Peterbilt truck
92353 Views 132 Replies 28 Participants Last post by  mribelin
16
Wheels
I could have bought the wheels for my new T and J project, but decided to make my own. I prefer wheels from oak (a bought wheel is from beech) because ebonizing and I also I prefer a rim that is separate from the tire. Her you can see how I did it:
First wood selected and signed wheels:
Wood Gas Wire Circle Electrical supply
Bandsaw work:
Wood Tints and shades Cylinder Circle Temperature
Drilling a hole 35 mm, 11 mm deep:
Wood Cuisine Dish Ingredient Circle
Turning the wheels a little oversized:
Natural material Wood Tints and shades Plant Tree
Made a hole 8mm for the axle pegs:
Wood Natural material Tree Art Circle
Putting about 10 wheels on a rod for final diameter turning;
Wood Gas Cylinder Machine Engineering
Than made with an angle grinder out of HSS steel a wheel profile maker. I have the benefit of a crossing table on my lathe. As you can see below the HSS blanc is mounted in the lathe:
Light Wood Material property Gas Auto part
After profiling and sanding 10 fixed wheels:
Automotive tire Tire Cloud Wood Sky
81 - 100 of 133 Posts
12
Lights on the roof
The pieces become smaller. Her are the pictures from the roof lights.
First put some dowels with CA glue in a piece of padouk:
Wood Font Circuit component Rectangle Line
After sawing:
Handwriting Font Line Circuit component Schematic
After sanding the crude form:
Font Line Slope Parallel Engineering
Turning on the lathe. This with the greatest caution I turned with…...sandpaper:
Wood Automotive tire Rim Gas Automotive wheel system
When it was done I realized I made 8 but needed 10. My disc sander was mounted on the lathe and I didn,t want to do a conversion. I put one piece in my drill and made a light on the discsander. This was much easier and faster:
Wood Line Tool Wood stain Office ruler
And after made a small bevel on the lights they where mounted on the roof. You also can see the horns made out of a golf tee:
Table Wood Gas Shelving Chair
Thanks for wathing
They are neat Dutchy…..well done.
Lights on the roof
After sawing:
Thanks for wathing
Looking good.
Lights on the roof
After sawing:
Thanks for wathing
Thank you guys.
Ornament
Another small part to make. Very small.
I started with glueing 3 pieces of wood together.
Product Wood Font Trigger Office supplies
After it was dryed it was cut in half. And sanding could start. Below you can see the process.
Wood Rectangle Grey Road surface Brick
Wood Tints and shades Wood stain Hardwood Flooring
Making it slant:
Rectangle Line Flooring Floor Font
Radius making:
Liquid Drinkware Fluid Tobacco Drink
And again disc sanding work to do and make it smaller:
Wood Rectangle Floor Flooring Font
And smaller:
Wood Rectangle Handwriting Floor Flooring
And smaller:
Wood Rectangle Flooring Tints and shades Font
And then it was glued on the truck and "clamped" with Duct tape:
Comfort Wood Automotive tire Couch Tints and shades
This ornament is very small and hard to see on the truck:
Wood Gas Tints and shades Rectangle Transparency
And for that reason another picture:
Wood Rectangle Hardwood Comfort Wood stain
Thanks for watching
Ornament
Making it slant:
Radius making:
And smaller:
And smaller:
Thanks for watching
That IS a small part. I didn't realize how small until the last pictures!
Ornament
Making it slant:
Radius making:
And smaller:
And smaller:
Thanks for watching
It's fun to see the process for making such small parts. Nice work Jan.
Ornament
Making it slant:
Radius making:
And smaller:
And smaller:
Thanks for watching
Thanks guys.
Steve next time I will put a tape measure next to it.
What went wrong and mistakes
Below a few pictures of what went wrong.
After sanding there was a naturel crack in the roof:
Wood Tints and shades Rectangle Hardwood Plywood
I decided to fix it with PVAc glue:
Hand tool Wood Metalworking hand tool Tool Red
When I was sanding the exhaust pipe and pulled too hard on the sanding paper he brook:
Wood Hardwood Rectangle Flooring Wood stain
When I was sanding the frame on the disk sander he fell out of my hands and one edge was considerably demaged. I glued a another piece in it:
Wood Wood stain Hardwood Gas Lumber
Four times a broken jamb:
Wood Gas Tints and shades Wood stain Hardwood
e
The bottom of the frame I glued in a wrong direction:
Wood Rectangle Flooring Floor Wall
And that's why I had to replace it:
Plumbing valve Tool Drill Bumper Metalworking hand tool
My cutter came deep in the wood and I had to replace that spot:
Wood Hardwood Publication Wood stain Flooring
Fortunately, you can hardly see the repair:
Wood Tints and shades Rectangle Ceiling Flooring
The making of a facet on the front wheel rims on the disk sander wasn,t a succes. Too wobly:
Handheld power drill Wood Saw Pneumatic tool Power tool
Thats wy I did it on the lathe:
Bumper Gas Machine tool Auto part Machine
Thanks for watching.
e
Bloopers and outtakes:
Never have them . Everything I do goes as smooth a silk.
And if you believe that I have a bridge for you to purchase. :)
e
Brian I believe you completely. I would not dare to doubt.
e
I've heard that the difference between an average woodworker and an excellent woodworker is his ability to hide his mistakes and accidents.
I am getting better all the time.
e
A few mistakes is common for me these little pieces and my old hands don't always work like they should. You are doing a very nice job. keep up the good work.
e
Bruce and Dick thanks for comments.
e
Hi Jan. This post is like a reality show that all of us have seen in our own shops.
e
Yes Mike We have saying here:
Who does not make mistakes never makes anything
e
Learning to repair errors or slips makes you a better wood worker. It makes you look at all the different things that can happen. i must make a lot of things in my shop because I make a lot of mistakes. A lot of the times, the first mistake that I make in the morning is getting out of bed. Have a nice day.
e
G'Day Dutchy,
You're a top bloke, telling us about the mishaps, thank you, as it helps everyone else in there learning experience, just like your FIRST CLASS blog of this WORK IN PROGRESS with great photos of your project….
WELL DONE SIR, indeed….
e
Thanks hookfoot and Crowie
e
Dutchy, with me never happen mistakes …... And not problems …..
Beep, beep, beep
"Here is your favorite announcer. They are 6am and it's time to wake up. Good day to all. Now a song …".
Hmmmm. Ok, Ok another day again. Thanks God for the quiet night
e
Thanks for sharing your project with us! There are always problems, er challenges, to deal with no matter what type of project we undertake. Your trucks turned out great and are quite inspirational. I may have to try one of these yet.
