1 - 5 of 5 Posts
I seek your advice.
I'm in the process of making several speaker cabinets out of 1.5" oak. I use the vertical gluing clamp made by Plano and love it. The last pieces I glued up were three tops for the cabinets measuring roughly 16" x 16" each. I had applied the glue and clamped the first two. I had applied the glue and placed the third piece in the clamp, closed the clamp but hadn't tightened it when I got interrupted. I wiped the glue squeeze out off all three tops and left for dinner. This morning I removed each piece. Often, I loosen the clamps on all the clamps first, and then remove the pieces one at a time, but not always.
When I got to the thire piece, the clamp was loosened, but I honestly can't remember loosening it, so I'm worried that I never tightened the clamp on that piece in the first place. I think I did, but I'm not sure.
Now, when I examined the piece, it was perfect. I did a quick 80 grit sanding and there were no gaps between the edges, and the boards were perfectly flush. That is, when I ran my hand accross the grain, it was perfectly smooth. It seems highly unlikely that I could have lucked out so much that the piece would be perfect if I hadn't tightened the clamps. But, I still worry….
Thus my two questions:
If the clamp had not been tightened, and the only pressure on the boards was their own weight, am I going to end up with weak joints?
Should I make another piece to replace the one that might not have been clamped?
Thanks so much for your advice.
Best wishes,
Dave
If it's tight, despite possibly not having been clamped, you have little to worry about, especially at 1.5" thick.
Discussion Starter · #5 ·
Thanks so much for the replies. I feel much better now. I did take great care in milling the boards, so from what you all have said, I should be good to go.
Thank you, Paxorion, for the youtube link. That was both interesting and reassuring.
JoeinGA, I tested it by trying to pull the boards apart and even by standing on it, and it showed no signs of weakness. I think the weight of the boards themselves, and of the clamp put some pressure on it even if I did forget to tighten the clamp.
Bigblockyeti, I appreciate the reassurance.
Have a great day, everyone, and thanks again!
1 - 5 of 5 Posts
