"Parasitic" floor lamp
11716 Views 68 Replies 12 Participants Last post by  kaerlighedsbamsen
Intro
The movie "Parasite" was full of eye candy for those that gravitate towards a modern, minimalist style. One piece of set dressing that caught my eye was the tripod floor lamp that was in the living room of the Park house.
Property Plant Wood Interior design Houseplant
The light it gave-off was more atmospheric than illuminating, and I couldn't quite make out how the light box was constructed to shape the light like it did. It took some googling to track down more photos of the lamp designed and built by the Korean artist Bahk Jong Sun. Among other sites, 1stdibs.com had some good images that revealed louvers that were used to adjust the light.
Shelf Wood Rectangle Shelving Wood stain
In the spirit of the movie, I decided that I'd be a parasite and make a copy of the lamp. I used it as an opportunity to get some experience with Sketchup. I didn't fully model the lamp, but it did help to work out the size and proportions.
In homage to the movie, here's what I came up with.
Arm Easel Human body Sleeve Gesture
I started with the turret, which I'll describe next.
41 - 60 of 69 Posts
Light box and louver shaping
For the main box and louvers, I again used some wood that I had on-hand - some Alaskan yellow cedar - selected because it was wide enough so I wouldn't need to do a glue-up and it was relatively lightweight. It's not very striking grain-wise, but I figured this lamp is all about form, so I'm okay with the plain look. AYC is on the soft side, but I figure the lamp isn't going to get much abuse, so I went with it.
I started by resawing and thickness sanding some pieces for the box down to 7/16". I cut the pieces down to the design dimensions of 20"L x 8"D x 7.75"H. The plan is to use simple butt joints like the original, and to fasten them with 4mm dominoes.
Brown Rectangle Wood Wood stain Hardwood
And just set in place to get a first view of the box. I won't be able to assemble the box until I check the proportions against the rest of the lamp and have the holes drilled for the louver fasteners.
Table Wood Rectangle Desk Wood stain
I did do a quick test with some scrap to see how the tiny dominoes would work. They'll do just fine.
Wood Wood stain Hardwood Beige Rectangle
Wood Rectangle Floor Flooring Hardwood
With the box taped together, I set it on top of the turret. It was then that we found that the turret needed some additional height (simulated with some cork coasters) and that the box looked just a bit too large. I overlaid the picture below over the original, and sure enough mine was a bit too long and high.
Easel Wood Shelving Flooring Wood stain
I kept the box proportions the same, reducing the height by 1/2" and the length by 1-1/4". With the new turret cap in place and the resized box, I was happy with overall proportions.
Wood Wood stain Shelving Hardwood Plywood
For the louvers, I started with a plank matching the thickness of the center of the louver and a little oversized in width to give me some wiggle room. I cut the length to be enough for 4 louvers plus some waste. I marked out the target cross section on either end, and then trimmed off the bulk on the bandsaw.
Wood Knife Hunting knife Blade Hardwood
Wood Scale Tool Flooring Cameras & optics
It was a really nice day, so I did all my planing outside on the patio. I used my trusty piece of thick purple rug pad to cushion the piece to avoid denting the piece on the workmate.
Light Wood Outdoor table Shade Tints and shades
After planing down to the line, I took it back to the workshop to do some final sanding. The nice part about this shaping was that, like the legs, the cross-section didn't need to be perfectly uniform along the length. It just needed to "look" right.
Purple Textile Sleeve Rectangle Grey
Then it was off to the tablesaw to cut the louvers to length. A strip of masking tape eliminated any tear-out during cutting.
Rectangle Wood Wood stain Floor Wall
The louver length is 1/8" less shy of the opening height to allow for a 1/16" thick washer on either end at the pivot point. And another quick look at the components in-place to see how it's looking:
Table Furniture Wood Rectangle Desk
Next up will be the threaded inserts on the top and bottom of the louvers.
It's looking really good, Ross. Nice job shaping the louvers.
Also, it's always nice seeing an old Workmate in use. I've had mine for over 35 years, and I still find ways to use it all the time.
- Ron Stewart
Thanks, Ron. The Workmate - yeah, I think I got mine around '85 or '86, so I've had mine for about the same length of time. The plastic part the keeps the legs folded has broken on one of the legs, but other than that it's still going strong.
