Your best bet would be to make a sled for your planer. Check out http://www.finewoodworking.com/workshop/video/a-planer-sled-for-milling-lumber.aspx
I would not recommend running end grain, such as cutting boards, through a planer. You are asking for major problems if you do that regularly, even with a sled.The router sled method is good for planing end grain, like cutting boards. I just recently made a melamine sled to joint a 9" wide board with my planer. Worked well, though I had to make it 72" long, and the melamine itself was not totally flat over that distance. It still worked, I just had to shim a few extra places.
If you have a heat gun, it will hep you get the glue off. It sticks to the melamine pretty well!
-Brian
- bbasiaga
Yep. That is why I would turn to the router sled method in that case. The router bit can handle it with light passes and is way less dangerous/risky than trying to do it in your planer. Also, much easier to replace a dull router bit than it is to change your planer knives.The router sled method is good for planing end grain, like cutting boards. I just recently made a melamine sled to joint a 9" wide board with my planer. Worked well, though I had to make it 72" long, and the melamine itself was not totally flat over that distance. It still worked, I just had to shim a few extra places.
-Brian
- bbasiaga
Be Careful!
Herb
- HerbC
When I did it, I slid shims under the board at any gaps (get some very thin shims) and then ran a bead of glue around those to hold them in place. That way I never got any glue on my actual board.So if I understand the "hot glue" concept, you re basically just squirting it under any gap and letting it dry to form that solid foundation, rather than using the intricate slider wood pieces in the video above?
- ryanjg117
