Options for drilling a 2" hole in hard maple
2617 Views 7 Replies 8 Participants Last post by  ChrisK
I'm looking for options (other than a drill press) to drill a 2" hole in hard maple. I've got a drill press, but it slips and haven't figured out how to get it fixed yet. So I'm looking for options of ways I could get a 2" hole drilled into some hard maple so I can make a nut for a wood screw.
Thanks, Michael
1 - 8 of 8 Posts
Do you have a hand drill? A 2" forstner bit would work.
A holesaw should work in a beefy hand drill, preferably corded. Just go slow and don't push too hard.
Another way is a circle guide with a dremel tool.
Are you needing a 2 inch disk to make the nut? or a two inch HOLE
If you want a 2 inch diameter disk drilled out of a block, then the hole saw is the way to go, just remember you want the Inside Diameter to be 2 inches so ~2 1/8 or 2 1/4 hole saw.
for the hole, as others said, beefy hand drill.
Alternatively, you can do this with a plunge router with a guide bearing… just center a pattern on the surface with double stick tape
many ways to skin a cat!
Corded hand drill and a hole saw. Just have someone ready to drive you to the ER when you break your arm - hehe. I've heard of broken wrists from doing things like this so be patient. You aren't stronger than a corded drill.
With the assumption that you're going to thread the inside of the 2" hole to make your nut then the first thing I'd do is try a new belt on my drill press.
Smart ass remarks aside, the Forstner bit in hand drill sounds like the best option. Hole saws in hard wood are a real pain in the butt - there's the tendency to over heat and burn the wood. And they're not very forgiving if you get off line while drilling - ask any plumber or electrician about the experience of having a Hole Hawg bind up on him while drilling studs.
Another approach would be to rough the hole out by drilling a ring of smaller holes and then clean it up with a router and a pattern bit.
+1 for DrDirt, plunge router with a guide bearing and a pattern.
or you can do this: http://www.woodmagazine.com/woodworking-tips/techniques/drilling-boring/hints-for-huge-holes/?page=4. Here they use a Forstner Bit, a Rabbeting Bit, then a pattern-routing bit. Works great!
Circle cutting jig and plunge router.
1 - 8 of 8 Posts