Louvers - threaded inserts
The bolts through the box that provide the pivot point for the louvers don't need to be very beefy, so I chose some small M4 shoulder bolts. My original plan was to use these threaded nut inserts in the louvers:
Hand Thumb Gesture Finger Plant
But, since they were so small and they were going into end grain of a soft wood, they really didn't grip very well at all when inserted. Here's what I was left with in a scrap of AYC after trying to seat an insert:
Wood Amber Rectangle Gold Flooring
So my workaround is to inset a disk of hardwood that's been tapped for M4 threads. I had some cocobolo turning blanks, so I cut off a 1/2" thick slice and cut out some disks on the CNC. After seeing the grain pattern of the wood, I was wishing I was using it for some other purpose. Oh well.
Wood Rectangle Wood stain Gas Lumber
Wood Wall Brick Font Brickwork
I chucked the tap in the drill press and turned the chuck by hand to tap the disks.
Wood Gas Cuisine Recipe Machine
I used a forstner bit to make the pocket for the disk insert.
Audio equipment Terrestrial plant Gas Fashion accessory Wood
The disks will all get glued into place.
Rectangle Wood Grey Door Material property
On a sample tapped hole, I was able to over-tighten the bolt and strip the wood threads. I don't expect to be tightening them fully, though. I'll use a little bit of temporary thread lock and tighten just enough so the louver isn't loose. I'll do a test assembly once I've got the holes drilled in the top and bottom of the box.
I didn't post on the previous posts, but the lamp is looking great. The taller turret is an improvement and I think the louvers are turning out well. I'm excited to see the next few posts.
I didn t post on the previous posts, but the lamp is looking great. The taller turret is an improvement and I think the louvers are turning out well. I m excited to see the next few posts.
- MikeDS
Thanks, I appreciate that, Mike. I'm pleased with how it's coming along.
Clever solution with the wooden inserts. Even when hidden You will know they are there and that precious wood will not be wasted
Louver pivots
Rather than drive a whole mile to the hardware store for some washers, I made use of the cocobolo instead. This let me get exactly 1/16" thick, match the 5/8" diameter of the threaded insert plugs, and make the center holes just slightly larger than the shoulder on the bolts.
Finger Thumb Snake Terrestrial animal Metal
Confirming the louver height plus 2 washers matches the height of the side pieces.
Brown Wood Rectangle Beige Material property
I had intended to drill the pilot and counterbore for the bolts on the drill press, but I didn't have the right sized bits. So I went ahead and drilled them with the CNC. I had been reluctant to do this because layout had to exactly match the width of the top and bottom pieces. Otherwise, when one piece was flipped over, the pairs of holes wouldn't exactly align vertically. I measured them to the nearest 1/32", and it worked out fine.
Wood Rectangle Office ruler Wood stain Hardwood
And, of course, I needed a test fitting. I counterbored slightly less than the head thickness because I didn't want to risk the shoulder reaching the surface of the threaded plug when the bolt is tightened. The shoulder protrudes just enough to keep the 1/16" washer centered.
Wood Table Hardwood Wood stain Rectangle
I left the edges of the louvers a little long so I could do some final fitting as I round them over.
Wood Beige Bumper Rectangle Automotive exterior
Now I can do a little sanding on the box pieces prior to getting them assembled and glued-up.
Louver pivots
Nice design and build, Ross. I'm not familiar with the movie, but I'm enjoying seeing you work through the details of the build. The louvers look really sharp.
Louver pivots
- Don Broussard
Thanks, Don. If you like modern minimalist architecture, the movie has lots of eye-candy.
Box glue-up
There's not much to show here except that I decided to use some connector bolts to hold the box to the top of the turret. So, before sanding all the pieces prior to glue-up, I drilled three holes in the bottom box piece and tapped 3 matching holes in the top of the turret. The holes are offset towards the rear of the turret, and they won't be visible from the front of the lamp once I have the translucent white acrylic sheet (diffuser) mounted inside the box.
Wood Wood stain Rectangle Hardwood Plank
The mini dominoes worked great for this.
Wood Rectangle Sewing Pattern Creative arts
Wood Rectangle Hardwood Flooring Plywood
Table Wood Automotive exterior Wheel Red
Rectangle Wood Natural material Wood stain Table
The box will get another light sanding before the end of the project.
Next is lighting. Finally.
Lighting
My plan from the beginning was to use LED strip lights that I had left over from my office lighting project. The 4000K LED's are "natural white", but may end up too cool for this particular application. But, since I had them, I decided to give them a try.
