Plane Restoration
6542 Views 18 Replies 6 Participants Last post by  ac0rn
Marsh M5 (Day 01)
After doing so many restorations lately I figured I'd take the time to create a blog series that hits the highlights of my process. The best way I can think of to do that is break it down by each day's worth of work at a time and describe what was done that day.
So here we go. This plug ugly bastard is a Marsh M5 I got from ebay for a whopping $35 including shipping. If I'm any good at what I do it will look like its worth a lot more when I'm done.
Smoothing plane Plane Wood Shoulder plane Jack plane
I know everyone reading this is envious of this magnificent ebay treasure.
Step 1: Take it a apart
Seriously that's all there is to step one. The only thing to remember is don't force any parts with threads. If they won't come off get some Kroil penetrating oil or P.B. Blaster. Don't worry if it gets on the wood parts…those are disgusting already. For this particular ugly duckling the rear depth adjuster was gunked up with lots of grime. It took quite a bit of PB Blaster and working it back and forth before it came off cleanly. That's still a better alternative than stripping the brass threads and trying to find a new adjuster knob on a Marsh.
Hand tool Wood Tool Auto part Metalworking hand tool
Step 2: Clean your parts - No its not your bath time yet…we are cleaning plane parts
I use just regular old soap and water with a soft bristle nylon brush for this part. Yes they may flash rust but who cares they are going into a rust bath later anyway.
Tool Hand tool Composite material Metal Wood
Looking a tiny bit better already.
Step: 3 Inspect your pars - not your parts…eyes up ya weirdo
What you're looking for is anything bent or broken. Bent we can fix but broken you have to source. On this old dirty bastard the lateral adjuster is bent as well as the frog depth adjustment fork. I will address those in another entry once they are clean. Also I can't quite make out the iron but it looks like a Miller Falls and not an H.C. Marsh. Once its clean we will find out for sure.
Step 4: Evaporust spa treatment
I don't have a pic of this step because its just a tub with some Evaporust in it and the plane gets fully submerged in it. Let me say that again…FULLY SUBMERGED...unless you want the acids to etch lines in the side of the plane body for you. By the way those lines won't ever come out…ask me how I know. Also if you have young kids or pets be responsible and get a tub with a latching lid. Big box stores have the knock off brand tubs stupid cheap.
Step 5: Sand the handles - We all love sanding right?
Not much to show on this step. The tote is going to suck to sand. If its an older style tote where they were more selective about grain patterns its going to be a bear to follow it. Most of the time it angles across the side and back but sometimes its crotch grain and the back side of the tote has a V shape in the grain. I always start with 120 grit and do two passes with it before I drop lower. Anything lower than 120 can leave scratches that are tough to take out. Sometimes its necessary if the finish is being a jerk.
I clean the tote with denatured alcohol between each sanding. One it helps break up any existing finish and it will remove any contaminants you don't see that could show up in your finish later.
Here the tote is done up to 220 grit and you can see my make shift bolt and spacers for the knob. This is loaded into my cordless and used to sand the knob.
Wood Wood stain Hardwood Metal Hand tool
Here is the other side of the tote still at 220 and the knob taken to 400 grit. The tote has a chip we need to fix or I would have taken it to 400 as well.
Wood Artifact Wood stain Font Metal
Step 6: Fix handles
I try to stay away from things with broken handles because I'm lazy and don't like dealing with it. If I was gluing a tote back together I would do that at step 5. But thankfully we just have a chip to fill on this tote.
This is a decent size chip but we will see how my super glue fill process looks once finish is applied
Wood Rectangle Tints and shades Font Art
And here it is filled. Make sure to overfill any chips as the glue will shrink. With this size it will most likely take a second coat.
Wood Material property Font Audio equipment Carmine
Now set that tote off somewhere away from dust and dirt to dry. If you used the glue in the pic don't try huffing…it has no smell.
Step 7: Clean the iron
The acids in evaporust can attack the hardened part of the iron so I never let it sit overnight with the rest of the plane. And in the summer time with the humidity in the mid west its either finish it on day one or spray it with CRC 3-36 and finish it later. Today I opted to do it the same day.
After a quick once over with 220 grit we can clearly see it is indeed a Miller Falls iron.
Font Tool Metal Automotive exterior Composite material
Now we have a judgement call to make. Is the pitting in the iron enough to warrant dropping down to 100 grit or can we live with it? I chose to drop down to 100 to remove more of the pitting since this iron may get sold if I can find a suitable H.C. Marsh to replace it with.
So the process for the iron is pretty simple. Steel has a grain to it just like wood so make sure to check the direction of the grain. On this iron it is vertical, so I sand with 100 grit in as vertical of motion as possible, then double my initial grit and go to 200. I repeat the same vertical sanding and then double it again at 400 and finally finish it with 800.
Now the tricky part - Buffing the iron. For Stanley Irons I use jeweler's rouge because it leaves more of a luster than a shine. For Miller Falls irons I like to use green compound to get a better shine. Miller Falls seem classier so I shine them up another degree.
If you have a buffer and aren't sure how to use one I suggest a trip to YouTube since a picture won't do it justice. Just be warned these irons can get a bit toasty. If you don't have a buffer then I suggest converting an old bench grinder. My "buffer" is an old Delta 5" grinder but works wonders for me.
Step 8: - Wax anything metal you completed today
Mid-west humidity laughs at unprotected metal things so I have to wax anything I finish same day even in the winter time. I like to use a micro-crystalline wax that is petroleum based versus any carnuba based waxes. My wax of choice is Renaissance.
