Poplar Box, dovetail version
2939 Views 4 Replies 2 Participants Last post by  LeftyBayside
30
Not quite a repeat
Ok, last Poplar Box was with finger/box joints at the corners. Taking almost the same sized Poplar boards, but using handcut, through Dovetails for the corners..first, cut a few pieces on the mitersaw..
Wood Machine tool Machine Gas Metal
Thought I could cut them all at once, and get even sized parts…2 for the ends, 2 for the sides…
Furniture Table Wood Rectangle Floor
One of the sides, even after 3 double-checks, came out a bit too long….we have ways. Then the hand plane routine, again…edges that didn't quite match up, from the same board?
Wood Motor vehicle Gas Engineering Metal
Almost like the board was wider at one end? Once all the edges matched, then the ends needed a bit of work, too
Automotive tire Wood Tool Saw Bumper
While the other end of these 2 boards sat on the rods in the vise, the Stanley No. 3 worked on the other ends, then flip end for end, and repeat. laid out all 4 sides..
Wood Rolling Track Automotive exterior Engineering
Then set 3 of them aside for a while…..got the layout toys laid out, most of them…
Wood Composite material Gas Engineering Roof
Set one of the long sides in the vise…bevel set to the angle I use for dovetails..
Wood Automotive tire Motor vehicle Gas Automotive exterior
Be sure to mark which is the waste. Marking gauge set to the thickness of the mating board, combo square is too. i use the combo square to mark pencil lines that I can see to saw…
Wood Floor Road surface Flooring Gas
I start with a 1/2 pin on both edges, and work towards the center…except…I off-set a hair, to make a wide dovetail about where the lid will get split off. then lower the side in the vise, wax up the saw..
Wood Gas Composite material Bumper Automotive exterior
That blue knife will get used later, for "knife-walls". I lower the board to get rid of chatter while sawing, easier to start the saw cut, too… then just have a seat on the shop stool…..
Wood Hand tool Tool Metalworking hand tool Bumper
And, make some sawdust….then set up a way to chop the waste out, again
Wood Gas Automotive tire Auto part Machine
Chop 1/2 way down from this face, leaving the tab for support, for when I flip the board over, and chop the rest out….I run a knife wall as a "baseline" for the chisel to start in.
Wood Composite material Gas Metal Art
I do the outside face first, to avoid any blow-outs when I chop from the inside…a little clean up, unclamp, set this on the mating corner, all sides are marked as to "inside" or no markings. Line the two insides up, mark where the pins are. Bandsaw works for me, as I can better see the cuts, and make sure I leave as much line as I can, by cutting to the waste side of the lines. The more "line" you leave, the tighter the joint will be…
Wood Tool Gas Hardwood Plank
A few extra cuts IN the waste, helps when I chop the waste out. That double line? Shows about where the inside or outside groove will go….fat dovetail will get split in to 2 joints. Then a dry fit..
Table Wood Wood stain Hardwood Gas
then rinse and repeat 3 more times…
Wood Composite material Gas Engineering Machine
One "gap"? And it will close up during a glue up…
End of Part 1….stay tuned….things are going to get groovy….
1 - 5 of 5 Posts
22
Feeling groovy, and doing the Stanley 45 dance
OK, pills taken, bathroom break done…wander back to the shop…taken the assembled box apart. reach for the Stanley 45….only to discover it is still set up from the last box….so, in order to do grooves for the plywood top and bottom panels to sit in….some changes were in order…
Hand tool Tool Metalworking hand tool Stonemason's hammer Wood
Those long rods would just be in the way, and, that cam rest would not fit….set the cam rest aside, change back to the short rods. Re-assemble the plane….
Hand tool Tool Metalworking hand tool Wood Ratchet
Took maybe 5 minutes, including digging out the rods from the case, and returning the excess parts to the case, and setting the case back on the shelf…..
Needed a simpler jig….had a lot of grooves to mill, less time spent changing the jig(s) around for each, the better..
Wood Gas Composite material Engineering Metal
First tried a single screw in the block of scrap….scrap was too small, and wanted to rotate…went to a longer scrap, added a second screw. Set it to where the edge of the parts would overhang the bench a bit. Then, one screw at each end of the part…one could even stay put, and just use the 4th one to lock the parts in place. Right in-between two pins or tails…I could change the "locking" screws to allow the shorter or longer parts into the jig.
Wood Gas Composite material Machine Metal
Depending on which part needed grooves next…grooves are 1/4" wide, 3/16" deep ( or so) and 1/4" in from the edge of the boards…
Motor vehicle Hand tool Wood Tool Automotive tire
Also, after the first couple passes, rub the groove's sides with the old candle, just a dab on each wall, right near the start point….plane will slide much better in the groove. 8 grooves were now done….need 4 more…but..
Wood Composite material Hardwood Plank Rectangle
This groove is for the inside of the lid. Short rods won't reach this far back. 5 minute break, re-install the long rods, and the cam rest…
Automotive tire Motor vehicle Bumper Machine tool Gas
At least it is only a few grooves, instead of 8..
