1 - 20 of 24 Posts
I need to replace a section of counter top edging.
It has a cross section that I will need to fabricate like so:
It needs to be 8' long.
The best piece I could find locally with a matching grain pattern has a goodly amount of bow and crook to it.
The bow could be fairly easy to deal with.
The crook is another story.
It is too great to remove by trimming the board's edges.
I screwed a couple of straight 2×4s together and have clamped the offending piece into them.
The oak 1"X3"X8' has been clamped into the 2X4s over night about 12 hours.
The 2nd and 3rd pics were taken in the morning after removing the clamps.
I'm not sure if there is much improvement from the initial condition.
I'm considering applying water to the concave sides of the oak.
Then, clamping the wet sides against the 2Xs.
Any advice, suggestions or thoughts on dealing with this problem?
Premium Member
How will this piece be attached to the counter? If you can straighten it with the clamps, you should be able to straighten it with the counter, especially a large part,of the wood will be removed and it will be easier to straighten.
Hi firefighterontheside,
it will be nailed and glued.
But, the problem is not getting it fastened to the counter. That part is trivial. The problem is accurately ripping the 2 lengthwise saw cuts [one from an edge and one from a side] required to form the cross-section and ending up with a decent looking edge piece when it is installed around the counter's tile surface.
+1 to Bill's suggestion.
If that doesn't work, a last resort would be to cut a straight line down the centre of the piece and glue what was the convex top edge to what was the concave bottom edge. Thisshould give you a straight board with no tension and almost the same thickness. You can make the cut by tacking a straight edged piece to yours an run it through the table saw.
Or use a router table to take the material off instead of using a table saw.. however, given the flexibility of the piece, with proper feather boards or other means of pushing it against the fence and table, you should be able to cut that profile without much fuss.
Premium Member
When I have to cut something like that I put one concave edge to the fence and one to the table and make sure that the piece stays in contact with the table and fence right in the area of the blade. I think you can get satisfactory results that way. First make your 1/4" cut then stand it up and make the other cut. You may be able to straighten it a bit with your water method at least taking the bow out for a while.
Paul's method of attaching it to a straight edge such as plywood could work well too. You could even glue it on and then cut it back off after you make your rabbet.
Discussion Starter · #7 ·
... cut a straight line down the centre of the piece and glue what was the convex top edge to what was the concave bottom edge. Thisshould give you a straight board with no tension and almost the same thickness. You can make the cut by tacking a straight edged piece to yours an run it through the table saw.
- shipwright
I've thought about that approach. The problem is that it would give me one section of the counter's edging with a grain mismatch running through its middle along its length.
- MrUnix
I've just fab'd a couple of feather boards from 1" Douglas fir.
One has to be placed above while the other needs to be placed on the side of the piece.
It is not very flexible.
It requires too much pressure to remove both the bow and the crook.
Removing the crook requires a lot of pressure.
Accurately ripping the cuts would be very difficult, if even possible.
You could take one of those straight boards and cut or route 2 parallel lines in it deep enough to push the 1X3X8' Oak (?) into it to equal the depth of your rip. You could carpet tape the oak in place. Rip the outer line then the inner one with the straight edge against the fence.
I know this is outside your parameters- but maybe, try to find a better board? Failing that- feather boards applied, you should be able to make that board behave. Wetting one side is pretty sketchy- and in the end, it may return to original shape anyway.
You could try a nice miter cut half way along the length, just to relieve some tension. Just make a cut, so you lose 1/8 inch saw kerf- but two short pieces may lay better then one long.
-Dan
I've straightened out oak crown molding that looked like a ski by using heat. Don't need any moisture, just dry heat. A heat gun is a good source of heat, but you have to be careful not to scorch the wood. One end has to be held solid, as in a vise, while you hold the other end and gradually flex it while applying the heat. Be patient, as it will take a while for the heat to penetrate. You'll want to apply the heat to the convex side of the curve, and pull the wood toward you. Over bend, as there will be some spring back. When you think you have it bent far enough, remove the heat and let the wood cool before releasing your grip on it. Just a few minutes of cooling should be enough.
Though I know from experience that this method works, my confidence is somewhat diminished due to the large cross section of wood you have to heat and bend.
Discussion Starter · #11 ·
Thanks folks for your input on this.
Many of your suggestions I've already considered and discarded as not getting me where I want to go with this.
I think I'll try making a quick and dirty steam-box from 4" PVC pipe and fittings, then use steam to soften and straighten the board out.
Yeah, it is a bit over-kill for this particular use.
But, I do have some projects I've been considering that will require steam bending.
This will be a good test bed for the method and get me set up for it.
Thanks again guys.
I'm back.
My first real job after high school was as an aircraft template maker.
I have never lost then compulsion to work within a 0.03" tolerance when making parts by hand.
No matter what the material.
M'lady is getting a bit miffed because I've got her kitchen tore up and have had it that way for over a week now.
She's got it well in check.
But, I can still tell she's wearing thin.
So, it's time to put my analness aside and get moving on towards completion.
Yesterday, I put wedges under the ends of the board and reversed the board's crook.
This morning most of the crook was gone and what was left didn't require much pressure to straighten out as it went through the saw.
The rip cuts to form the cross section came out good.
The edging has been fitted and is ready to install and finish.
M'Lady knows how to motivate me, reward and punishment.
I was not headed for a reward.
Now, I think I am.
Discussion Starter · #17 ·
Cookie… Or nookie?
- TheFridge
Both!
She knows how to reward properly.
On the other hand, she's a damn thorough punisher too.
Ok, another question:
I am going to refinish the entire oak edging around the counter.
Areas along the edging, especially around the stove and eating bar, have hardened oils and grease on them.
Sanding will be a mess because the oils will clog the sanding grit.
Is there a good degreaser that will remove the built up coating without any bad effects for refinishing the wood?
Discussion Starter · #19 ·
By golly, I do have one.
I brought 1 pair of skis with me to Hawai'i.
I also included my waxing and base finishing tools.
Both plastic and steel scrapers are part of that kit.
I do not have a burnishing tool for it though.
Never needed one for the ski bases.
Gotta get me a good cabinet scraper and burnishing tool now.
Thanks
Premium Member
I did see where they were skiing on the volcano a few weeks ago. Drive to the top and ski down. Have to take turns being the driver I guess. Lava rock can't be good on the skis though. I tend to prefer skiing in Colorado.
1 - 20 of 24 Posts
