Very interesting Jan. Your tire making jigs are brilliant. Can't wait to see your next blog in this series.
Very interesting Jan. Your tire making jigs are brilliant. Can't wait to see your next blog in this series.Wheels
I could have bought the wheels for my new T and J project, but decided to make my own. I prefer wheels from oak (a bought wheel is from beech) because ebonizing and I also I prefer a rim that is separate from the tire. Her you can see how I did it:
First wood selected and signed wheels:
Bandsaw work:
Drilling a hole 35 mm, 11 mm deep:
Turning the wheels a little oversized:
Made a hole 8mm for the axle pegs:
Putting about 10 wheels on a rod for final diameter turning;
Than made with an angle grinder out of HSS steel a wheel profile maker. I have the benefit of a crossing table on my lathe. As you can see below the HSS blanc is mounted in the lathe:
After profiling and sanding 10 fixed wheels:
Thank you Mike.Wheels
Bandsaw work:
I like the way you are attacking this. Well done.Wheels
Bandsaw work:
Thank you Brian.Wheels
Bandsaw work:
Sometimes I wish I had room for a wood lathe when I see how easy folk can make things like these beaut wheels…well done "dutchy".....Wheels
Bandsaw work:
Another great jig Jan. This would be very useful for so many similar drilling situations. Thanks for sharing!Holes in axle
It always was difficult for me to make the holes parallel in the axle. I made a little jig to solve this problem.
From plywood I made a 100% right-angle "jig". On this plywood I put two wheels The screw in the "middle" of the wheel has an offset from 2 mm. By turning the wheel I can clamp the axle. Below you can see how it worked out:
Below is the situation on the drill press:
Thanks Mike.Holes in axle
Keep up the blog. I am really enjoying it. If I ever get my other projects caught up. I want to try a T&J project.Making the cabin
First I made the pieces I needed. None of them is exactly.
Here you can see them:
I started sanding the botom exactly. Therefore I mostly glue a piece of paper on the part that has to be sanded. Below the situation on the disk sander:
Then I glue the back of the cabin and the dashpanel to the bottom. This two pieces both are over sized:
After the glue has dried again I sand the pieces exactly according to the bottom;
Now it,s time to glue the oversized engine hood on it:
And again making it exactly on the disk sander. Below you can see the result after sanding:
No its time to glue the sides on it. Below one side oversized:
First I sanded the botom of the sides exactly flat. Also the window is already there. Below you see the sanded sides:
Now it,s time to glue the sides on the body.
Thank you Bruce. That makes me keep up going.Making the cabin
Enjoy the blog, I am working on a Bi Plane at the moment and I enjoy following your progress! Thanks for sharingMaking the cabin
When I,m finished with the truck I hope you can make a flight with your plane to Holland.Making the cabin
There is always ways of getting the completed task at hand done. Sometimes you need to try a couple of ways to get the desired effect.Radiotor front
I make more things at once for my truck. Here you can see how I made the radiator front.
First I made the inner site exactly on the disk sander. To do this first I glued a piece of paper on the ash wood:
Before i removed the paper I marked the position for the radiotor front strips on the end grain;
Then I glued the radiator strips from wenge on it:
To sand the strips a little thinner I put double sided tape on a piece of plywood:
Put the radiator inner side on this tape and sanded it on the drumsander:
Glued the up and down side to the inner side:
Sanded it on the disk sander:
Glued the left and right side to the inner side:
Next time more.
Thank you Brian. (Also for your answer on my glue question) I enjoy working with my drum sander, but for making T and J toys you can do without.Radiotor front
Next time more.
This is not boring. keep up the blog I enjoy follonwing it even if I don't always comment.Glueing the cabin on the frame
Today i glued the cabin on the frame. I hope this blog isn,t boring. But I started this blog and want to finish him.
Below you see the frame:
Glueing the cabin on the frame:
After drying first saw the frame a liitle smaler on the bandsaw:
Then made the frame and the cabin exactly flat:
The result after sanding:
Sanded the nose from cabin and frame flat:
Glueing the radiator front on the cabin:
After sanding the results:
Thank you Bruce.Glueing the cabin on the frame