Here is a finished Miller Falls iron…look at it all nice and shiny
Rectangle Tool Ruler Auto part Metal
Step 9: Protect your parts - Put the jock strap down…i know its lumber jocks but we're talking plane parts
Rectangle Handwriting Gas Office equipment Bumper
I like these rubbermaid clear tubs. They are a tad pricey at around $12 each but they have nice seal to help keep out dust and a size 3 and 4 can fit in them body and all.
So that's it for the first day of plane restoration work. The next entry will be hardware and the initial stripping of the japanning from the body and tote.
1 - 19 of 19 Posts
Marsh M5 (Day 01)
Step 6: Fix handles
Excellent write up and photos. I see so many "restorations" starting with a wire wheel. Good to see you disassemble right off. Good tip on keeping parts submerged in evaporust. Same applies for electrolysis rust removal.
Can't wait to see the next installment!
Regards, The Kentucky Toolsmith!
Marsh M5 (Day 01)
Step 6: Fix handles
Thank you. I use wire brushes in two processes only. The first is steel bristle brushes if I'm stripping bad japanning off. The second is brass bristle brushes cleaning and shining the depth adjuster. I could do jobs like cleaning the lever cap faster with a wire brush but sand paper gives me much finer control.
Marsh M5 (Day 02)
Back at the Marsh for the second day of its rehabilitation back to a worthwhile member of the plane society. Let's start with a quick overview of my most commonly used tools which I forgot to put in the Day 1 entry.
The old Stanely Hurwood No 51 is the perfect fit for the bass nuts on the handle rods, the Husky 1/4 screw driver is a perfect fit for all other hardware. And finally a couple picks for gunk in the slotted screws or getting the corners of a plane body you stripped down.
I'm going to follow the same step 1 thru X format as I did previously. Basically just chronicling my work as I did it in each step for the day. Warning - Day two covers a lot of steps
Step 1: Fix the handles
In the last entry we did a super glue fill of a big chip in the tote. So today we need to sand that down, refill it, and set it aside so it can dry while we work on other plane parts.
Here we are dried, sanded, and then refilled.
You can see how it shrinks and looks pretty ugly. I sanded with 120 grit since we will be filling again. I didn't want it to smooth as I was afraid it might lose adhesion. We will find out in another day if that was a bad idea or not
Step 3: Clean your parts It's a recurring theme with this line of work.
This step is pretty straight forward. For most planes you can simply remove them from the Evaporust bath then clean with soap, water, and a soft nylon brush. I have a bathroom in my garage shop which I can clean small parts and 3 or 4 size bodies. A number 5 or larger has to go to the kitchen. So be courteous to your wife/girflriend/husband/partner and keep a Mr Clean eraser and some Bar Keepers Friend at the sink. Wipe that bad boy down when youre done
Notice anything strange? Ya the plane body and frog are nearly at bare metal. That can happen if rust gets underneath the old finish. The rust bath will eat that away and the finish just comes right off. This is one of those catch 22 deals. On one hand its less work for us but on the other a butt load of black finish is now in your Evaporust depleting its effectiveness. A cheese cloth and strainer can help with that and I will cover it in the next entry.
Step 4: Clean your parts…AGAIN! Told you it was a theme
After the soap and water I like to use degreaser, followed by brake parts cleaner because it evaporates quickly. I follow up the brake parts cleaner with some CRC 3-36 for anything that I don't want to rust on me. So pretty much every surface except for the parts of the frog and body that used to be black.
Step 5: Strip your parts Damn it…put your pants back on
Not much to cover here. I use KleanStrip, a disposable brush and container, some gloves, and a tub you dont mind if it smells like butt hole cancer.
Pour some stripper into your container and paint it on. Try to avoid surfaces that will be not painted later but its not a big deal if you get some on there. We will most likely rust bath these again anyway. I like to keep some blue towels underneath so the chemicals don't try to eat the plastic.
I like to have a pretty thick layer on everything. Kind of like it was just covered in slime. Then put the lid on your butt hole smelling tub and leave it be. I find that slowing the drying process lets the stripper work a bit longer. This plane will only take a single coat but a more difficult bastard can take a couple coats of stripper.
Step 5: Inspect your parts
Yes we went over this yesterday but after the rust and grime is removed somethings we didn't see may become apparent now. Here are a couple of examples.
First we have a chip in the lever cap. Its too deep to grind it back and reshape the leading edge. If it was 1/16th of an inch or smaller I would grind it back but this will just have to be left alone.
Next we have a pretty significant issue with the chip breaker. Some clown who owned it previously ground it back so the leading edge is flat. Like a small cliff that shavings will run face first into.
Oh and they didn't even grind it square
Final issue is a small bend in one tab of the frog depth adjustment fork…i dont actually know what its called but it sits behind the frog on a depth adjuster. If its not flat it can cause us to have issues getting the frog to seat correctly. A lateral adjuster can only do so much so we need to fix that too.
Font Wood Circle Symbol Metal
Step 6: Fix your parts
We will start with the smallest one first. If you don't have at least a small metal working vise with an anvil you should get one. So to fix the frog fork thingy its really simple. Put it on your vises anvil, get the biggest ball peen hammer you have and smack it! There are more elegant ways to handle this for sure but a good solid flat whack or two and we get it flat.
Gas Circle Composite material Metal Wood
Now onto the chip breaker. First thing first we need to have some metal files and load this thing into the vise. I started with a bastard file and worked my way down a couple different sizes. I can't really take pics of that because you need two hands and a third to photograph. Best way I can explain it is keep the file level. Bring it down until it touch the high corner and take a stroke. Keep doing this until you are squared up. The black line you saw in the previous step 5 is a visual indicator of when to stop filing. But ALWAYS check with a square as well.