I bought a transformer that was dimmable with an inexpensive 0-10v rotary dimmer, which will be mounted on the back panel along with an on/off switch. Here are the pieces hooked-up temporarily so I could see how the dimming worked. I'm most likely going to set-and-forget the dimming level, and I was pleased that it went pretty dim before winking out.
Bicycle part Gas Composite material Font Metal
Motor vehicle Grey Hood Line Gas
For mounting the LED strips, I made a frame to hold 6" sections of the aluminum track. I curved the front of the frame, hoping that the light would be brightest in the center and fall-off a bit towards the sides.
Wood Rectangle Composite material Fixture Facade
Here I'm just working out how high off the bottom the frame should be mounted. I set the height to roughly put the transformer centered vertically. The frame will eventually be mounted to the 1/4" ply back, which I've yet to make.
Electronic instrument Musical instrument accessory Gadget Audio equipment Rectangle
I cut the LED tape into ten 6" sections and soldered some jumpers between them.
Gas Font Pattern Wire Circle
I cut ten 6" sections of aluminum track and diffuser, drilled them for flat head screws, and mounted them to the frame.
Wood Automotive tire Electrical wiring Gas Rectangle
Wood Fence Facade Gas Home fencing
With the LED strips and diffusers temporarily installed, I could do a test fitting in the box.
Wood Gas Audio equipment Electronic device Font
The fit was a little snug, so I'm going to file some relief notches on each end of the aluminum tracks so the wires don't get pinched. The acrylic panel I ordered has 32% translucency, which I think is really going to work great. You won't be able to distinguish individual LED strips when it's only an inch or so away.
Wood Rectangle Floor Wood stain Stairs
I'm not sure I'll get the light fall-off at the edges with how the LEDs are currently placed, but I still need to check it out with the dimmer reinstalled. (All the lit LED pictures on this page except the first are full brightness.) If I decide that's super-important, I'll just try a different configuration. The light also seems a bit harsh, so I may be ordering some lower temperature "warm white" LEDs at some point.
Wood Rectangle Table Wood stain Hardwood
Computer desk Table Desk Wood Rectangle
Lighting
You could also get more fall-off by having shorter strips of LEDs at the ends.
Looks like it's coming together nicely.
Lighting
- Dave Polaschek
Excellent point. I like a simple solution.
Almost there
I'm down to the final bits of construction now. I'll be down to just sanding and finishing in no time. To finish up the light box, I added some baltic birch ply mounting tabs to hold some captive lock nuts. These will hold the acrylic panel and the rear panel in place.
Wood Automotive tire Material property Font Pattern
The nuts were a snug fit - I had to tap them down into place.
Wood Automotive tire Material property Hardwood Flooring
I made a little template to help locate the tabs equidistant from each side.
Rectangle Wood Beige Flooring Floor
Wood Rectangle Wood stain Table Hardwood
I placed the mounting tabs so that they would be directly in line with the first and last louver pivot points so the dark spot they create on the lit acrylic won't be too noticeable.
Rectangle Wood Table Beige Shelving
Rectangle Wood Wood stain Hardwood Table
The back panel is 1/4" BBP with laminated veneer of Alaskan Yellow Cedar on the exterior surface.
Table Rectangle Wood Coffee table Font
I still need to work out what type of ventilation openings I want to put on the back, but I've got the rocker switch and dimmer knob placement worked out.
Rectangle Wood Grey Beige Floor
Rectangle Road surface Grey Wood Brick
I did opt to buy a different strip of LEDs. These ones are 2700K, so warm white. I'm happy that I did. I couldn't resist another test assembly to see how it looks lit in the living room. So far, so good, I think.
Amber Rectangle Art Bar stool Paint
Almost there
Looking good, Ross! That's one seriously cool looking lamp.
Nice attention to detail aligning the tabs with the louver pivots. That's the sort of thing that elevates a good project to a great one.
Almost there
That is going to be one cool lamp!
Almost there
- Ron Stewart
Thanks, Ron. I borrowed the tab idea from the original, but it did not hide them directly behind the louvers. In the end, it probably doesn't matter unless you're really looking closely.
Almost there
- sras
Thanks, Steve. It's been a fun one to work on.
Almost there
Looking good, Ross!!
Jim
41 - 60 of 69 Posts
