Peterbilt truck
92349 Views 132 Replies 28 Participants Last post by  mribelin
16
Wheels
I could have bought the wheels for my new T and J project, but decided to make my own. I prefer wheels from oak (a bought wheel is from beech) because ebonizing and I also I prefer a rim that is separate from the tire. Her you can see how I did it:
First wood selected and signed wheels:
Wood Gas Wire Circle Electrical supply
Bandsaw work:
Wood Tints and shades Cylinder Circle Temperature
Drilling a hole 35 mm, 11 mm deep:
Wood Cuisine Dish Ingredient Circle
Turning the wheels a little oversized:
Natural material Wood Tints and shades Plant Tree
Made a hole 8mm for the axle pegs:
Wood Natural material Tree Art Circle
Putting about 10 wheels on a rod for final diameter turning;
Wood Gas Cylinder Machine Engineering
Than made with an angle grinder out of HSS steel a wheel profile maker. I have the benefit of a crossing table on my lathe. As you can see below the HSS blanc is mounted in the lathe:
Light Wood Material property Gas Auto part
After profiling and sanding 10 fixed wheels:
Automotive tire Tire Cloud Wood Sky
101 - 120 of 133 Posts
22
What went wrong and mistakes
Below a few pictures of what went wrong.
After sanding there was a naturel crack in the roof:
Wood Tints and shades Rectangle Hardwood Plywood
I decided to fix it with PVAc glue:
Hand tool Wood Metalworking hand tool Tool Red
When I was sanding the exhaust pipe and pulled too hard on the sanding paper he brook:
Wood Hardwood Rectangle Flooring Wood stain
When I was sanding the frame on the disk sander he fell out of my hands and one edge was considerably demaged. I glued a another piece in it:
Wood Wood stain Hardwood Gas Lumber
Four times a broken jamb:
Wood Gas Tints and shades Wood stain Hardwood
e
The bottom of the frame I glued in a wrong direction:
Wood Rectangle Flooring Floor Wall
And that's why I had to replace it:
Plumbing valve Tool Drill Bumper Metalworking hand tool
My cutter came deep in the wood and I had to replace that spot:
Wood Hardwood Publication Wood stain Flooring
Fortunately, you can hardly see the repair:
Wood Tints and shades Rectangle Ceiling Flooring
The making of a facet on the front wheel rims on the disk sander wasn,t a succes. Too wobly:
Handheld power drill Wood Saw Pneumatic tool Power tool
Thats wy I did it on the lathe:
Bumper Gas Machine tool Auto part Machine
Thanks for watching.
Nice to know Ron that you maybe also will make a truck. Let me know when you start.
What I didn,t like
I love working with the T and J plans but there is one thing I don,t like and that is making handles, mirrors and so on. This little stuff is made out of 2,3mm (3/32") dowels. Dowells of 2,3 mm are hard to get in europe so I use 3 mm (almost 1/8"). I do the glueing with CA. Below you see a couple of picture,s from the way I try to press it together.
Circuit component Gas Auto part Engineering Audio equipment
Font Urban design Asphalt Screenshot Engineering
Gas Electrical wiring Composite material Engineering Machine
Is there someone who can give me an advise to do this easier. You are welcome!!
What I didn,t like
I'm probably not going to be able to describe this very well, but here's a thought.
Can you make an L shaped support out of something like HDPE (http://www.amazon.com/Polyethylene-Off-White-Tolerance-D4976-245-Thickness/dp/B00CPRDN3W/ref=sr_1_1?ie=UTF8&qid=1425567246&sr=8-1&keywords=hdpe) for example.
Three pieces with grooves could be used. I thought of HDPE because the glue shouldn't stick to it. By arranging the pieces as shown in the diagram below you support the dowels so they don't bow under pressure, you help enforce a good corner alignment, etc.
You'd want to make more than one set - that way you can do different sized square glueups without having to make a custom support for each one.
Rectangle Font Parallel Slope Electric blue
Hope this makes sense. I don't think you'll use any fewer clamps with this setup but I think it will support the constructions better.
I've looked at making a couple of these models as well and 3/32 is an odd size of dowel to use. I've only found one place you can get it online.
What I didn,t like
kweinert,
A very good idea. Thank you for your clear explanation. The next time I will gif this a try.
What I didn,t like
Maybe not the best solution, but I would take a piece of flat board or platter, draw the square to describe the pattern and then drill a hole in each corner, lay the dowels onto the pattern where the glue will be applied to prevent the dowels from sticking to the board. This should work well with superglue.
What I didn,t like
Isn't it great when blokes help each other from there experiences and know-how….
Thank you to both Dutchy and "kweinert"....much appreciated….
What I didn,t like
Hi Jan. Here is a picture to show you my glueing solution. Please let me know if this is not clear.
Handwriting Font Parallel Rectangle Automotive design
I would assemble the work piece dry, tape it to the board and then drip the glue into the corners.
What I didn,t like
Thanks Mike,
Your drawing is clear. Next time I will try it and also let you know if it works.
What I didn,t like
Dutchy, I live in Australia so 3/32" is even prehistoric to us. I have found some toothpicks come very close, however, they are not consistent. What I do is everytime I place an order for a T and J plan (I buy the spare parts kit) I over stock by ordering various diameter imperial dowels. I guess I now have enough stockpiled to build about 30 models. Having said that, I use a shopmade tiny mitre box with Japanese finecut saw to cut the 3/32" dowels and with superglue on one piece and a spritz of accelerator on the other, as soon as I touch I get an instantaneous solid bond with no need to hold the pieces together or apply pressure. The downside is that if you miss alignment you have a wonky join that needs to be broken and redone after some careful sanding.
What I didn,t like
Thanks Alex.
Currently I do it the way you discriped. And it goes exact as you discriped. Comment is that a joint with an accelerator is less strong than one without.
Thanks again.
Preview
This is the last blog of the Peterbilt truck. I made 200 picture,s (didn,t use them all) That means an average of slightly more than 10 picture,s per blog entry. The blog took some time but in relation to making the two logging trucks it wasn,t that much. Tomorrow I will ask my daughter to make some project pictures but below the preview:
Wood Metal Machine Hardwood Plywood
As mentioned before tomorrow hopefully more pictures for label Project. For that reason you may also wait with comments
Preview
I've certainly enjoyed your many blog entries as these MAGNIFICENT trucks came to realization. You are certainly a very astute craftsman and patiently achieved your goal. Even through some slight mistakes which you so generously shared. Thanks for all your efforts. Now who gets to put them on the mantel?
Preview
You made two! I am looking forward to the finished pictures/presentation.
Preview
Thank you guys.
I don,t have a mantel. I hope to solve that problem.
Yes I made two. Or is,t a trick. No it,s a truck. No it are trucks.
Preview
Dutchy,
You have done a real service in posting your blog on How to Build these great trucks. Thanks for sharing your knowledge. Posting on a blog is not easy when done in great detail.
This will be of benefit to truck builders for a long time.
Preview
Thanks Thomas,
The biggest difficulty for me is the language. It is more than 40 years ago I left school. I,m glad with google translate.
Preview
Well done Jan…
Preview
Those are so nice. They bare realy great miniatures.
helluvawreck aka Charles
Preview
Wow. I've been watching your build blogs. These Petes have turned out beautiful! Thanks for sharing!
Preview
Great blog Jan, the results look wonderful. I'm looking forward to seeing the full project photos.