Textile Collar Wood Button Pattern
Now that we are square the hard part starts. We just made our cliff face even taller and need to reshape the leading edge. I started with a small metal file. Positioned it against the curved part of the chip breaker and stroked upwards in a slight curve. This did most of the work and I used my surface plate and some 60 grit paper to finish shaping.
The chip breaker is flexible so a finger placement is key to keeping it square as you shape it. I prefer to place my fingers inside the edges but not too close to the center.
Gesture Finger Thumb Toe Wrist
Then all you do is pull back and rock your wrist up at the same time. The end of the stroke should look something like this.
Hand Gesture Thumb Finger Wrist
Check the edge every few strokes to make sure you are getting even pressure. If one corner is shaping faster than the other adjust your fingers to the high side to even it back out.
When completed the front should be nice and rounded over with a crisp clean edge. On the left we have a Stanley and on the right is the newly repaired Marsh chip breaker.
Rectangle Road surface Bumper Automotive exterior Gas
Once you have the front profile done there will be a pretty nasty burr on the bottom side. We need to remove that and put a slight flat spot on the underside so it registers with iron. I like to get a diamond stone and set it on my bench letting the tail of the breaker ride the bench.
Wood Rectangle Wood stain Hardwood Composite material
We do this because the breaker will flex when tightened down to the iron. We want a slight angle when its un-flexed so it will be nice and flat when flexed and tight.
Use three fingers, both sides and center, and work the breaker back and forth. When finished you should have a nice 1/16" to 3/32" flat spot on the bottom side.
Brown Wood Rectangle Wood stain Table
Step 7: Deburr your hardware
Some planes are worse than others. I've had to replace hardware on some entirely while others were handled with gentle loving hands. The Marsh was handled by big monkey paws and most of the slotted screws are dinged up.
Microphone Automotive tire Automotive lighting Grey Audio equipment
I prefer to do this part by hand on some 220 or 320 grit sand paper. The best method I have found is to get some sort of mat to put your sand paper on. Much of the old hardware is rounded tops and the mat will prevent you from sanding flat spots on the tops.
Plant Purple Textile Sleeve Violet
Here I'm just using my big Milwaukee mat I put on my bench when working on planes. Its just a thick toolbox mat at about 3/16" thick. Be sure to sand in the direction of the slot in the hardware and rock your wrist back and forth. Check it frequently to make sure you aren't sanding any flat spots. It takes a little practice but the mat is one heck of a good insurance policy.
When done they look something like this.
Automotive tire Household hardware Font Auto part Wood
We aren't striving for perfection on this plane as you can see some of the hardware is pitted. If they were still in good condition I would sand them longer.
For the threads I just use a solid brass brush in my cordless. I will eventually upgrade to one in my 8" grinder but this works well for now.
Finger Yellow Audio equipment Nail Thumb
Step 8: Buff your hardware
First and foremost when working with small parts and a high speed buffer where safety glasses at the very minimum. Preferably you have a full face shield. If one of those little screws slips your grip they shoot off like a missile.
Here is one of the brass nuts deburred next to one that is polished. Less than a minute with some jewelers rouge makes a world of difference.
Wood Earrings Body jewelry Handbell Jewellery
And the last pic of the day is most of the hardware all buffed and ready to be oiled down before putting it back in our tub to be kept safe
Body jewelry Jewellery Metal Font Nickel
Sorry for the long post on this one. There was a lot to cover. Fixing the chip breaker takes a bit of effort. They may not seem like important parts but a nice smooth well fitting breaker is a key component to top performing plane. In the next entry we will strip down the body and lap it flat as well as get some finish on the handles.
Marsh M5 (Day 03)
No review to go over today so let's get to it.
Step 1: Finish sanding the tote
If you've been following along we left the tote with another coat of super glue and a question as to whether 120 was to coarse to sand the first fill coat. Well it was and here is the result after sanding the second fill coat down and the whole tote to 400 grit.
Wood Grey Flooring Tints and shades Pattern
You can see some white specs in the fill. I think that is from the previous layer being to rough. Hopefully it kind of blends in once the finish coat is on. If not its still quite a bit better than a big chip
Step 2: Put on some finish
I used to have a lengthy finish process here that involved danish oil, shellac seal coat, and finally some lacquer. That makes the finish look very authentic but is a serious PITA. Now I use gloss wipe on poly for a few coats and then a spray gloss poly.
Here is my setup. A board with some dowels cut at an angle to hold the handles, my poly, a disposable container, and some gloves. I like to pour the poly into a small container and apply it with just an ordinary blue shop towel.
Wood Flooring Gas Hardwood Engineering
Wood Barware Bicycle part Drinkware Metal
Don't be surprised if the first coat gets kind of blotchy. Since we cleaned the handle with denatured alcohol they can be rather dry. The handles may just drink up the first coat. No big deal. Don't try to re-work or anything like that. Just apply it and if it disappears into the wood leave it be. It's easy to add more coats but difficult to fix a bad coat. Now set that off somewhere away from dust and humidity to dry.
Step 3: Clean your parts This step is getting old
Seriously if you want to be good at restoration work the details is all in the prep. Here is somewhat how your frog, yoke, and body should look after removed from the stinky butt hole tub where they stripper was applied
Gas Tool Auto part Metal Bag
They will probably have some rust and some slime still on them so first thing we want to do is wash them with soap and water. If you notice black junk coming off easy feel free to use a wire brush while cleaning in the sink or bucket.
You may also notice an assortment of wire brushes that can be loaded in a cordless. These do the bulk of the work getting us to bare metal. I like to clamp the body and frog in my bench vise. Be VERY careful how you do this. You want the meatiest part of the cast iron in the vise and you only need enough pressure to keep it from falling or moving.
