Check the wiring diagram on the inside cover of the starter. Generallly you just need to change the control transformer input voltage (which you have done) and install the proper sized heater for overload protection if applicable. Can you post a picture of the information sheet on the inside cover?
Your control station wiring is a standard three wire setup and should be fine.
Not sure what you mean by that statement… a 240v motor has 3 wires (2 hot + ground), and a 120v motor has 3 wires (2 hot + ground). Where is this extra wire coming from?
