1 - 20 of 69 Posts
· Registered
Discussion Starter · #1 ·
Intro
The movie "Parasite" was full of eye candy for those that gravitate towards a modern, minimalist style. One piece of set dressing that caught my eye was the tripod floor lamp that was in the living room of the Park house.
Property Plant Wood Interior design Houseplant
The light it gave-off was more atmospheric than illuminating, and I couldn't quite make out how the light box was constructed to shape the light like it did. It took some googling to track down more photos of the lamp designed and built by the Korean artist Bahk Jong Sun. Among other sites, 1stdibs.com had some good images that revealed louvers that were used to adjust the light.
Shelf Wood Rectangle Shelving Wood stain
In the spirit of the movie, I decided that I'd be a parasite and make a copy of the lamp. I used it as an opportunity to get some experience with Sketchup. I didn't fully model the lamp, but it did help to work out the size and proportions.
In homage to the movie, here's what I came up with.
Arm Easel Human body Sleeve Gesture
I started with the turret, which I'll describe next.
· Registered
Intro
I am a big fan of Parasite but must admit that I missed that lamp. Interesting concept, definitiely, as you write, more athmosphere than lighting. Looking forward to follow along!
· Registered
Discussion Starter · #3 ·
Intro
- kaerlighedsbamsen
It's sculpture masquerading as lighting. :)
· Registered
Intro
It s sculpture masquerading as lighting. :)
Indeed. And what a sculpture that is!
· Registered
Discussion Starter · #5 ·
Center turret
I'm assuming that the circular turret on the original lamp allows the light box to be rotated. In the original, the turret and arms were made of brass. And since I'm not a metalworker (yet, anyway), I'm making this component from wood.
For the prototype, I'll be using wood that I have on-hand. Given the dimensions needed and my stock, that leaves me with just cherry for the turret, turret arms, and legs. If the initial build goes well, I may shop for some more interesting options for a 2nd one.
The turret bottom has a hollowed top that fits a matching lipped cap, with enough of a gap between to fit a small lazy-susan bearing set to allow the cap to rotate freely.
Shelf Wood Rectangle Art Shelving
Here is the bearing set - it's about 4" across on the diagonals.
Camera accessory Auto part Carbon Circle Metal
The turret top and bottom were cut on the CNC, and I included a well in each piece to capture the bearing.
Wood Wood stain Hardwood Table Circle
Wood Wood stain Circle Button Hardwood
With the bearing seated, there's about a 1/16" gap showing between the top and bottom pieces.
Table Hat Wood Rectangle Floor
The bearing will sit loose, staying centered by the recess it sits in. The cap will receive a T-nut in its center to receive a bolt through the entire turret assembly that will hold the cap in place. With a little bit of thread-lock, I hope I can get enough compression to hold the cap in place without play, but still allow it to rotate. If this doesn't work, I'll scheme a different plan.
Plant Wood Table Flower Hardwood
Wood Sleeve Button Circle Pattern
Wood Sleeve Natural material Wood stain Hardwood
To spread the joy of sanding throughout the project rather than saving it to the end, I spent some time sanding the turret parts. Luckily, I don't need to worry about the interior surfaces.
Wood Textile Floor Hardwood Outdoor furniture
Next up are the turret arms that will provide joints for the legs to attach. (Connecting arms to legs doesn't sound quite right, but I couldn't come up with a better descriptor than "arms".)
· Registered
Center turret
I like that you look into the background of movies. I find myself looking more at the furnishings than the characters. looking for ideas.
It'll be fun to see how you create this challenge!
· Registered
Center turret
Looking forward to following along. should be a striking piece when finished.
· Registered
Discussion Starter · #8 ·
Center turret
Thanks, gents
- splintergroup
In Parasite, the house had such a presence, it could be considered a character in the movie!
· Registered
Discussion Starter · #9 ·
Turret arms
I cut the turret arms on the CNC as well, although these could have easily been done on the tablesaw too. Once I've drilled the fastener holes for the articulated legs, the arms will be glued together and to the bottom of the turret.
Rectangle Wood Drawer Font Gas
Table Wood Art Tool Hardwood
Wood Circle Natural material Hardwood Pattern
Shaping the legs is next.
· Registered
Discussion Starter · #10 ·
Leg shaping
I would do some things differently if I were starting this step over. I started by creating a template for the curved leg profile.
Mistake 1: I second-guessed myself on the shape/width of the leg profile. I drew the lines manually with a flexible batten just based on a few measurements from the Sketchup model. The result looked too narrow, so I widened it a bit. However, once I had the first leg cut out from the template, the proportions were wrong, so I had to re-work the template and re-trim the leg. I should have trusted the model.
Mistake 2: Using the template to flush-trim the leg on the router table. The narrow work was difficult to keep perfectly flat on the router table, which resulted in some indents when it rocked a little. I had to plane the edges afterwards, so I might as well have just used the template to transfer the profile to the work, cut it roughly on the bandsaw, and then planed down to the line.
Furniture Wood Flooring Floor Comfort
Wood Motor vehicle Gas Machine Vehicle
Wood Bumper Automotive exterior Material property Hardwood
At this stage, the legs were too beefy, and I ended-up planing them down a good bit.