Wood Bumper Tool Auto part Hardwood
In the image above you can see I'm not clamping down on the ears. You want all the pressure along the strongest part which is where the bed and sides meet. You still need to be very careful not to over torque the vise or you risk cracking a side at the mouth.
All that you need to do next is go to town with your wire brushes, picks, hand brush, and maybe some WD-40. After you think its clean rinse it with some soap and water. It should look something like this
Tool Wood Composite material Metal Nickel
We aren't 100% to bare metal but we picked up some rust so back into the evaporust it goes overnight. So to be continued on that part.
Step 4: Shine your parts No not polish your knob…I said shine your parts
Tonight I started with the breaker that was rehabbed yesterday and the lever cap. I start with 200, then 400, and finally 800 grit paper. I will drop to 100 grit but that's kind of a judgement call in regards to depth of pitting.
Here is the lever cap after a once over with 200. In this case I will drop to 100 to reduce some of the pitting
Guitar accessory String instrument accessory Wood Font String instrument
If you drop to 100 then make sure to do 200 again before going up. Here is the lever cap all finished at 400(top) compared to an un-restored M5 lever cap in very good condition. I think its a pretty good match.
Hand tool Wood Font Wrench Metalworking hand tool
Now we need to check the bottom of the lever cap to make sure its shaped properly to make good contact with the iron and breaker.
Grey Gas Font Metal Wood
The M5 we are working on is on the left and the good cap is on the right. As you can see the one on the right has a nice flat registration surface. So we need to head to the surface plate and work on the first -1/2" to get a flat spot.
After a few minutes at 80 grit it looks pretty good.
White Grey Gas Font Silver
Not to much to show on the chip breaker. Its sanded with 200, 400, and 800. I like to sand vertically because most breakers already have some steel grain lines running that direction. If pitting is rather deep like in the one we are working on you can use a brass bristle brush. This will get down into the pits and lift any gunk or metal dust out. Just be sure the brush is moving in the same direction you sanded or its going to look terrible.
Hand tool Auto part Tool Metal Composite material
Next up is the depth adjuster. I have seen plenty of ways to do this online but here is my method. Brasso and an assortment of brass bristle brushes. The smallest brush gets the inside, the normal brush gets the outside and bottom, and finally we go back with the cup brush to get a good polish.
Liquid Fluid Yellow Bottle cap Plastic bottle
This is the part many will disagree with me on. I use a metal working vise to hold the depth adjuster while i work on it. You don't need much pressure to hold it at all. I have yet to get one marked by the vise jaws. So once you've slathered the whole thing in Brasso load it up in your vise. You may want a mask as Brasso has about 10% ammonia in it and smells terrible.
Automotive tire Wood Automotive lighting Gas Motor vehicle
Once loaded in the vise go to town on the inside with a small brass brush. Let the brush and Brasso do all the work. This is why you don't need much pressure. Once the inside has turned a greyish green ugly sludge color switch to the brass wheel brush and get the knurling. Flip the adjuster in the vise and get the bottom side. Again let the brush and brasso do the work for you.
Now that both sides are butt ugly wash all the gunk off with some water. It should have a dull sheen to it. All you need to do now is load it in your vise and hit it with the cup brush. That should put a very glossy finish it on it.
Wood Yellow Button Metal Close-up
Step 5: Admire your hard work
We are three days into a this project so its time to admire some of our work. I like to put the iron, breaker, and lever cap together and see how they look all shined up. We worked hard on them so lets take a moment to enjoy that shine
Tool Composite material Blade Metal Steel
Step 6: Filter the Evaporust (optional)
I said I would go over this so here it is. You need a strainer, a bucket, and a cheese clothe. The cheese clothes I use come from amazon and cost about $10 for 8 of them. I can cut each one in half so I get 16 filters for 10 bucks. I'm sure there are better solutions out there but this works for me.
Here is what it looks like
Cookware and bakeware Gas Composite material Aluminium Metal
Natural material Plastic wrap Circle Pattern Chemical compound
Natural material Artifact Art Composite material Bedrock
That's all there is to it. The cheese clothe really isnt necessary but it saves the strainer from getting all gunked up. Your evaporust may still be dark like mine is but it will still last a few more planes before it needs replaced. Getting the bigger particles out keeps it from continuously acting on them and depleting its usefulness.
That's a wrap for today. The next installment should be final metal prep, taping, and the first coat of paint.
Marsh M5 (Day 04)
I have quite a bit more work done on the Marsh I just haven't had a chance to post it all yet. I'm doing my best to try and keep track of each days worth of work. My old boxer passed away on Saturday and it kind of upended my life for a few days. That old man was with me for 13 yrs. At age 40 that's nearly a third of my life. His demeanor was always one of caring and patience. It was a constant in my life I came to rely on and once its gone it leaves a very large hole.
I believe the last entry left off with getting the first coat of finish on the handles and getting the cast iron parts back into the rust bath.
Step 1: More finish on the handles
I like to start each day/session by working on the finish for the handles since those take a full day in the summer humidity to dry. I use 0000 steal wool after each coat as necessary to remove nibs off the finish. Here is a pic of the first coat after being wiped with the steal wool.
Wood Bicycle part Auto part Metal Hardwood
You can see we have some uneven finish here. I attribute this to the drying effect of the denatured alcohol used to clean the handles between sanding. Nothing to worry about. Just means another wipe on coat of poly is needed. I put that on now and set my handles off somewhere safe to dry
Step 2: Clean your parts - So much cleaning
I don't have an image for this step because its been covered but remove plane parts from rust bath and clean with soap and water.
Step 3: Flatten the body
I don't do anything fancy here. I've seen people use granite tiles, glass plates, even glass plates with precision machined aluminum surfaces on top that were 3 ft long before. I use just a simple large granite surface plate I bought on sale at Wood Craft.
