eight inch faceplate. There was not hand wheel made for the lathe. They just use the eight inch faceplate as a hand wheel. You may be able to find a hand wheel/faceplate schools are dumping shop equipment because they feel that shop classes are not needed.
Discussion Starter · #11 ·
Thanks everybody for the help. I wasn't trying to give anybody a reading lesson. If I came across that way I apologize. Again thanks for all the help.
Heck.. make one! It would be pretty easy and only cost you the price of a suitable LH nut. If you can't find one at your local hardware store, you can always get one (or three) online from McMaster Carr, Graingers, Fastenal, etc.. I know my local Ace hardware store has LH nuts for my lathe (3/4"-10) for around $1, so there is a good chance they have the proper size you need. That and a piece of scrap 1×8 (or whatever size you want to make the wheel) and you are all set.
1 - 14 of 14 Posts
