On the drawing board - The main Frame
I'm building a Bandsaw, my 4th shopmade tool. It will be made of layers of phenolic plywoods with 14" wheels. The table will be fixed at 90 degrees coz I don't see any need to cut at 45 deg and it's going to be easy to make a sled for it.
Here are the plans that I created using CorelDraw.
The square hole at the base of the frame will house the tension adjuster.
I then exported the drawing to Sketchup to create 3D images of the Frame.
next in the series is the tension adjuster.