Wood Composite material Gas Building material Engineering
Lid grooves are placed at that wider dovetail…when the outside groove is made to split the lid off, dovetail should look like the rest..in theory…we'll see..again, cut 2 plywood panels to size…maybe joint a rough sawn edge, if needed…
Motor vehicle Wood Gas Engineering Machine
Test the fit…then spread the glue, and grow a forest of clamps..
Wood Gas Engineering Composite material Machine
Was a busy day?
Road surface Asphalt Wood Flooring Gas
Noodles are a little too crunchy.
Let this sit a day, or so….then try to split the lid off…..that will be the next episode….
Stay tuned..
Flipping a lid
Box came out of the clamps….looking in need of a clean up..
Wood Gas Hardwood Lumber Plywood
Sanders and plane….then lay out where the groove will be…
Rectangle Wood Font Typesetting Paper
Somewhere about there, I think…just barely over the inside groove, towards the bottom of the box. Reset the 45
Wood Motor vehicle Automotive tire Gas Automotive exterior
While I was set the fence…decided to clean that up a bit. Fence has a "Fine Adjust" feature, that was filling up with crud. Opened the fence all the way, clean things out, lock it back in place. Then reset the entire fence to make the groove ….
Wood Automotive tire Bumper Gas Automotive exterior
Quickly found out the box was in the vise a bit too high in the air, lowered it down for a better cut, without the vibration thing….decided to work my way around, one side at a time. Long sides were placed on the bench, with 2 planing stops, one one the vise to tighten down the box….didn't want it to hop around..
Motor vehicle Wood Gas Automotive exterior Machine tool
Once all were done, wound up here
Wood Composite material Gas Rectangle Automotive exterior
And use that sharp knife to cut around at the "top" of the groove…
Wood Rectangle Table Composite material Gas
Lip was again a bit too thick…rather it would be that, than too thin…then adjust until the lid fit all the way down
Set out a small tray of tools and hardware…
Wood Typesetting Metal Engineering Art
Visegrips to hold a small nail to act as a pilot hole drill….and the help turn the screwdrivers…..that soon got changed. Ground the swivel head off the larger screwdriver, and then chucked it into a drill. Then got out a longer nail, got rid of it's head, so it will get chucked in the drill as a well..I left the smaller screwdriver as is, to hand-start each screw, after I waxed the threads.. Hinges and corners first..
Wood Gas Automotive exterior Composite material Engineering
Box held in the vise, to keep things steady. Corners brass uses 2 screws, one per side…so, when I rotate..
Wood Gas Metal Rectangle Engineering
To install a handle and the next pair of corners..more screws…rotate again..
Wood Wood stain Hardwood Composite material Gas
To install a latch, and the next two corners. Then rotate, and do the last handle, and the last screws…whew.
Wood Rectangle Gas Composite material Metal
Wood Plant Automotive exterior Bumper Motor vehicle
Wood Gas Composite material Automotive exterior Natural material
Wood Floor Composite material Flooring Gas
Was going to apply a coat of stain…no brushes IN the shop? Means a late-night run to Wall E World…
next episode? Stain and a tray?
Stay tuned..
Stain, tray, shellac.....
Lets see….stained the box, using the same stain as the last box. Gunstock by Minwax…
Brown Wood Rectangle Hardwood Wood stain
Then decided a tray would be nice…cut a chunk of Poplar to about the correct length..
Wood Gas Composite material Hardwood Flooring
Yeah, yeah…finger prints and a price sticker…good thing this board is too thick, at 1/2", wanted to get as close to 1/4 " as i could…set a couple stops below that 1/4"...
Rectangle Wood Asphalt Road surface Tints and shades
Instead of resawing, a plane would be used….tried the fancy #62, first..
Wood Gas Tool Bumper Hardwood
It would make such nice, thin shavings…but, I needed a 1/4" planed off, be here all day, plane was too long, and too heavy….so
Plane Wood Tool Gas Lumber
Millers Falls #11…a little shorter, much lighter, and could really remove wood…fast…then a smoother to clean things up…
Wood Motor vehicle Gas Automotive exterior Auto part
Then the bandsaw to rip some parts to width out of this now thin board…
Wood Typesetting Gas Lumber Motor vehicle
Strip of plywood to determine how wide…one board was left wide, to make a handle…was going to try some fancy corner joint….didn't really work out….went with glue and nails, instead…including a plywood bottom..
Motor vehicle Automotive exterior Wood Bumper Gas
There was a problem….some of the pieces were tapered in thickness…planed them all to about the same size…
Brown Wood Rectangle Material property Bumper
Wanted something the tray could sit on in the box…couple 1×1s, glued on the ends of the box should do the trick..
set the tray inside..
Wood Rectangle Wood stain Automotive exterior Composite material
And close the lid…and let all the stain dry, overnight..
Cabinetry Chest of drawers Drawer Wood Rectangle
So…this morning, I applied a couple coats of Amber Shellac…
Musical instrument Wood Rectangle Material property Gas
Even the handled ends look better..
Brown Wood Rectangle Trunk Chest
Enough that this is now posted as a Project….Thanks for following along…
Well done. Like those brass corners too!
1 - 5 of 5 Posts