My initial setup is a single sheet of 60 grit paper and a small clamp to hold it down. A number 5 size plane can be worked diagonally on a single sheet.
Purple Wood Rectangle Violet Floor
For a bit of controversial lapping I don't load the frog back into the body. I've heard it explained that the frog tensions the plane and prevents an warping but I don't see how and no one besides a physicist who is also a metallurgist is going to be able to convince me otherwise. The frog is held in by 2 screws that are only torqued down tight enough to keep it from moving. On Stanley's, type 9 and earlier, the front of the frog didnt even make contact with the mouth. So in my opinion loading the frog back in the body does nothing but make lapping a giant pain in the ass.
In order to check the sole I first use a Milwaukee Inkzall marker. I used to keep Sharpies around but they dont like metal dust or dirt. On a corrugated plane like the M5 I mark big thick black lines on both sides of the mouth and then a few arcs at the toe and heel
Rectangle Wood Material property Tints and shades Electric blue
Here is how I grip the body when lapping. I try to use my palm to keep pressure over the mouth. I'm not using a ton of force here either. I start with a coarse grit so that it does all the work.
Hand Gesture Wood Finger Gadget
Now remember I'm actually going to sand at a diagonal. It was just hard to get a pic at that angle.
After around 8 to 12 passes on the coarse paper I will recheck where the marker lines.
Rectangle Wood Grey Composite material Gas
We can see the marker lines are completely gone from around the mouth but we didn't even touch the toe or heel. This means we have a bit of a belly to smooth out. On a number 5 it probably doesn't matter but we can get flatter so why not go for it.
Now I change my setup to remove the belly from the plane. I switch to using two sheets of paper with some painters tape to hold them down. I know there are lots of things you can use like roles of paper but this method works well for me. You just have to make sure the two sheets are aligned correctly with no bumps at the joint. A slight gap wont hurt at all but an overlap would be very bad.
Purple Rectangle Wood Violet Floor
Now you have some work to do. It can take a while to get the sole flat. I will work it from both directions. Mouth towards me and mouth away from me keeping two hands on the body at all times. If you want it to look its best when completed you want as straight of strokes as possible.
And after about 10 or 15 minutes worth of work we have a bed that is shiny from almost head to toe.
Rectangle Wood Material property Gas Composite material
Here is a close up of the toe. You can see it's not perfect but that last tiny bit isn't going to hurt anything. I have yet to come across a situation where I'm trying to register my plane on a piece of lumber using only the first 1/4" of the sole.
Automotive tire Building Automotive design Grey Art
And the heel came out nearly perfect with just a tiny dark spot left at the edge
Head Building Eye Plant House
Now that we have done the sole its on to the sides. When doing these I have a specific grip I like to use. I hold onto the cheek with one finger pointing forward and keep my elbow tucked and in line with my shoulder. Much like using a hand saw. This keeps even pressure and prevents getting out of square.
Tire Wheel Automotive tire Tread Wood
The other advantage to this grip is if the sides aren't square I can just lean pressure of my hand to one side of the other to take heavier passes where needed to square it up.
After you get your grip down sand away and make sure to check for square OFTEN. I use a Starrett tool makers square to get as accurate as possible but any good small square will do.
After I've established flat and square on 60 grit, I step up to 120, 220, and finally 400. You may end up with a few low spots on the cheeks after using the surface plate. Every plane is different and if I get low spots I will touch those up by hand.
Here is the M5 taken up to 400. Still some dirt and grime to remove but we can do that later.
Wood Hardwood Blade Metal Carmine
Now would be a good time to go wash up because your hands probably look like this
Gesture Finger Thumb Wood Nail
Step 4: Fettle the frog
This frog actually doesn't need any work. Some restorers go thru the hassle of removing tool marks from the frog just because they don't like the look. To me the frog is the most important part of the plane so I don't mess with it if I don't have to.
What I like to do is load it in my bench vise face up. If you have a small straight edge you can check if for flat that way. What I use is a spare iron that registers very flat on my surface plate. I place that on top of the frog and tap all for corner and both sides around the center point. If there is any rock in the iron I know the frog isn't flat and I know where to address that.
Wood Bumper Automotive exterior Gas Hardwood
Step 5: Clean your parts AGAIN!
This is the final cleaning before we paint. I was battling severe humidity the day I did this so I got flash rusting on the surface of the plane and frog. Might not have happened if I wasn't stopping every 10 minutes for pics but hey I can deal with it. So first part of final cleaning is WD40 and a wire brush to get the flash rusting off.
Everyday carry Knife Wood Hunting knife Tool
Following this I use brake parts cleaner until no more brown, grey, green, or really any ugly color comes off on my blue shop towel. It can take awhile but the cleaner it is the better.
Wood Rectangle Household hardware Automotive exterior Tool
Step 6: Protect your parts
After everything is super clean I like to wax the sole and cheeks of the bed just to protect them during painting. I don't need anything try to rust under the painters tape. I've only had it happen one time but it sucked so this is a precaution I take. No pics of this step. I just apply a light coat of Renaissance wax.
Step 7: Tape your parts
Now that everything is clean we need to tape off the areas we don't want painted. The body and yoke are easy but the frog will suck. Don't be surprised if you go through a couple razor blades taping the frog. Rough cast iron and sharp don't mix.
Body
Tool Wood Composite material Everyday carry Electric blue
Frog and Yoke
Wood Electric blue Gas Font Concrete
Azure Wood Electric blue Rectangle Gas
One thing I didn't get a pic of is adding some scrap hardware to all the bolt holes, except the frog depth adjuster hole, in the body. The last thing you want is paint in the mounting holes.
