I have a Delta Model 22-540 that I have had for about 8 years. I was using it today, took a break, came back a half hour later and it wouldn't start. I checked the brushes and they look fine. Pulled the switch and there is power to it. Took out the switch and tried it direct and still nothing happens. Anyone has any thoughts I'd appreciate it. It has been a great tool and I really don't want to buy a new one. Thanks in advance.
Do you have a continuity tester? You said you bypassed the switch. Maybe you could check for continuity from the "motor side" wire from the switch through to where the white wire is connected to the motor wiring (wire nut connection). If there is continuity, maybe the problem is in the plug. The plug can be tested also with the continuity tester. If you had continuity as explained above, just unplug the planer, turn on the switch and test continuity between the two flat lugs of the plug. If there is no continuity then the problem is a bad plug or the wire to the planer. Also, I don't want to sound like a smart a** but you did try a different receptacle. Sometimes the receptacles go bad and don't pop a breaker.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
LumberJocks Woodworking Forum