Wood Flooring Table Floor Wood stain
While the legs still had two parallel sides, I cut out the notch (kind of a mortise?) at the top that will receive a contrasting spline (tenon?), which will have the pivot point for the leg. I cut these out on the bandsaw, leaving a little material to chisel out later.
Mistake 3: I forgot to tighten the blade guard on the bandsaw, and the blade wandered a bit. Oops.
Brown Rectangle Wood Wood stain Hardwood
I'll clean this up later.
Wood Font Plank Wood stain Hardwood
I then created a flexible template to mark the tapered sides of the leg. I had some 1/16" basswood sheets that worked great for this.
Mistake 4: I didn't create the template with an aggressive enough taper to start with, so once I did a rough cut on the bandsaw, I ended up with a lot more planing to arrive at the final shape.
Wood Rectangle Hardwood Tints and shades Gas
Wood Plant Cuisine Ingredient Pattern
These are only partially shaped. The lower half of the legs got planed quite a bit more after this. Once I'm totally happy with the shape and proportions, I'll take one of the legs and update the templates for next time.
Grille Wood Rectangle Hood Font
· Registered
Leg shaping
I find long, slender curves difficoult to get right. Think you did well despite som errors along the way
· Registered
Leg shaping
-"I might as well have just used the template to transfer the profile to the work, cut it roughly on the bandsaw, and then planed down to the line."
I am finding more and more that the simpler approach is the better one. Bandsaw and handplane is far more satisfying that trying to work with jigs and routers. Millimeter-level accuracy is unnecessary for most applications, including this one.
I am enjoying your postings. Thanks for sharing.
· Registered
Discussion Starter · #13 ·
Leg shaping
- kaerlighedsbamsen
Yes, I agree. I did some more fine-tuning last night, and I'll update this post with a new photo at some point.
- John
I agree - the hand shaping is much more satisfying than hogging away material at the router table. And as you've noted, the legs don't need to be identical copies. As long as they're roughly close in size and shape, they'll visually appear identical.
· Registered
Discussion Starter · #14 ·
Leg shaping
Here's where I've landed with the leg shaping. The tip cross-section is somewhere around 1/2" to 9/16" square.
Wood Road surface Rectangle Automotive tire Parallel
· Registered
Discussion Starter · #15 ·
Hinge joint
I'm using furniture connector bolts to fasten the spline to the leg, and another for the pivot for the joint. I would have liked to have found an alternative that had a smaller diameter head that was still shallow, but I wasn't able to locate any other options. I think these will be fine for this build, though.
I then proceeded to drill the counterbore on all the pieces to recess the head and then the 5/16" shank holes.
Next up was the spline that would become part of the joint. I worked out the exact length with a scrap of maple first.
Once I was happy with the fit of the test spline, I cut three of gaboon ebony.
I had enough completed to do a test assembly to get a sense of how it would look. I'm pleased with how it's coming along.
· Registered
Hinge joint
Wood Household hardware Rectangle Hardwood Flooring
Wood Floor Flooring Hardwood Rectangle
Wood Tree Wood stain Plant Hardwood
Wood Rectangle Hardwood Pattern Wood stain
Wood Rectangle Beige Sleeve Hardwood
Wood Rectangle Collar Dress shirt Hardwood
Wood Rectangle Hardwood Wood stain Collar
Wood Hardwood Wood stain Water Circle
Wood Hardwood Plank Wood stain Rectangle
Wood Hardwood Wood stain Flooring Plank
I'm enjoying following along on this one.
· Registered
Discussion Starter · #17 ·
Hinge joint
I m enjoying following along on this one.
- sras
Thanks, Steve. I've been enjoying it myself.
· Registered
Hinge joint
Elegant.
Best thoughts,
Mads
· Registered
Discussion Starter · #19 ·
Hinge joint
Elegant.
Best thoughts,
Mads
- mafe
Thanks, Mads.
· Registered
Discussion Starter · #20 ·
Turret/Arm assembly
I glued the arms together with some CA glue. The all end-grain joint wasn't going to be very strong regardless of glue choice. I just needed it to hold together until I could drill a center hole.
Wood Rectangle Wood stain Table Plank
Wood Wood stain Table Hardwood Tints and shades
Then I applied some wood glue to the arms where they met the bottom of the turret, keeping the glue about 1/4" from the edges to avoid any squeeze-out. I temporarily inserted a bolt through both pieces to align them while gluing.
Wood Tool Knife Everyday carry Blade
I used a hole saw to cut a disc of UHMW plastic that would be a low-friction washer. This would go into a counterbored hole on the underside of the assembly, with a bolt going up to the rotating turret cap.
Test-fitting the washer in some scrap:
Wood Line Beige Gas Rectangle
I then used the scrap to center the forstner bit over the 1/4" hole in the bottom to drill the counterbore.
Wood Wood stain Hardwood Tool Plywood
And then I could do another test assembly.
Wood Gas Hardwood Wood stain Chair
Wood Line Circle Natural material Beige
Wood Wood stain Flooring Plank Hardwood
Wood Wood stain Floor Plank Hardwood
My sanding debt is growing. The turret/arm assembly was all pre-sanded, but I still need to sand the legs and splines.
Next up is the light box.
1 - 20 of 69 Posts