Step 8: Final cleaning - HOORAY!!!
I can never get the hang of doing fine detailed taping with gloves on so I know I touched some surfaces I want paint on at some point during the taping step. Since we don't want any finger oils on those soon to be painted parts I glove up and wipe all my parts down with acetone. Avoid your paint because acetone eats adhesive.
Step 9: Paint your parts
I don't have any pics of this step. My lighting in my paint area is not very good and images always come out bad. If you have ever spray painted anything before with some success you will be fine. The color I use for planes is Dupli-Color Ceramic Ford Semi-Gloss Engine enamel. The Dupli-Color paint code is DE1635.
Just remember to start with light coats and build up gradually. You can always add more paint but taking any off means taking it all off and starting this process from Strip Your parts. I've been there before and trust me its not fun.
Marsh M5 (Day 04)
Body
Frog and Yoke
Very thorough job and blog.
Marsh M5 (Day 05)
If all goes according to plan this should be the final day and the plane can be assembled at the end. But since I'm writing a blog about this plane it did have an issue. That's just how the universe works sometimes. I will cover what happened and the steps to resolve below.
One thing I know I missed from my last entry about paint is wait a full 24 hours after the last coat before handling the plane. I don't care what the spray can instructions say on it I wait 24 hours because that is what experience has taught me to do.
This is what your painted parts should look like after building with a handful or so of thin to medium coats of paint.
Gadget Automotive lighting Audio equipment Cameras & optics Camera lens
Step 1: CAREFULLY remove the tape
I stress carefully in this step because the paint is not fully cured yet. We will bake it once the tape is removed. If you used high temp painters tape you could actually skip this step. I don't have anywhere local to pick up high temp tape so I carefully remove the tape. You want to avoid using razor blades in this step unless its necessary to lift a corner of the tape so you can slowly peel it off.
Once tape is removed the plane is starting to look like pretty again
Guitar accessory Hood Tool Font Material property
You may have noticed the top edges of the body are still black. I don't tape these off before painting because that is a hassle. And I don't remove that until after I bake the plane. It makes quite a bit of a mess and we don't want any paint flakes baking on to surface by accident.
Step 2: Bake your parts
This is the step that turns the ceramic engine enamel into a high durability finish in my opinion. I don't have pics of this because its pretty straight forward.
- Preheat the oven to 160 degrees. If you have a newer oven that only goes to 200 check for a "Warm" setting. That should be around 140 which will also work.
- Place your plane parts on a cookie sheet covered in foil and put that on the center rack of your oven.
- Let the plane cook for one full hour. My oven is too narrow for the cookie sheet to go in side ways so after 30 minutes I rotate it to ensure even heat on all parts.
- Let the plane cool down to room temperature. This part is important. We don't want it to still be warm when we bake it the second time.
- After the plane has cooled preheat the oven to 200 degrees
- Cook plane for one more full hour at 200 degrees rotating the cookie sheet if necessary.
There you have it you just baked a plane. Experience has taught me that 200 right off the bat can be too high of temp and I have had the paint wrinkle on me. I'm also using a very old oven so a newer oven that heats more evenly may not have this issue.
Step 3: Final clean up
After the plane has fully cooled is when I take a razor blade and scrape off the paint from any places I don't want it. This is almost always the front lip of the body and top lip of the sides. Also double check all the mating surfaces on the plane body and the frog for over spray. I don't have an images of this step but its pretty straight forward. One of the razor blades you have left from when you taped the plane can be used for this step. Then throw that blade away cuz you thoroughly thrashed it.
If you have an air compressor use it to blow off any loose paint when you're done scraping.
Step 4: Wax your parts
I used Renaissance wax for all of my planes. It is a petroleum based wax with other fancy science word additives. Carnuba based waxes can contain acidic substances and we want none of that. If using a micro-crystalline wax like Renaissance or EJ Wheatons DO NOT wait for the wax to "set up" like you would with a normal paste wax. I wax a surface and then wipe it back off. The whole plane may take on a cloudy look at this point which is fine. Once all surfaces are waxed come back with a micro fiber clothe and buff the whole thing.
And here is what it should look like after baking, scraping, and waxing
Rectangle Material property Font Musical instrument accessory Fashion accessory
I could have used another light coat or two on this plane. Baking does cause a small amount of shrinkage to the finish. It would naturally happen over time as it fully cures but baking does that part quicker. Its a hard call to make during the painting process. If you get too thick and it doesn't shrink enough it looks really bad because you lose the crispness of the stamped lettering.
Step 5: Assemble the plane!
This part is pretty easy. Use a screw driver that PROPERLY FITS the threads. I use my Husky 1/4 flat head for this. We just spent time cleaning up all the screws and we don't need to muck one up now. Seriously I can't stress enough how important it is to have a screw driver with a good fit.
I use good old fashioned 3-in-1 oil on all of the threads. I even put a drop in all of the threaded holes on the body and the frog. Some people use paraffin wax which works as well but I prefer the ease of 3-in-1 oil.
The only thing I'm going to show for this step is lining up the frog with the mouth of the plane to be co-planer. This is a number 5 so I doubt I will ever move it but this is how I initially setup up all planes regardless of the size.
Automotive lighting Bumper Automotive exterior Wood Motor vehicle
Side note: In my personal opinion Marsh had a superior frog design to Stanley. It's locked in on both sides with butt load of metal meat for the iron to ride against. I wish Stanley would have copied this design when they bought Marsh back in 1924 but they didn't and shortly after that Marsh ceased to exist.
