1 - 7 of 7 Posts
Discussion Starter · #1 ·
Bench Construction Begins
Up until a few weeks ago I have been using a thrown together bench made of some 2×4s and a sheet of plywood. I finally decided that I should have a proper bench if I am going to be serious about woodworking. I have a huge shop that I am finally getting setup and decided as my first project that I would build a bench. It is a very basic bench that is 6.5 feet long and about 25 inches deep. What I really like about is that it does not use any metal fasteners at all. It is completely built using glue and wooden joinery and mostly hand tools. So far I have glued up all of my parts except for the top. I have cut the through mortises in each of the legs and have started making the tenons so that I can assemble the base. I can't wait to complete it and use it for the first time. I will post some pictures of my progress soon.
Sounds like you are having fun!! A bench is a wonderful project to start a shop with. I am looking forward to seeing pictures of the construction.
hey scott, every time i see you your sittin in that chair, do you ever do anything…...lol…...hey ike and berry looking forward to your bench…..im having some stirrings in that direction myself…but ive got a desk ive got to do before that…..so have fun with your project…..
Discussion Starter · #4 ·
Base is finished
i finally finished the assembly and glue up of the base for my cabinet makers bench. I still have a few dowel pins to put in the legs, but the main glue up and assembly is done. Now I get to start on the top. Here are some pics of the bench so far.
Base is finished
looks very beefy and stout. did you design the bench yourself? or are you following a plan/other bench?
Discussion Starter · #6 ·
The top is done and attached to the base
I finally got the top to my new bench glued up and attached to the base. I ended up using dowel pegs to attach the top to the base. Doing this enables me to remove the top if I need to in the future, but holds the top to the base securely while I am using it. Take a look at the pictures to get a better look. I modified plans that I found to build this. The original plans are Bob and Dave's Good, Fast, and Cheap Bench. You can find them if you Google the description. 90% of this bench was made with hand tools and it does not use any metal fasteners to attach the parts of the bench itself. This was a great project to get my shop going. All I have left to do is plane the top flat, seal the bench top, make some bench dogs, and put the vices on.
Sounds good
1 - 7 of 7 Posts