Step 6: STUPID TOTE
I don't have any pics here but as described in the intro a small part of the tote did not like the finish I applied. It happens on like 1 our of every 5 totes. The wood is very old and we have no idea what its been subjected to over it's 100 yrs of service.
To remedy the issue I sanded some of the finish off with 600 grit automotive sanding sponge. Then smoothed that out with 800 grit wet sand paper. Finally I re-sprayed the bad spot with a thick coat of poly and the rest of the tote with a thin coat. I'm now going to let that sit for a full 48 hours before touching it.
If the tote finish ever fully cures I will see you back here in two days for final assembly and testing of the plane.
Marsh M5 (Day 05)
Step 6: STUPID TOTE
This whole series is an excellent write up Sansoo! Thank you for taking the time to do it :)) I'm gonna have to try baking my enamel soon. I usually just wait a couple of weeks after painting to re-assemble. Baking would speed that process up!
Sorry to hear about your boxer :-(
Regarding assembling the plane before lapping… Most of the time it's probably not necessary. BUT, I have had planes where the fit between the frog and the base was such that when the screws were tightened down, it did cause some deformation in the base. I only noticed this because I lapped the sole flat up to 120 grit then after re-assembly went to polish it out on 220 and noticed a high spot right behind the mouth that wasn't there previously.
Now, don't get me wrong, the plane would have worked just fine. It was a smoother so the high spot was more pronounced than it would have been on a larger plane and the blade would have probably sat higher than the high spot anyway.
But, in order to avoid that, ever since then I print and scrape the fit between the frog and the base. That way I know the frog is properly fit and isn't putting any undue stresses in the casting. It may seem excessive but it really doesn't take long at all and the vast majority of the time, there isn't any need to scrape anything anyway.
Now, all that said, I still re-assemble my planes before I lap the sole. The main reason isn't the frog but rather the fact that when I plane, I'm putting significant force into both the knob and the tote. And the forces on each vary through the stroke and aren't always in the same direction depending on the task at hand. So, I think it's a good idea to lap a plane using the knob and tote since that's where forces are applied during use. Does it really make any difference? I have no idea ;-) But it makes sense to me so I figured I'd give you some food for thought.
Marsh M5 (Day 05)
Step 6: STUPID TOTE
Thanks for the pointers Ken. Just goes to show no matter how many times to you do something there is always room for improvement.
The print and scrape with the dye is a great way to achieve proper fit. I will definitely be giving that a try once I find a consistent way to remove lateral adjusters and get them back on. It's the getting them back on part I have issues with at the moment.
One of the reasons I don't lap assembled that I didn't mention is avoiding the metal dust that could potentially get embedded in the handles. However tweaking my workflow a bit I could lap before sanding down the handles.
In my final entry I think I will mark around the mouth again and run it over some 320 to check for high spots once fully assembled. Who knows maybe I will end up lapping fully assembled for now one once I see the results of my test.
Marsh M5 (Day 05)
Step 6: STUPID TOTE
It's worth a check just to see. Don't get me wrong, I'm not saying you're missing or skipping anything. Just giving my reasoning for how I arrived at my methods.
Also printing and scraping where possible deformation is concerned, would be printing the frog to the pads in the base, not the iron to the frog face. The lateral won't be in your way there ;-)
Marsh M5 (Day 05)
Step 6: STUPID TOTE
Got a question for ya…
I'm working on my Millers Falls #24 and have decided to try baking this one. Also going to try not taping off the top edge of the cheeks because it's hard to get a clean line after removing the tape.
  1. Does baking the enamel have a strong smell in the oven? My wife will hate it and I still can't smell anything (after-effects of Covid) so if the smell is strong, I'll probably skip it. Or maybe do it on my gas grill at low heat? And to clarify, you bake it 24 hours after the final coat?
  2. When you remove the paint from the top edges, do you do it immediately after baking or wait for it to cure further? Or does it matter? And do you just scrape it off with a razor blade or do you have some secret sauce?
Thanks!
Marsh M5 (Day 05)
Step 6: STUPID TOTE
I'm a jerk and forgot to reply.
1. Baking the enamel will create a smell. In my oven I can't really tell its baking unless I open it. The smell is not very kind but it does dissipate rather quickly. My exhaust hood in the kitchen vents outside so I leave the oven cracked and turn that on for 30 min and poof no more smell.
For anyone wanting to try baking I would do a small plane first. They don't produce as much smell as a big old #8 will and you will probably only get in a small amount of trouble if the wife gets mad.
2. The top edge is cleaned with a razor blade before or after paint with different concerns for both. Prior to baking the enamel is soft and you need to be careful with it. If you have a steady hand the enamel will peel off the edges really nicely prior to baking. If you choose to use the razor blade post baking be warned the enamel more or less flakes off at this point. Its a rather hard surface now after all. If you want nice crisp edges to your paint line don't dig too hard into the top edge or it will flake and look jagged. You will need to do a little more sanding if removing the paint post baking.
My preferred method is a nice sharp fresh utility razor and do the paint removal prior to baking.
Marsh M5 (Day 05)
Step 6: STUPID TOTE
Gracias Sansoo! I have actually decided to go another direction. Mostly because I'm out of Duplicolor but have a couple cans of Rustoleum Protective Enamel that I used to paint my mom's mailbox a few months ago. I remember liking the sheen and how evenly it went on over primer and it's held up outdoors remarkably well. So I've primed this plane and I'm gonna wet sand that down smooth and hopefully later this week get the black sprayed on. Since I'm experimenting with a new paint, I'm not gonna throw baking into the mix as another variable at the same time. We'll see how it goes…
Marsh M5 (Day 06)
The final day of getting the plane ready to go. For starters let's do a review of the day 1 image as to remember what this rusty bastard looked like before we started.
This is a sad plane
And with a little bit of work we make a happy plane
Wood Food Hardwood Bicycle part Wood stain
Step 1: Wax on Wax off
Once the handles have had time to dry I like to give them a good coat of wax. For rosewood and other dark wood handles I prefer MinWax Special dark
Look at it shine…
Drink Ingredient Bottle Wood Barware
We do the same with the tote but unfortunately it still has a few tiny blemishes in the tip of the horn. First is the 120 grit choice for sanding the fill spot. That was too rough and left some white marks. The second is some very small areas that would not take the finish. I have no idea what causes this but I get one tote or knob out of a dozen or so that just has a problem. I chalk it up to being 100 yrs old and not knowing what all gunk has gotten on them over that time span.
Still looks better than what we started with so I call it a win
Wood Tints and shades Thumb Hardwood Electric blue
Step 2: Testing
Normally I wouldn't do this step because we are all clean and shiny right now. This testing is going to require cleaning the sole and waxing it again. However fellow LJ HookieKen brought to my attention an issue he had where lapping without assembling the plane did warp the sole once it was all back together. I believe the culprit in his case was the leading edge of the frog not being machined parallel with the sole. So where they made contact left uneven pressure.
So to test I thoroughly cleaned my surface plate and laid down a new sheet of 320 grit paper. Next we mark the mouth of the plane with a couple black lines on both sides.
Hood Grille Wood Gas Motor vehicle
You should take the iron out for this but I decided to go full boar and leave it in but fully retracted. This has the plane fully tensioned as it would be in use.
Tire Automotive tire Wood Bicycle part Rim
No irons were harmed in this testing
Finally I run the plane diagonally across my 320 grit for a total of a dozen passes with it fully assembled and using the tote and knob just as I would if I was making curls.
Plane Scrub plane Purple Rebate plane Bumper
And here is our result
Wood Gas Rectangle Electronic device Grille
A tiny black bar in front of the mouth. This says to me that i missed this when I was first lapping the sole. I can't think of any pressure being put on the plane when its fully assembled that would cause any warping in front of the mouth.
If this was a smoother instead of a jack I would break out some lower grit paper and take that hollow out. Being a jack plane I'm honestly not to worried about that. If it causes me issue when taking shavings I will address it then.
Step 3: Sharpen the iron
I'm not going to go into detail here. There are literally TONS of videos and blogs out there about rehabbing and sharpening plane irons. I have my own method that is a mix of the Cosman and Sellers sharpening techniques. What works best for one person may not work for the next. It seems every hand tool user has their own way of handling irons that works best for them. I say do some research from well known craftsman and come up with a method that works best for you.
Step 4: Make some curls
The first thing I do is find a nice board to take some edge passes with. This lets me get a feel for the plane as well as get the iron dialed in nice and straight. Paul Sellers has a great video on this but basically you want to take a pass on the left and right side of the iron. If they aren't even move the lateral adjuster toward the side that took a heavier shaving and repeat. Once both sides are even you know you are nice and straight.
Here is our board
Wood Wood stain Plank Hardwood Nail
And here are the resulting shavings.
Wood Vegetable Root vegetable Hardwood Soil
With the oak having that heavy of grain lines I think that's the best we will get. The edge is straight, square, and glass smooth. Its fun to get those transparent shavings but in my experience not all wood will do that for you.
Now that we have our iron square and its taking nice shavings lets do the face
Water Wood Beach Building material Sand
And here are the shavings from the face
Wood Automotive lighting Table Hardwood Automotive tire
That long shaving right in front of the knob is nearly full length of the test board and getting close to full width. I am satisfied she is dialed in.
Now it's time to play!
Wood Ingredient Mobile phone Cuisine Table
Or get carried away as I often do with a new plane
Wood Bottle Table Cutting board Grana padano
Take note of the strop in this pic. I HIGHLY HIGHLY recommend this horse butt strop from Tools for Working Wood. I use the rough side and it works so well I can use it to touch up an iron before heading back to the stones. That is a pretty big time saver and extends my working time with an iron by a good 30 to 40 precent.
So there you have it my process for restoring a rusty old plane. I want to give a special thanks to HookieKen and KYToolSmith for giving me some pointers I can incorporate into my process for the next plane I restore. As with all things in life continuously searching for ways to make improvements will almost certainly lead to better results and a more enjoyable experience.
If you have any questions feel free to ask. Thanks for those that made it this far. I hope I was able to share some information you may not have seen before.
Marsh M5 (Day 06)
This is a sad plane
Look at it shine…
Step 2: Testing
Here is our board
Great series Sansoo. I've always went for understated knobs and totes. I sand em back, oil em, wax em and go. But now you make me wonder if shiny wood is the way to go :) Excellent result! Thanks for sharing.
Marsh M5 (Day 06)
This is a sad plane
Look at it shine…
Step 2: Testing
Here is our board
Thanks Ken. I used to do satin or at most semi gloss on my handles until I got a buffer. Once the metal bits got shiny it was a natural progression for handles to get shiny.
I think it also depends on how the tool feels in your hand. Some folks like the feel of the wood grain. I prefer the silky smooth high polish with a nice wax. It just makes the tool feel premium to me. Kind of like the difference between an Empire combination square versus a Starrett. There is no reason the Starrett has to look awesome while outperforming the Empire. I just like that it does.
Marsh M5 (Day 06)
This is a sad plane
Look at it shine…
Step 2: Testing
Here is our board
I thoroughly enjoyed your blog on this , thanks for sharing your experience.
Marsh M5 (Day 06)
This is a sad plane
Look at it shine…
Step 2: Testing
Here is our board
Finally took the time for this read. Well presented, thanks.
1 - 19 of 19 Posts
